Re:Mesa 7i77 differencial encoder connection.
- ishman
My motor's encoder pins are as below.
12 Power supply(5V) +5V
13 Public ground 0V
1 Encoder A+ input A+
6 Encoder A- input A-
2 Encoder B+ input B+
7 Encoder B- input B-
3 Encoder Z+ input Z+
8 Encoder Z- input Z-
4 Encoder U+ input U+
9 Encoder U- input U-
5 Encoder V+ input V+
10 Encoder V- input V-
14 Encoder W+ input W+
15 Encoder W- input W-
11 Inhibit ground FG
While 7i77 provides following.
1 QA0 TO 7I77
2 /QA0 TO 7I77
3 GND FROM 7I77
4 QB0 TO 7I77
5 /QB0 TO 7I77
6 +5V FROM 7I77
7 IDX0 TO 7I77
8 /IDX0 TO 7I77
- BigJohnT
- Thank you received: 994
- ishman
I am afraid I don't know! The whole connection comes through a multi-cored cable and goes directly to the driver via serial cable type connector. But from Driver's output, there is A+,A-,B+,B-,Z+,Z- and GND and ZOC. Total eight connector output they provide.Does one set go to the drive and one set to the controller?
- ishman
I think it's the same thing as you asked. driver provides one set of output to controller. But is it a good idea to take feedback from driver ? and not from encoder directly ?
- BigJohnT
- Thank you received: 5334
- ishman
Now it becomes clear that I should use drives output as an encoder feedback.
Thanks again.
- BigJohnT
ABZ are the encoder lines, 1000+ pulses per rev. Incremental quadrature + Index
UVW are the Hall sensors, 6 unique patterns per rev, low resolution but absolute position.
ABZ are used for positioning, UVW purely so the drive knows which coils need power as the motor rotates.
- ishman
Wonderful information. I appreciate your knowledge andypugh.ABZ are the encoder lines, 1000+ pulses per rev. Incremental quadrature + Index
