Halcompile no such file
3 years 2 weeks ago #283191 by qbyoung
Probably would be a simple question, when installing cia402, reporting in No such file but instead halcmd works.
3 years 2 weeks ago #283198 by rodw
Replied by rodw on topic Halcompile no such file
sudo apt-get --install linuxcnc-uspace-dev
Should install halcompile
3 years 2 weeks ago #283200 by tommylight
Replied by tommylight on topic Halcompile no such file
He is running a RIP install, so this should work:
sudo ./halcompile --install component_name.comp
3 years 2 weeks ago - 3 years 2 weeks ago #283201 by rodw
With RIP, sudo is not required but it should available without installing anything  provided you have run the rip-environment script
. ~/linuxcnc-dev/scripts/rip-environment
then
halcompile --install mycomp.comp
Last edit: 3 years 2 weeks ago by rodw.
3 years 2 weeks ago #283210 by qbyoung
Replied by qbyoung on topic Halcompile no such file
Exactly, thanks,  after a close of terminal, it is fixed by a rejoin of the environment
3 years 2 weeks ago #283233 by Elco
Replied by Elco on topic Halcompile no such file
I am running linuxcnc 2.9.0-pre0, which seems to be the last version on my 5.19.0-rt system, and am trying to get halcompile installed. I cannot get sudo apt-get --install linuxcnc-uspace-dev to work (command error). Is there another way to get lsrio16.comp installed, so that I can test some hardware?
Thanks,
Elco
Time to create page: 0.202 seconds
