Custom component - addf failed
2 years 4 months ago #302167 by Rookie0
same error in my hal file.
i just wrote a very simple comp, and installed it with sudo in terminal.
i ran linuxcnc app from desktop, then the same error reported.
BUT, it worked well in halrun.  I'm confused.
2 years 4 months ago #302171 by Rookie0
i've found the cause of the problem just right now.
it's UNDERLINE in the component's name.
remove them (both in code and filename), the function works!
but i'm still confused, why the other comps with same format in source code, they must be worked well in fact...
i'm poor in C/C++, just hope someone find the reason and fix it. Thanks~.~
Time to create page: 0.079 seconds
