Quadrature decoding to produce pulse + direction
- frogandspanner
30 Jul 2024 12:44 #306428
by frogandspanner
Quadrature decoding to produce pulse + direction was created by frogandspanner
I am building an MPG control for a Chinese 920 lathe I am converting to CNC. I want the controls to have the same intuitive feel as the original manual lathe, with the option of overriding to use full CNC, so will be fitting an MPG where the standard controls would be. I have the prototype setup working, using _encoder_ to decode the quadrature encoding (it is strange the the decoder component is called "encoder"). This produces a count, but I'd also like quadrature decoded to pulse + direction for further processing.
Is there any way of doing that with standard HAL components?
- Thank you received: 7504
30 Jul 2024 13:51 #306430
Replied by tommylight on topic Quadrature decoding to produce pulse + direction
Hmmmm why?
LinuxCNC can use any encoder as MPG, so no need to convert anything, even on parallel port it works.
- Thank you received: 5336
30 Jul 2024 14:13 #306432
Replied by PCW on topic Quadrature decoding to produce pulse + direction
Yes, basically LinuxCNCs motion component already does this with the MPG count.
- frogandspanner
02 Aug 2024 04:45 #306706
by frogandspanner
Replied by frogandspanner on topic Quadrature decoding to produce pulse + direction
I don't want the count - I want pulse + direction so I can combine decoded pulses from the quadrature encoder/MPG with pulses from other sources.
02 Aug 2024 08:02 #306728
In any case LinuxCNC uses a count for jogging
You could combine MPGs by adding counts in hal
- frogandspanner
02 Aug 2024 08:07 #306729
by frogandspanner
That's what I currently do, but I wish to extend this to apply different scales at different time to the combined streams of pulses to produce the count.
For example, I wish to have a switch that reduces the MPG count:pulse ratio, then revert to the original ratio. I also wish to combine that count with another count (which may have a similar scaling switch).
02 Aug 2024 08:18 #306731
You can scale the individual counts
take a look at
scaled_s32_sums.comp
(this may only be in master)
take a look at
- frogandspanner
02 Aug 2024 08:27 #306733
by frogandspanner
But does that apply to the counts, or the counts since a certain condition/time/bit being set?
If it applies to *all* counts then it doesn't do what I want as if I am rotating my MPG, then set the bit that changes scale it would apply to the accumulated, but I want it to apply only after the bit has been set.
02 Aug 2024 08:56 #306734
Typically the scaling would be done by setting the jog increments.
- Mecanix
- Thank you received: 229
02 Aug 2024 09:02 #306737
by Mecanix
shadowcode.io/quadrature-decoder-verilog/
Better yet, use flags!!
Replied by Mecanix on topic Quadrature decoding to produce pulse + direction
Potential rewrite/custom solution required. See 'old/new states' for inspiration.but I want it to apply only after the bit has been set.
Time to create page: 0.936 seconds
