Can someone help me understand what's on this preview screen?
4 years 5 months ago #244217 by usert_l
I put an arrow pointing to the circle thingy on my LinuxCNC preview screen. I can see that the circle's center seems to correspond to the G54 X and Z coordinates. What I don't understand is why it's set there (X=0.557 and Z=0.000) and what purpose it serves.
I used Ezilathe to create this g-code program for my lathe. Some screenshots are attached. I'm still very new to this Ezilathe software, and this part is my first trial in learning to use LinuxCNC on a lathe.
4 years 5 months ago #244219 by tommylight
4 years 5 months ago #244224 by usert_l
Another note I forgot to mention is my lathe has no physical limit switch for homing. So I set up reasonable travel limits in my ini file. I manually home each axis a safe distance away from the work piece, but not so far away that it would exceed the soft travel limits.
For this kind of set up, is there a particular coordinate system that is most suitable?
4 years 5 months ago #244231 by tommylight
I had and still maintain machines with no limit switches, once you learn to live with it, it works just fine.
And i use g54 on those, always.
But i have little experience with CNC lathes, so might want to wait for someone more experienced to answer.
The following user(s) said Thank You: usert_l
4 years 5 months ago #244246 by andypugh
After a bit of experimenting, I think that it might be the machine absolute zero.
4 years 5 months ago - 4 years 5 months ago #244254 by snowgoer540
Ironically this came up tonight with regard to QtPlasmaC, and after some experimenting, I can confirm that Tommy is right, it does indicate that one of the various offsets is active (or not zero'd out).
That said, it seems finnicky. Example: I had a G54 and G55 offset set. I G53G0X0Y0Z0 and then touched off on all axes. Same for G55. The small origin (glcanon.py calls this "draw_small_origin") persisted. Restarted, and it went away.
But further, I'm not sure I understand the point. As soon as you touch off (G54 for example) the small origin will light up. It will remain always lit up unless you take the time to go to machine zero, and clear all offsets (and possibly restart). I'm having trouble picturing the work flow where this would make sense/be necessary?
Last edit: 4 years 5 months ago by snowgoer540. Reason: the editor's placement of things is special
Time to create page: 0.221 seconds
