Linuxcnc still talks to the parallel port via a realtime component\driver. Each external piece of hardware as their own realtime component\driver that is used for back & forth communication. Before jumping of the deep end I suggest a read of the docs maybe an idea. Almost all of the hal components are described.I am aware of that, which is why I would probably use an SPI Ethernet board to communicate with the Arduino. But the point is that it does not need to be an Arduino, as soon as the program works.
I think I am close, actually, I wrote a HAL component using a .comp file, compiled with halcompile, and loaded using loadrt. I can already manipulate position commands and axis velocities in C, which is exactly what I wanted. Now, (given that the Arduino connection can keep up of course), will this be just as fast as any other hardware, allowing for high-precision motion, or is this halcompiled realtime component still slower than a real parallel port?
