7i95 sserial port as gpio
2 years 1 month ago #309601 by ekbiker
Replied by ekbiker on topic 7i95 sserial port as gpio
I decided to go with a buffered parallel port BOB to get more GPIO (Mesa 7i75 Breakout/FPGA protection card). But I also need a pwmgen to drive a Mesa SPINx1A for the VFD. I plans to use all 6 step/direction and encoder channels eventually, so I don't want to use one of those for VFD speed control if I don't have to. Leaving the sserial as is for future expansion.
So I need firmware which adds 1 pwngen to the P1.
Would 7i95t_5abobd.bin in the MesaCT do this? I assume it would make 5 pwmgen's available; and for those pins I want to use as I/O, I just declare them in HAL as GPIO. Is this correct?
Or do I need special firmware?
2 years 1 month ago #309604 by PCW
Replied by PCW on topic 7i95 sserial port as gpio
7i95t_5abobd.bin has 1 PWMgen and I think 4 or  or 5 additional stepgen channels
Its designed for the common "Sainsmart Mach 5 Axis breakout"
2 years 1 month ago - 2 years 1 month ago #309609 by ekbiker
Do I need special firmware? Can you please make one for me?
Last edit: 2 years 1 month ago by ekbiker.
2 years 1 month ago #309614 by PCW
No, 7i95t_5abobd.bin should work.
The following user(s) said Thank You: ekbiker
2 years 1 month ago - 2 years 1 month ago #309959 by ekbiker
I flashed 7i95t_5abodd.bin, it succeeded. Then I hit reload, and now the card can't be found. I rebooted the card and restarted MesaCT, still can't find the board. Jumpers still in the same location, NIC settings the same. No red leds.
What to do now?
2 years 1 month ago - 2 years 1 month ago #309960 by PCW
What is the card address and what does the command
ip a
report?
You can boot the fallback configuration by setting both IP address jumpers UP
(the will also set the card IP address to 192.168.1.121)
Last edit: 2 years 1 month ago by PCW.
Time to create page: 0.269 seconds
