Duplomatic BSV N 160 Werkzeugwechsler / Turret
5 years 4 months ago #211586 by Ingo
Hi guys, I was reading, looking for something about the model of my Turret (BSA 200 12/20), but as I'm nob here I'm suffering a lot..., actually I was very confused. First of all, I don't know if I can take this model from you because you are different. Another thing, my 12-position turret, I use the inputs, Bit1,2,4 and 8 I know it also has Parity and stroby (I don't know what it's for, how do you use it), it still has over temperature, index and locked... ., how I use all this, could someone clarify me, show me the way, because I'm using 7i76E and a 7i84 daughter (including all turret entries are on it).
Thank you very much
Ingo
5 years 4 months ago #211808 by andypugh
"Strobe" is used to indicate that all the position signals will have settled and can be trusted.
"Parity" is a check that all the signals are working properly. (It basically will show a 1 if an odd number of sensors _should_ be triggered and 0 if its an even number. By comparing the parity pin and the actual pins you can check the sensors.
The HAL "carousel" module can handle all this.
4 years 11 months ago #226931 by depronman
Would the above be suitable for the dupomatic BD80 turret as fitted to my Denford cyclone lathe 1998 model ?
It is an 8 tool turret and from what I have read up so far uses 4 bits to determine tool position, strobe and lock
Cheers Paul
4 years 11 months ago #226972 by andypugh
It should, it was certainly designed with that sort of thing in mind.
4 years 11 months ago #226997 by depronman
Hi Andy thanks for the quick reply
That is certainly very good news
Next question (likely of many) if I was to configure a second parallel port as on IN port would all the connections needed be doable through the parallel port ?
My worry is that the parallel port may not be quick enough - any thoughts please ?
Would I be wanting the duplo8 version as listed above in that my BD80 is an 8 turret version ?
Cheers. Paul
4 years 11 months ago #227001 by andypugh
I am afraid I seem to have answered the wrong question, ie not the one you asked.
I was talking of the "carousel" HAL component, and it seems that you were talking about the "duplo" HAL component.
In either case, I am fairly sure that between them there will be a way to control your turret.
I would expect a parallel port to be easily fast enough. The servo thread itself only runs at 1kHz.
The following user(s) said Thank You: depronman
Time to create page: 0.181 seconds
