Need help setting up a lathe(Sherline)
6 years 11 months ago #150523 by kbec
I have these, www.sherline.com/product/67127-stepper-motor/#specifications
I wanted those since I know the dimensions would work and other have used them while manually using the machine as well.
The following user(s) said Thank You: Mike_Eitel
6 years 11 months ago #150524 by pl7i92
manually using the mashine while steppers/DYNAMOS are connected is quite a chellenge for the Drivers
Analog drivers like D542 may produce 150V towards the electronic while turning the Spindel manually
be aware of that you can get nice quick connects between them it is nor a good work but safe
and you will fast realy fast find out you mashine no longer needs manuell as of subs on the controll will get you fast into conture
6 years 11 months ago #150531 by kbec
I know I would need to disconnect them to do any manual work. I just want the option in case I need it. I am just starting out.
6 years 11 months ago #150539 by Leon82
Do they sell the female side of that connection? It would make wiring it easier.
6 years 11 months ago #150540 by kbec
They have the harness, they are a little more expensive though.
6 years 11 months ago - 6 years 11 months ago #150542 by Leon82
You will be wiring from the driver to the windings in the motor. Having a connection like that will make it easy to unplug to work manually.
But if the other side is only sold with the control box you may need to get a different set.
I found a pack of 10 on Amazon for cheap. 4 pins and they have a screw retaining ring
Aviation Plug Connector 10 Pairs Male Female Panel Metal Wire Connector 16mm Socket (4 Pins 10-Pack) www.amazon.com/dp/B07D7SHKGK/ref=cm_sw_r_cp_apa_i_mFA0Db2HXPG6K
Last edit: 6 years 11 months ago by Leon82.
Time to create page: 0.092 seconds
