7i96S mesa_modbus encoder count interference
2 years 5 months ago #301593 by PCW
Can you post your hal/ini files and spindle_load source so
I can try and duplicate the issue?
Does the error occur if there is no connection? (wondering if this
can be tested without your particular VFD)
2 years 5 months ago - 2 years 5 months ago #301897 by somuchforfree
Is it possibly just noise related?
that is, what happens if you set:
setp hm2_7i96s.0.encoder.00.filter true
setp hm2_7i96s.0.encoder.sample-frequency 100000
I don't have a .sample-frequency in my parameters, just counter-mode, filter, index-invert, index-mask, index-mask-invert, scale and vel-timeout.
I missed that the sample-frequency is child of encoder, not encoder.00. This is why I couldn't set it with setp.
Unfortunately setting the filter frequency like you suggested did not fix the issue.
Last edit: 2 years 5 months ago by somuchforfree. Reason: fix quote
2 years 5 months ago #301900 by somuchforfree
Sorry if that was unclear from my original post, but we do not have a VFD connected, it's an Arduino that takes an analog input from a voltage divider conected to the VFD's analog out. That does not matter for the functionality, just to clear things up.
// spindle-load.mod #define MAX_MSG_LEN 16 // may be increased if necessary to max 251 static const hm2_modbus_chan_descriptor_t channels[] = { /* {TYPE, FUNC, ADDR, COUNT, pin_name} */ {HAL_U32, 4, 0x0000, 1, "state"}, };
# custom_jogwheel.hal # set jumpers W1-W3 to left for single ended encoder setp hm2_7i96s.0.encoder.00.counter-mode 1 setp hm2_7i96s.0.encoder.00.filter true setp hm2_7i96s.0.encoder.sample-frequency 100000 # not encoder.00.! net joint-selected-count <= hm2_7i96s.0.encoder.00.count
The encoder count and count-latched stay at 0, the input-a and input-b are constantly HIGH, rawlatch and rawcounts are stuck at 65535 but the encoder's velocity and velocity-rpm go to negative values like -15 and -850 respectively, as described in earlier posts.
All of this happens even if I do not have the Arduino connected to the Mesa.
2 years 5 months ago - 2 years 5 months ago #301903 by somuchforfree
If I move the setp for the update-hz above the loadrt conv_u32_float the Modbus updates at 10 Hz but the encoder count is going crazy.
If I move it below the loadrt, it will read a correct value once at startup but never update. The encoder rawlatch and rawcount are always at 933 or 934 (restarted LinuxCNC 5 times, 5 times 933/934) after the first Modbus read but after this they are stable and only change when I actually turn the jog wheel.
2 years 5 months ago - 2 years 5 months ago #301909 by PCW
OK I cannot duplicate this (at least with no modbus device) so not sure whats next
Used your spindle-load comp
With this hal support:
loadrt spindle-load ports=hm2_7i96s.0.pktuart.0
setp spindle-load.00.address 1
setp spindle-load.00.baudrate 9600
setp spindle-load.00.rxdelay 255
setp spindle-load.00.txdelay 10
addf spindle-load.00 servo-thread
setp spindle-load.00.update-hz 10
loadrt conv_u32_float count=1
addf conv-u32-float.0 servo-thread
net spindle-load-float conv-u32-float.0.in <= spindle-load.00.state
Here is a halshow view: (encoder velocity 0 when not moving)
Here is the encoder behaviour when moved by hand:
Note: you cannot use count mode with a quadrature encoder, this is
an up/down counter mode not a 1x quadrature mode and will miss-count
and give wild velocity numbers when fed quadrature.
Better to use the MPG inputs on TB3 if you want 1X quadrature
Last edit: 2 years 5 months ago by PCW.
Time to create page: 0.462 seconds
