- Thank you received: 5
two pause / resume inputs
- Kasper-001
3 years 3 months ago - 3 years 3 months ago #276246
by Kasper-001
two pause / resume inputs was created by Kasper-001
hello
is there a simple way to add one more input to this setup
# --- Toggle button stuff ---
loadrt toggle count=3
loadrt toggle2nist count=3
addf toggle.0 servo-thread
addf toggle.1 servo-thread
addf toggle.2 servo-thread
addf toggle2nist.0 servo-thread
addf toggle2nist.1 servo-thread
addf toggle2nist.2 servo-thread
loadrt and2 count=2
loadrt or2 count=2
addf and2.0 servo-thread
addf and2.1 servo-thread
addf or2.0 servo-thread
# --- Toggle machine on button ---
net btn-pwr toggle.1.in <= hm2_7i92.0.7i76.0.0.input-24 # Machine on Button
net pwr-btn toggle2nist.1.in <= toggle.1.out
net tog-on toggle2nist.1.is-on <= halui.machine.is-on
net pwr-on halui.machine.on <= toggle2nist.1.on
net pwr-off halui.machine.off <= toggle2nist.1.off
# External Program Pause/Resume Button
net pause-resume-btn and2.0.in0 and2.1.in0 <= hm2_7i92.0.7i76.0.0.input-23
net pause-on toggle2nist.0.is-on and2.0.in1 <= halui.program.is-paused
net run-on and2.1.in1 <= halui.program.is-running
net pause-sig or2.0.in0 <= and2.0.out
net resume-sig or2.0.in1 <= and2.1.out
net toggle-ok toggle.0.in <= or2.0.out
net togglesig toggle2nist.0.in <= toggle.0.out
net toggleon halui.program.pause <= toggle2nist.0.on
net toggleoff halui.program.resume <= toggle2nist.0.off
i like to use input.0.btn-mode on my ps3 controller
Last edit: 3 years 3 months ago by Kasper-001.
- Thank you received: 5334
3 years 3 months ago #276249
Replied by PCW on topic two pause / resume inputs
You can make wider "AND" and "OR" gates with the logic component
- Kasper-001
3 years 3 months ago #276253
by Kasper-001
Replied by Kasper-001 on topic two pause / resume inputs
sorry but i can´t see how its done,
3 years 3 months ago #276254
I don't totally understand the logic but it seems like you might need
say a 3 input "OR" gate, and that is something the logic component can do...
- Kasper-001
3 years 3 months ago #276257
by Kasper-001
3 years 3 months ago - 3 years 3 months ago #276258
Nothing to build, the logic component is part of LinuxCNC
Here's an example of creating a 3 input "or" gate:
halcmd: loadrt logic personality=0x203
halcmd: addf logic.0 servo-thread
And the pins it creates:
halcmd: show pin logic
Component Pins:
Owner Type Dir Value Name
51 bit IN FALSE logic.0.in-00
51 bit IN FALSE logic.0.in-01
51 bit IN FALSE logic.0.in-02
51 bit OUT FALSE logic.0.or
51 s32 OUT 164 logic.0.time
( The "logic.0.or" pin is the output )
"man logic" for details
Component Pins:
Last edit: 3 years 3 months ago by PCW.
Time to create page: 0.418 seconds
