5i23 with 7i33 and smart serial firmware question
03 Jul 2012 22:35 #21532 by clkeck1
Im getting ready to fire up the new system
its a 5i23 running a 7i33 and a 7i44 (which has 2to 7i64s and a 7i70)
Is there a svss4_8 firmware for that setup?
Cory
04 Jul 2012 00:33 - 04 Jul 2012 00:33 #21542 by andypugh
Not in the default set. (I am not sure why).
I have attached one of the many versions of svss8_8.bit that I have lying about on my PC (which I was using until deciding I needed one with a 7i39 pinout too).
File Name: svss8_8.zip
File Size:88 KB
Last edit: 04 Jul 2012 00:33 by andypugh.
04 Jul 2012 19:27 #21569 by clkeck1
I loaded the new bit file and everything is working except for the 7i70 and I get the error attached.
Any ideas?
Cory
04 Jul 2012 19:35 #21570 by PCW
What version of LinuxCNC are you running?
Sounds like it may not be new enough
to support the generic sserial devices
04 Jul 2012 19:43 #21571 by clkeck1
I used my old install CD and then updated to 2.5
04 Jul 2012 20:09 #21573 by andypugh
That ought to work. Can you do the following:
Open two terminal windows.
Window1: halrun
Window1: loadrt hostmot2 debug_modules=1
Window2: sudo echo 5 > /proc/rtapi/debug
Window1: loadrt hm2_pci
Window1: exit
Window1: dmesg
And paste the dmesg output here ?
04 Jul 2012 20:15 - 04 Jul 2012 20:16 #21574 by PCW
if you run linuxcnc from the command line what version does it print?
I'm still running 2.5pre2 and it works fine here (just tried)
Last edit: 04 Jul 2012 20:16 by PCW. Reason: ommision
04 Jul 2012 20:35 #21576 by clkeck1
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000008f000 (usable)
[ 0.000000] BIOS-e820: 000000000008f000 - 0000000000090000 (reserved)
[ 0.000000] BIOS-e820: 0000000000090000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ee98000 (usable)
[ 0.000000] BIOS-e820: 000000007ee98000 - 000000007eebf000 (reserved)
[ 0.000000] BIOS-e820: 000000007eebf000 - 000000007ef47000 (usable)
[ 0.000000] BIOS-e820: 000000007ef47000 - 000000007efbf000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007efbf000 - 000000007eff1000 (usable)
[ 0.000000] BIOS-e820: 000000007eff1000 - 000000007efff000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007efff000 - 000000007f000000 (usable)
[ 0.000000] BIOS-e820: 000000007f000000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.5 present.
[ 0.000000] last_pfn = 0x7f000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-DFFFF write-protect
[ 0.000000] E0000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07F000000 mask FFF000000 uncachable
[ 0.000000] 2 base 0FFFF0000 mask FFFFF0000 write-protect
[ 0.000000] 3 base 0FFF10000 mask FFFFF0000 write-protect
[ 0.000000] 4 base 0FFF20000 mask FFFFF0000 write-protect
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000008f000 (usable)
[ 0.000000] modified: 000000000008f000 - 0000000000090000 (reserved)
[ 0.000000] modified: 0000000000090000 - 000000000009ec00 (usable)
[ 0.000000] modified: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000007ee98000 (usable)
[ 0.000000] modified: 000000007ee98000 - 000000007eebf000 (reserved)
[ 0.000000] modified: 000000007eebf000 - 000000007ef47000 (usable)
[ 0.000000] modified: 000000007ef47000 - 000000007efbf000 (ACPI NVS)
[ 0.000000] modified: 000000007efbf000 - 000000007eff1000 (usable)
[ 0.000000] modified: 000000007eff1000 - 000000007efff000 (ACPI data)
[ 0.000000] modified: 000000007efff000 - 000000007f000000 (usable)
[ 0.000000] modified: 000000007f000000 - 0000000080000000 (reserved)
[ 0.000000] modified: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 7000-c000
[ 0.000000] RAMDISK: 37369000 - 37fef6b8
[ 0.000000] Allocated new RAMDISK: 008b5000 - 0153b6b8
[ 0.000000] Move RAMDISK from 0000000037369000 - 0000000037fef6b7 to 008b5000 - 0153b6b7
[ 0.000000] ACPI: RSDP 000f2060 00024 (v02 INTEL )
[ 0.000000] ACPI: XSDT 7effe120 0004C (v01 INTEL D525MW 00000053 01000013)
[ 0.000000] ACPI: FACP 7effd000 000F4 (v03 INTEL D525MW 00000053 MSFT 0100000D)
[ 0.000000] ACPI: DSDT 7eff9000 03796 (v01 INTEL D525MW 00000053 MSFT 0100000D)
[ 0.000000] ACPI: FACS 7ef87000 00040
[ 0.000000] ACPI: APIC 7eff8000 00084 (v02 INTEL D525MW 00000053 MSFT 0100000D)
[ 0.000000] ACPI: MCFG 7eff7000 0003C (v01 INTEL D525MW 00000053 MSFT 0100000D)
[ 0.000000] ACPI: HPET 7eff6000 00038 (v01 INTEL D525MW 00000053 MSFT 0100000D)
[ 0.000000] ACPI: SSDT 7eff2000 0377C (v01 INTEL D525MW 00000053 MSFT 0100000D)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1144MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00008000 - 0000ef00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000009ec00 - 0000100000] BIOS reserved ==> [000009ec00 - 0000100000]
[ 0.000000] #5 [00008b1000 - 00008b4126] BRK ==> [00008b1000 - 00008b4126]
[ 0.000000] #6 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #7 [00008b5000 - 000153b6b8] NEW RAMDISK ==> [00008b5000 - 000153b6b8]
[ 0.000000] #8 [0000008000 - 000000f000] BOOTMAP ==> [0000008000 - 000000f000]
[ 0.000000] found SMP MP-table at [c00fbe70] fbe70
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007f000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[7] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000008f
[ 0.000000] 0: 0x00000090 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x0007ee98
[ 0.000000] 0: 0x0007eebf -> 0x0007ef47
[ 0.000000] 0: 0x0007efbf -> 0x0007eff1
[ 0.000000] 0: 0x0007efff -> 0x0007f000
[ 0.000000] On node 0 totalpages: 519916
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c153d000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3961 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2289 pages used for memmap
[ 0.000000] HighMem zone: 290404 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:78000000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c2800000 s74936 r0 d23368 u1048576
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u1048576 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515851
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=ad9b2dc2-0618-4859-8426-3f688e05ff9b ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 10403840 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007f000)
[ 0.000000] Memory: 2030180k/2080768k available (4539k kernel code, 48372k reserved, 1928k data, 620k init, 1170772k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:440
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1800.016 MHz processor.
[ 0.004008] Calibrating delay loop (skipped), value calculated using timer frequency.. 3600.03 BogoMIPS (lpj=7200064)
[ 0.004041] Security Framework initialized
[ 0.004082] AppArmor: AppArmor initialized
[ 0.004098] Mount-cache hash table entries: 512
[ 0.004304] Initializing cgroup subsys ns
[ 0.004314] Initializing cgroup subsys cpuacct
[ 0.004323] Initializing cgroup subsys memory
[ 0.004335] Initializing cgroup subsys devices
[ 0.004340] Initializing cgroup subsys freezer
[ 0.004345] Initializing cgroup subsys net_cls
[ 0.004377] CPU: L1 I cache: 32K, L1 D cache: 24K
[ 0.004383] CPU: L2 cache: 512K
[ 0.004388] CPU: Physical Processor ID: 0
[ 0.004392] CPU: Processor Core ID: 0
[ 0.004398] mce: CPU supports 5 MCE banks
[ 0.004410] CPU0: Thermal monitoring enabled (TM1)
[ 0.004423] Performance Events: Atom events, Intel PMU driver.
[ 0.004436] ... version: 3
[ 0.004441] ... bit width: 40
[ 0.004445] ... generic registers: 2
[ 0.004449] ... value mask: 000000ffffffffff
[ 0.004454] ... max period: 000000007fffffff
[ 0.004458] ... fixed-purpose events: 3
[ 0.004462] ... event mask: 0000000700000003
[ 0.004472] Checking 'hlt' instruction... OK.
[ 0.020006] Disabling 4MB page tables to avoid TLB bug
[ 0.020925] ACPI: Core revision 20090903
[ 0.040020] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.040031] ftrace: allocating 21003 entries in 42 pages
[ 0.050130] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.050503] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.052001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.052001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.052001] ..... (found apic 0 pin 2) ...
[ 0.097706] ....... works.
[ 0.097711] CPU0: Intel(R) Atom(TM) CPU D525 @ 1.80GHz stepping 0a
[ 0.100001] Booting processor 1 APIC 0x2 ip 0x6000
[ 0.008000] Initializing CPU#1
[ 0.008000] CPU: L1 I cache: 32K, L1 D cache: 24K
[ 0.008000] CPU: L2 cache: 512K
[ 0.008000] CPU: Physical Processor ID: 0
[ 0.008000] CPU: Processor Core ID: 1
[ 0.008000] CPU1: Thermal monitoring enabled (TM1)
[ 0.184088] CPU1: Intel(R) Atom(TM) CPU D525 @ 1.80GHz stepping 0a
[ 0.184107] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.188025] Brought up 2 CPUs
[ 0.188030] Total of 2 processors activated (7200.38 BogoMIPS).
[ 0.188302] CPU0 attaching sched-domain:
[ 0.188308] domain 0: span 0-1 level CPU
[ 0.188313] groups: 0 1
[ 0.188323] CPU1 attaching sched-domain:
[ 0.188328] domain 0: span 0-1 level CPU
[ 0.188333] groups: 1 0
[ 0.188477] devtmpfs: initialized
[ 0.188477] regulator: core version 0.5
[ 0.188477] NET: Registered protocol family 16
[ 0.188477] Trying to unpack rootfs image as initramfs...
[ 0.188477] EISA bus registered
[ 0.188477] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.188477] ACPI: bus type pci registered
[ 0.188564] PCI: MCFG configuration 0: base f8000000 segment 0 buses 0 - 63
[ 0.188571] PCI: MCFG area at f8000000 reserved in E820
[ 0.188575] PCI: Using MMCONFIG for extended config space
[ 0.188580] PCI: Using configuration type 1 for base access
[ 0.196601] bio: create slab <bio-0> at 0
[ 0.197525] ACPI: EC: Look up EC in DSDT
[ 0.210818] ACPI: BIOS _OSI(Linux) query ignored
[ 0.211857] ACPI: Interpreter enabled
[ 0.211863] ACPI: (supports S0 S5)
[ 0.211884] ACPI: Using IOAPIC for interrupt routing
[ 0.219349] ACPI: No dock devices found.
[ 0.219719] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.219843] pci 0000:00:02.0: reg 10 32bit mmio: [0xe0300000-0xe037ffff]
[ 0.219853] pci 0000:00:02.0: reg 14 io port: [0x30c0-0x30c7]
[ 0.219861] pci 0000:00:02.0: reg 18 32bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.219870] pci 0000:00:02.0: reg 1c 32bit mmio: [0xe0200000-0xe02fffff]
[ 0.220035] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.220043] pci 0000:00:1c.0: PME# disabled
[ 0.220148] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.220156] pci 0000:00:1c.1: PME# disabled
[ 0.220259] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.220267] pci 0000:00:1c.2: PME# disabled
[ 0.220372] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.220380] pci 0000:00:1c.3: PME# disabled
[ 0.220468] pci 0000:00:1d.0: reg 20 io port: [0x3080-0x309f]
[ 0.220561] pci 0000:00:1d.1: reg 20 io port: [0x3060-0x307f]
[ 0.220644] pci 0000:00:1d.2: reg 20 io port: [0x3040-0x305f]
[ 0.220725] pci 0000:00:1d.3: reg 20 io port: [0x3020-0x303f]
[ 0.220807] pci 0000:00:1d.7: reg 10 32bit mmio: [0xe0380400-0xe03807ff]
[ 0.220883] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.220891] pci 0000:00:1d.7: PME# disabled
[ 0.221117] pci 0000:00:1f.2: reg 10 io port: [0x30b8-0x30bf]
[ 0.221128] pci 0000:00:1f.2: reg 14 io port: [0x30cc-0x30cf]
[ 0.221139] pci 0000:00:1f.2: reg 18 io port: [0x30b0-0x30b7]
[ 0.221150] pci 0000:00:1f.2: reg 1c io port: [0x30c8-0x30cb]
[ 0.221162] pci 0000:00:1f.2: reg 20 io port: [0x30a0-0x30af]
[ 0.221173] pci 0000:00:1f.2: reg 24 32bit mmio: [0xe0380000-0xe03803ff]
[ 0.221206] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.221213] pci 0000:00:1f.2: PME# disabled
[ 0.221276] pci 0000:00:1f.3: reg 20 io port: [0x3000-0x301f]
[ 0.221379] pci 0000:01:00.0: reg 10 io port: [0x2000-0x20ff]
[ 0.221410] pci 0000:01:00.0: reg 18 64bit mmio pref: [0xe0004000-0xe0004fff]
[ 0.221434] pci 0000:01:00.0: reg 20 64bit mmio pref: [0xe0000000-0xe0003fff]
[ 0.221505] pci 0000:01:00.0: supports D1 D2
[ 0.221510] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.221520] pci 0000:01:00.0: PME# disabled
[ 0.221613] pci 0000:00:1c.0: bridge io port: [0x2000-0x2fff]
[ 0.221627] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xe0000000-0xe00fffff]
[ 0.221896] pci 0000:05:00.0: reg 10 32bit mmio: [0xe0110000-0xe01100ff]
[ 0.221909] pci 0000:05:00.0: reg 14 io port: [0x1100-0x11ff]
[ 0.221922] pci 0000:05:00.0: reg 18 io port: [0x1000-0x10ff]
[ 0.221935] pci 0000:05:00.0: reg 1c 32bit mmio: [0xe0100000-0xe010ffff]
[ 0.221962] pci 0000:05:00.0: reg 30 32bit mmio pref: [0xffff0000-0xffffffff]
[ 0.222071] pci 0000:00:1e.0: transparent bridge
[ 0.222079] pci 0000:00:1e.0: bridge io port: [0x1000-0x1fff]
[ 0.222087] pci 0000:00:1e.0: bridge 32bit mmio: [0xe0100000-0xe01fffff]
[ 0.222127] pci_bus 0000:00: on NUMA node 0
[ 0.222137] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.222483] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
[ 0.222707] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.222853] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX1._PRT]
[ 0.222997] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
[ 0.223141] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
[ 0.231616] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.231834] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.232070] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
[ 0.232283] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 *10 11 12)
[ 0.232495] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.232705] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.232919] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
[ 0.233133] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 *9 10 11 12)
[ 0.233343] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.233363] vgaarb: loaded
[ 0.233601] SCSI subsystem initialized
[ 0.233791] libata version 3.00 loaded.
[ 0.233951] usbcore: registered new interface driver usbfs
[ 0.233985] usbcore: registered new interface driver hub
[ 0.234044] usbcore: registered new device driver usb
[ 0.234347] ACPI: WMI: Mapper loaded
[ 0.234353] PCI: Using ACPI for IRQ routing
[ 0.234626] NetLabel: Initializing
[ 0.234631] NetLabel: domain hash size = 128
[ 0.234635] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.234658] NetLabel: unlabeled traffic allowed by default
[ 0.234732] Switching to clocksource tsc
[ 0.235329] AppArmor: AppArmor Filesystem Enabled
[ 0.235329] pnp: PnP ACPI init
[ 0.235329] ACPI: bus type pnp registered
[ 0.237945] pnp: PnP ACPI: found 10 devices
[ 0.237951] ACPI: ACPI bus type pnp unregistered
[ 0.237958] PnPBIOS: Disabled by ACPI PNP
[ 0.237980] system 00:01: iomem range 0xf8000000-0xfbffffff has been reserved
[ 0.237987] system 00:01: iomem range 0xfed14000-0xfed17fff has been reserved
[ 0.237994] system 00:01: iomem range 0xfed18000-0xfed18fff has been reserved
[ 0.238001] system 00:01: iomem range 0xfed19000-0xfed19fff has been reserved
[ 0.238008] system 00:01: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.238015] system 00:01: iomem range 0xc0000-0xdffff could not be reserved
[ 0.238022] system 00:01: iomem range 0xe0000-0xfffff could not be reserved
[ 0.238030] system 00:01: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.238045] system 00:06: ioport range 0x500-0x53f has been reserved
[ 0.238052] system 00:06: ioport range 0x400-0x47f has been reserved
[ 0.238058] system 00:06: ioport range 0x680-0x6ff has been reserved
[ 0.238065] system 00:06: ioport range 0x295-0x296 has been reserved
[ 0.272983] pci 0000:05:00.0: BAR 6: address space collision on of device [0xffff0000-0xffffffff]
[ 0.273062] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:01
[ 0.273070] pci 0000:00:1c.0: IO window: 0x2000-0x2fff
[ 0.273079] pci 0000:00:1c.0: MEM window: 0x80000000-0x803fffff
[ 0.273088] pci 0000:00:1c.0: PREFETCH window: 0x000000e0000000-0x000000e00fffff
[ 0.273100] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:02
[ 0.273107] pci 0000:00:1c.1: IO window: 0x4000-0x4fff
[ 0.273117] pci 0000:00:1c.1: MEM window: 0x80400000-0x805fffff
[ 0.273125] pci 0000:00:1c.1: PREFETCH window: 0x00000080600000-0x000000807fffff
[ 0.273138] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:03
[ 0.273145] pci 0000:00:1c.2: IO window: 0x5000-0x5fff
[ 0.273154] pci 0000:00:1c.2: MEM window: 0x80800000-0x809fffff
[ 0.273162] pci 0000:00:1c.2: PREFETCH window: 0x00000080a00000-0x00000080bfffff
[ 0.273174] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:04
[ 0.273181] pci 0000:00:1c.3: IO window: 0x6000-0x6fff
[ 0.273191] pci 0000:00:1c.3: MEM window: 0x80c00000-0x80dfffff
[ 0.273199] pci 0000:00:1c.3: PREFETCH window: 0x00000080e00000-0x00000080ffffff
[ 0.273213] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:05
[ 0.273219] pci 0000:00:1e.0: IO window: 0x1000-0x1fff
[ 0.273229] pci 0000:00:1e.0: MEM window: 0xe0100000-0xe01fffff
[ 0.273238] pci 0000:00:1e.0: PREFETCH window: 0x81000000-0x810fffff
[ 0.273263] alloc irq_desc for 17 on node -1
[ 0.273268] alloc kstat_irqs on node -1
[ 0.273279] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.273288] pci 0000:00:1c.0: setting latency timer to 64
[ 0.273303] pci 0000:00:1c.1: enabling device (0000 -> 0003)
[ 0.273310] alloc irq_desc for 16 on node -1
[ 0.273314] alloc kstat_irqs on node -1
[ 0.273323] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 0.273333] pci 0000:00:1c.1: setting latency timer to 64
[ 0.273346] pci 0000:00:1c.2: enabling device (0000 -> 0003)
[ 0.273353] alloc irq_desc for 18 on node -1
[ 0.273357] alloc kstat_irqs on node -1
[ 0.273365] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.273375] pci 0000:00:1c.2: setting latency timer to 64
[ 0.273389] pci 0000:00:1c.3: enabling device (0000 -> 0003)
[ 0.273403] alloc irq_desc for 19 on node -1
[ 0.273408] alloc kstat_irqs on node -1
[ 0.273416] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.273426] pci 0000:00:1c.3: setting latency timer to 64
[ 0.273438] pci 0000:00:1e.0: setting latency timer to 64
[ 0.273447] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.273453] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.273459] pci_bus 0000:01: resource 0 io: [0x2000-0x2fff]
[ 0.273465] pci_bus 0000:01: resource 1 mem: [0x80000000-0x803fffff]
[ 0.273471] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe00fffff]
[ 0.273477] pci_bus 0000:02: resource 0 io: [0x4000-0x4fff]
[ 0.273482] pci_bus 0000:02: resource 1 mem: [0x80400000-0x805fffff]
[ 0.273488] pci_bus 0000:02: resource 2 pref mem [0x80600000-0x807fffff]
[ 0.273494] pci_bus 0000:03: resource 0 io: [0x5000-0x5fff]
[ 0.273500] pci_bus 0000:03: resource 1 mem: [0x80800000-0x809fffff]
[ 0.273506] pci_bus 0000:03: resource 2 pref mem [0x80a00000-0x80bfffff]
[ 0.273512] pci_bus 0000:04: resource 0 io: [0x6000-0x6fff]
[ 0.273518] pci_bus 0000:04: resource 1 mem: [0x80c00000-0x80dfffff]
[ 0.273523] pci_bus 0000:04: resource 2 pref mem [0x80e00000-0x80ffffff]
[ 0.273529] pci_bus 0000:05: resource 0 io: [0x1000-0x1fff]
[ 0.273535] pci_bus 0000:05: resource 1 mem: [0xe0100000-0xe01fffff]
[ 0.273541] pci_bus 0000:05: resource 2 pref mem [0x81000000-0x810fffff]
[ 0.273547] pci_bus 0000:05: resource 3 io: [0x00-0xffff]
[ 0.273552] pci_bus 0000:05: resource 4 mem: [0x000000-0xffffffff]
[ 0.273617] NET: Registered protocol family 2
[ 0.273803] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.274389] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.275254] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.275660] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.275667] TCP reno registered
[ 0.275866] NET: Registered protocol family 1
[ 0.275908] pci 0000:00:02.0: Boot video device
[ 0.297189] Scanning for low memory corruption every 60 seconds
[ 0.297378] audit: initializing netlink socket (disabled)
[ 0.297399] type=2000 audit(1341433672.296:1): initialized
[ 0.310581] highmem bounce pool size: 64 pages
[ 0.310592] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.313796] VFS: Disk quotas dquot_6.5.2
[ 0.313914] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.315144] fuse init (API version 7.13)
[ 0.315343] msgmni has been set to 1680
[ 0.315793] alg: No test for stdrng (krng)
[ 0.315928] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.315935] io scheduler noop registered
[ 0.315939] io scheduler anticipatory registered
[ 0.315944] io scheduler deadline registered
[ 0.316034] io scheduler cfq registered (default)
[ 0.316286] alloc irq_desc for 24 on node -1
[ 0.316291] alloc kstat_irqs on node -1
[ 0.316311] pcieport 0000:00:1c.0: irq 24 for MSI/MSI-X
[ 0.316326] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.316536] alloc irq_desc for 25 on node -1
[ 0.316540] alloc kstat_irqs on node -1
[ 0.316555] pcieport 0000:00:1c.1: irq 25 for MSI/MSI-X
[ 0.316569] pcieport 0000:00:1c.1: setting latency timer to 64
[ 0.316799] alloc irq_desc for 26 on node -1
[ 0.316804] alloc kstat_irqs on node -1
[ 0.316818] pcieport 0000:00:1c.2: irq 26 for MSI/MSI-X
[ 0.316833] pcieport 0000:00:1c.2: setting latency timer to 64
[ 0.317046] alloc irq_desc for 27 on node -1
[ 0.317051] alloc kstat_irqs on node -1
[ 0.317065] pcieport 0000:00:1c.3: irq 27 for MSI/MSI-X
[ 0.317079] pcieport 0000:00:1c.3: setting latency timer to 64
[ 0.317240] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.317447] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.317582] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.317598] ACPI: Sleep Button [SLPB]
[ 0.317710] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.317716] ACPI: Power Button [PWRF]
[ 0.320776] hpet_acpi_add: no address or irqs in _CRS
[ 0.320869] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.323432] brd: module loaded
[ 0.324474] loop: module loaded
[ 0.324663] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.324872] ata_piix 0000:00:1f.2: version 2.13
[ 0.324905] ata_piix 0000:00:1f.2: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.324914] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 0.325062] isapnp: Scanning for PnP cards...
[ 0.504572] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 0.548190] scsi0 : ata_piix
[ 0.548366] scsi1 : ata_piix
[ 0.548724] ata1: SATA max UDMA/133 cmd 0x30b8 ctl 0x30cc bmdma 0x30a0 irq 18
[ 0.548731] ata2: SATA max UDMA/133 cmd 0x30b0 ctl 0x30c8 bmdma 0x30a8 irq 18
[ 0.549467] Fixed MDIO Bus: probed
[ 0.549540] PPP generic driver version 2.4.2
[ 0.549635] tun: Universal TUN/TAP device driver, 1.6
[ 0.549640] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.549824] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.549863] alloc irq_desc for 23 on node -1
[ 0.549868] alloc kstat_irqs on node -1
[ 0.549880] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.549905] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.549912] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.549980] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.550016] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 0.550033] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.553925] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.554014] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xe0380400
[ 0.601428] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.601607] usb usb1: configuration #1 chosen from 1 choice
[ 0.601675] hub 1-0:1.0: USB hub found
[ 0.601691] hub 1-0:1.0: 8 ports detected
[ 0.601818] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.601849] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.601909] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.601922] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.601930] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.602002] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.602037] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00003080
[ 0.602224] usb usb2: configuration #1 chosen from 1 choice
[ 0.602281] hub 2-0:1.0: USB hub found
[ 0.602296] hub 2-0:1.0: 2 ports detected
[ 0.602381] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.602393] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.602399] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.602475] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.602521] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00003060
[ 0.602700] usb usb3: configuration #1 chosen from 1 choice
[ 0.602756] hub 3-0:1.0: USB hub found
[ 0.602770] hub 3-0:1.0: 2 ports detected
[ 0.602854] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.602866] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.602872] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.602939] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.602972] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00003040
[ 0.603159] usb usb4: configuration #1 chosen from 1 choice
[ 0.603216] hub 4-0:1.0: USB hub found
[ 0.603230] hub 4-0:1.0: 2 ports detected
[ 0.603312] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16
[ 0.603323] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 0.603330] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.603410] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.603459] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00003020
[ 0.603643] usb usb5: configuration #1 chosen from 1 choice
[ 0.603699] hub 5-0:1.0: USB hub found
[ 0.603713] hub 5-0:1.0: 2 ports detected
[ 0.603891] PNP: No PS/2 controller found. Probing ports directly.
[ 0.638340] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.638360] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.638590] mice: PS/2 mouse device common for all mice
[ 0.638804] rtc_cmos 00:03: RTC can wake from S4
[ 0.638880] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.638919] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.639155] device-mapper: uevent: version 1.0.3
[ 0.661600] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.692861] isapnp: No Plug & Play device found
[ 0.693016] device-mapper: multipath: version 1.1.0 loaded
[ 0.693023] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.693304] EISA: Probing bus 0 at eisa.0
[ 0.693314] Cannot allocate resource for EISA slot 1
[ 0.693319] Cannot allocate resource for EISA slot 2
[ 0.693324] Cannot allocate resource for EISA slot 3
[ 0.693329] Cannot allocate resource for EISA slot 4
[ 0.693334] Cannot allocate resource for EISA slot 5
[ 0.693339] Cannot allocate resource for EISA slot 6
[ 0.693351] EISA: Detected 0 cards.
[ 0.693356] cpuidle: using governor ladder
[ 0.693361] cpuidle: using governor menu
[ 0.694208] TCP cubic registered
[ 0.694543] NET: Registered protocol family 10
[ 0.695380] lo: Disabled Privacy Extensions
[ 0.695979] NET: Registered protocol family 17
[ 0.696039] Using IPI No-Shortcut mode
[ 0.696229] registered taskstats version 1
[ 0.696810] rtc_cmos 00:03: setting system clock to 2012-07-04 20:27:53 UTC (1341433673)
[ 0.696818] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.696822] EDD information not available.
[ 0.730352] Freeing initrd memory: 12825k freed
[ 0.781494] ata1.00: ATA-8: Corsair Nova 2 SSD, 5.02, max UDMA/133
[ 0.781501] ata1.00: 58626288 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 0.804953] ata2.01: NODEV after polling detection
[ 0.813383] ata2.00: ATAPI: ATAPI iHAS124 B, AL0Q, max UDMA/100
[ 0.813776] ata1.00: configured for UDMA/133
[ 0.814024] scsi 0:0:0:0: Direct-Access ATA Corsair Nova 2 S 5.02 PQ: 0 ANSI: 5
[ 0.814323] sd 0:0:0:0: [sda] 58626288 512-byte logical blocks: (30.0 GB/27.9 GiB)
[ 0.814336] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.814467] sd 0:0:0:0: [sda] Write Protect is off
[ 0.814474] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.814540] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.814887] sda: sda1 sda2 < sda5 >
[ 0.816005] sd 0:0:0:0: [sda] Attached SCSI disk
[ 0.829137] ata2.00: configured for UDMA/100
[ 0.831138] scsi 1:0:0:0: CD-ROM ATAPI iHAS124 B AL0Q PQ: 0 ANSI: 5
[ 0.837460] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 0.837467] Uniform CD-ROM driver Revision: 3.20
[ 0.837657] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.837771] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 0.837872] Freeing unused kernel memory: 620k freed
[ 0.838262] Write protecting the kernel text: 4540k
[ 0.838309] Write protecting the kernel read-only data: 1668k
[ 0.875535] udev: starting version 151
[ 0.912878] usb 1-4: new high speed USB device using ehci_hcd and address 2
[ 1.049905] usb 1-4: configuration #1 chosen from 1 choice
[ 1.050947] hub 1-4:1.0: USB hub found
[ 1.051162] hub 1-4:1.0: 4 ports detected
[ 1.095863] Linux agpgart interface v0.103
[ 1.102146] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.102180] r8169 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.102245] r8169 0000:01:00.0: setting latency timer to 64
[ 1.102255] r8169 0000:01:00.0: unknown MAC, using family default
[ 1.102317] alloc irq_desc for 28 on node -1
[ 1.102322] alloc kstat_irqs on node -1
[ 1.102346] r8169 0000:01:00.0: irq 28 for MSI/MSI-X
[ 1.103667] eth0: RTL8168b/8111b at 0xf8088000, e8:40:f2:3d:cd:54, XID 0c200000 IRQ 28
[ 1.109539] agpgart-intel 0000:00:00.0: Intel IGD Chipset
[ 1.109895] agpgart-intel 0000:00:00.0: detected 8188K stolen memory
[ 1.121986] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 1.158345] [drm] Initialized drm 1.1.0 20060810
[ 1.211862] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.211872] i915 0000:00:02.0: setting latency timer to 64
[ 1.224893] alloc irq_desc for 29 on node -1
[ 1.224900] alloc kstat_irqs on node -1
[ 1.224915] i915 0000:00:02.0: irq 29 for MSI/MSI-X
[ 1.224925] [drm] set up 7M of stolen space
[ 1.225495] [drm] initialized overlay support
[ 1.320611] usb 1-4.4: new high speed USB device using ehci_hcd and address 3
[ 1.386637] fb0: inteldrmfb frame buffer device
[ 1.386643] registered panic notifier
[ 1.386816] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 1.390814] vga16fb: initializing
[ 1.390821] vga16fb: mapped to 0xc00a0000
[ 1.390828] vga16fb: not registering due to another framebuffer present
[ 1.403959] [drm] Big FIFO is enabled
[ 1.412880] usb 1-4.4: configuration #1 chosen from 1 choice
[ 1.413034] hub 1-4.4:1.0: USB hub found
[ 1.413377] hub 1-4.4:1.0: 4 ports detected
[ 1.476025] [drm] Big FIFO is enabled
[ 1.476039] [drm] Big FIFO is enabled
[ 1.476097] [drm] Big FIFO is enabled
[ 1.504510] Console: switching to colour frame buffer device 128x48
[ 1.688131] usb 1-4.4.4: new high speed USB device using ehci_hcd and address 4
[ 1.705196] [drm] Big FIFO is enabled
[ 1.728221] [drm] Big FIFO is enabled
[ 1.801389] usb 1-4.4.4: configuration #1 chosen from 1 choice
[ 1.801986] hub 1-4.4.4:1.0: USB hub found
[ 1.802106] hub 1-4.4.4:1.0: 4 ports detected
[ 2.040506] xor: automatically using best checksumming function: pIII_sse
[ 2.060011] pIII_sse : 5576.000 MB/sec
[ 2.060016] xor: using function: pIII_sse (5576.000 MB/sec)
[ 2.067078] device-mapper: dm-raid45: initialized v0.2594b
[ 2.122554] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 2.132312] usb 1-4.4.4.1: new low speed USB device using ehci_hcd and address 5
[ 2.231049] usb 1-4.4.4.1: configuration #1 chosen from 1 choice
[ 2.304248] usb 1-4.4.4.3: new low speed USB device using ehci_hcd and address 6
[ 2.415436] usb 1-4.4.4.3: configuration #1 chosen from 1 choice
[ 2.506247] Adding 1254392k swap on /dev/sda5. Priority:-1 extents:1 across:1254392k SS
[ 2.572795] udev: starting version 151
[ 2.812252] usb 1-4.4.4.2: new low speed USB device using ehci_hcd and address 7
[ 2.838890] lp: driver loaded but no devices found
[ 2.908388] usb 1-4.4.4.2: configuration #1 chosen from 1 choice
[ 3.077000] input: General Touch Co. Ltd. GeneralTouch USB Touchscreen as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4.1/1-4.4.4.1:1.0/input/input3
[ 3.077274] usbcore: registered new interface driver usbtouchscreen
[ 3.185207] usbcore: registered new interface driver hiddev
[ 3.195294] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4.3/1-4.4.4.3:1.0/input/input4
[ 3.195557] generic-usb 0003:04D9:1503.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.7-4.4.4.3/input0
[ 3.207815] type=1505 audit(1341433676.007:2): operation="profile_load" pid=545 name="/sbin/dhclient3"
[ 3.208320] type=1505 audit(1341433676.011:3): operation="profile_load" pid=545 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 3.212897] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4.3/1-4.4.4.3:1.1/input/input5
[ 3.213130] generic-usb 0003:04D9:1503.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.7-4.4.4.3/input1
[ 3.215370] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4.2/1-4.4.4.2:1.0/input/input6
[ 3.215610] generic-usb 0003:192F:0916.0003: input,hidraw2: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1d.7-4.4.4.2/input0
[ 3.215664] usbcore: registered new interface driver usbhid
[ 3.215671] usbhid: v2.6:USB HID core driver
[ 3.222531] type=1505 audit(1341433676.023:4): operation="profile_load" pid=545 name="/usr/lib/connman/scripts/dhclient-script"
[ 3.526213] type=1505 audit(1341433676.327:5): operation="profile_load" pid=678 name="/usr/share/gdm/guest-session/Xsession"
[ 3.534900] type=1505 audit(1341433676.335:6): operation="profile_replace" pid=679 name="/sbin/dhclient3"
[ 3.535445] type=1505 audit(1341433676.335:7): operation="profile_replace" pid=679 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 3.535749] type=1505 audit(1341433676.335:8): operation="profile_replace" pid=679 name="/usr/lib/connman/scripts/dhclient-script"
[ 3.586811] type=1505 audit(1341433676.387:9): operation="profile_load" pid=691 name="/usr/lib/cups/backend/cups-pdf"
[ 3.587471] type=1505 audit(1341433676.387:10): operation="profile_load" pid=691 name="/usr/sbin/cupsd"
[ 3.662001] r8169: eth0: link up
[ 3.662015] r8169: eth0: link up
[ 3.987633] ppdev: user-space parallel port driver
[ 4.485602] CPU0 attaching NULL sched-domain.
[ 4.485614] CPU1 attaching NULL sched-domain.
[ 4.508593] CPU0 attaching sched-domain:
[ 4.508600] domain 0: span 0-1 level CPU
[ 4.508606] groups: 0 1
[ 4.508617] CPU1 attaching sched-domain:
[ 4.508622] domain 0: span 0-1 level CPU
[ 4.508627] groups: 1 0
[ 4.508958] CPU0 attaching NULL sched-domain.
[ 4.508965] CPU1 attaching NULL sched-domain.
[ 4.536101] CPU0 attaching sched-domain:
[ 4.536109] domain 0: span 0-1 level CPU
[ 4.536115] groups: 0 1
[ 4.536127] CPU1 attaching sched-domain:
[ 4.536131] domain 0: span 0-1 level CPU
[ 4.536136] groups: 1 0
[ 7.093764] CPU0 attaching NULL sched-domain.
[ 7.093776] CPU1 attaching NULL sched-domain.
[ 7.116668] CPU0 attaching sched-domain:
[ 7.116676] domain 0: span 0-1 level CPU
[ 7.116683] groups: 0 1
[ 7.116694] CPU1 attaching sched-domain:
[ 7.116699] domain 0: span 0-1 level CPU
[ 7.116704] groups: 1 0
[ 7.117037] CPU0 attaching NULL sched-domain.
[ 7.117044] CPU1 attaching NULL sched-domain.
[ 7.144739] CPU0 attaching sched-domain:
[ 7.144748] domain 0: span 0-1 level CPU
[ 7.144754] groups: 0 1
[ 7.144766] CPU1 attaching sched-domain:
[ 7.144771] domain 0: span 0-1 level CPU
[ 7.144776] groups: 1 0
[ 14.260512] eth0: no IPv6 routers present
[ 23.814140] I-pipe: Domain RTAI registered.
[ 23.814154] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 23.814160] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 23.814240] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 23.814245] PIPELINE layers:
[ 23.814251] f8a21e20 9ac15d93 RTAI 200
[ 23.814256] c085cb20 0 Linux 100
[ 23.858129] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 23.858929] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 23.858942] RTAI[sched]: hard timer type/freq = APIC/12500368(Hz); default timing: periodic; linear timed lists.
[ 23.858950] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800016000 hz.
[ 23.858956] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 23.859091] RTAI[usi]: enabled.
[ 23.948694] RTAI[math]: loaded.
[ 24.083733] hm2: loading Mesa HostMot2 driver version 0.15
[ 24.089703] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 24.089771] alloc irq_desc for 20 on node -1
[ 24.089776] alloc kstat_irqs on node -1
[ 24.089791] hm2_pci 0000:05:00.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 24.089798] hm2_pci: discovered 5i23 at 0000:05:00.0
[ 24.089889] hm2_5i23.0: firmware: requesting hm2/5i23/SVSS8_8.BIT
[ 24.309455] hm2/hm2_5i23.0: Smart Serial Firmware Version 23
[ 24.362353] hm2/hm2_5i23.0: Unsupported Device 7I704.4 found on sserial 0 channel 2
[ 24.423527] hm2/hm2_5i23.0: 72 I/O Pins used:
[ 24.423536] hm2/hm2_5i23.0: IO Pin 000 (P2-01): Encoder #1, pin B (Input)
[ 24.423543] hm2/hm2_5i23.0: IO Pin 001 (P2-03): Encoder #1, pin A (Input)
[ 24.423550] hm2/hm2_5i23.0: IO Pin 002 (P2-05): Encoder #0, pin B (Input)
[ 24.423557] hm2/hm2_5i23.0: IO Pin 003 (P2-07): Encoder #0, pin A (Input)
[ 24.423563] hm2/hm2_5i23.0: IO Pin 004 (P2-09): Encoder #1, pin Index (Input)
[ 24.423570] hm2/hm2_5i23.0: IO Pin 005 (P2-11): Encoder #0, pin Index (Input)
[ 24.423578] hm2/hm2_5i23.0: IO Pin 006 (P2-13): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 24.423585] hm2/hm2_5i23.0: IO Pin 007 (P2-15): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 24.423593] hm2/hm2_5i23.0: IO Pin 008 (P2-17): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 24.423600] hm2/hm2_5i23.0: IO Pin 009 (P2-19): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 24.423608] hm2/hm2_5i23.0: IO Pin 010 (P2-21): PWMGen #1, pin Not-Enable (Output)
[ 24.423615] hm2/hm2_5i23.0: IO Pin 011 (P2-23): PWMGen #0, pin Not-Enable (Output)
[ 24.423622] hm2/hm2_5i23.0: IO Pin 012 (P2-25): Encoder #3, pin B (Input)
[ 24.423629] hm2/hm2_5i23.0: IO Pin 013 (P2-27): Encoder #3, pin A (Input)
[ 24.423636] hm2/hm2_5i23.0: IO Pin 014 (P2-29): Encoder #2, pin B (Input)
[ 24.423643] hm2/hm2_5i23.0: IO Pin 015 (P2-31): Encoder #2, pin A (Input)
[ 24.423650] hm2/hm2_5i23.0: IO Pin 016 (P2-33): Encoder #3, pin Index (Input)
[ 24.423657] hm2/hm2_5i23.0: IO Pin 017 (P2-35): Encoder #2, pin Index (Input)
[ 24.423663] hm2/hm2_5i23.0: IO Pin 018 (P2-37): IOPort
[ 24.423670] hm2/hm2_5i23.0: IO Pin 019 (P2-39): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 24.423676] hm2/hm2_5i23.0: IO Pin 020 (P2-41): IOPort
[ 24.423683] hm2/hm2_5i23.0: IO Pin 021 (P2-43): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 24.423690] hm2/hm2_5i23.0: IO Pin 022 (P2-45): IOPort
[ 24.423696] hm2/hm2_5i23.0: IO Pin 023 (P2-47): PWMGen #2, pin Not-Enable (Output)
[ 24.423702] hm2/hm2_5i23.0: IO Pin 024 (P3-01): IOPort
[ 24.423708] hm2/hm2_5i23.0: IO Pin 025 (P3-03): IOPort
[ 24.423714] hm2/hm2_5i23.0: IO Pin 026 (P3-05): IOPort
[ 24.423719] hm2/hm2_5i23.0: IO Pin 027 (P3-07): IOPort
[ 24.423725] hm2/hm2_5i23.0: IO Pin 028 (P3-09): IOPort
[ 24.423731] hm2/hm2_5i23.0: IO Pin 029 (P3-11): IOPort
[ 24.423736] hm2/hm2_5i23.0: IO Pin 030 (P3-13): IOPort
[ 24.423742] hm2/hm2_5i23.0: IO Pin 031 (P3-15): IOPort
[ 24.423748] hm2/hm2_5i23.0: IO Pin 032 (P3-17): IOPort
[ 24.423753] hm2/hm2_5i23.0: IO Pin 033 (P3-19): IOPort
[ 24.423759] hm2/hm2_5i23.0: IO Pin 034 (P3-21): IOPort
[ 24.423765] hm2/hm2_5i23.0: IO Pin 035 (P3-23): IOPort
[ 24.423770] hm2/hm2_5i23.0: IO Pin 036 (P3-25): IOPort
[ 24.423776] hm2/hm2_5i23.0: IO Pin 037 (P3-27): IOPort
[ 24.423782] hm2/hm2_5i23.0: IO Pin 038 (P3-29): IOPort
[ 24.423787] hm2/hm2_5i23.0: IO Pin 039 (P3-31): IOPort
[ 24.423793] hm2/hm2_5i23.0: IO Pin 040 (P3-33): IOPort
[ 24.423799] hm2/hm2_5i23.0: IO Pin 041 (P3-35): IOPort
[ 24.423804] hm2/hm2_5i23.0: IO Pin 042 (P3-37): IOPort
[ 24.423810] hm2/hm2_5i23.0: IO Pin 043 (P3-39): IOPort
[ 24.423816] hm2/hm2_5i23.0: IO Pin 044 (P3-41): IOPort
[ 24.423821] hm2/hm2_5i23.0: IO Pin 045 (P3-43): IOPort
[ 24.423827] hm2/hm2_5i23.0: IO Pin 046 (P3-45): IOPort
[ 24.423833] hm2/hm2_5i23.0: IO Pin 047 (P3-47): IOPort
[ 24.423840] hm2/hm2_5i23.0: IO Pin 048 (P4-01): Smart Serial Interface #0, pin RxData0 (Input)
[ 24.423847] hm2/hm2_5i23.0: IO Pin 049 (P4-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 24.423855] hm2/hm2_5i23.0: IO Pin 050 (P4-05): Smart Serial Interface #0, pin RxData2 (Input)
[ 24.423862] hm2/hm2_5i23.0: IO Pin 051 (P4-07): IOPort
[ 24.423869] hm2/hm2_5i23.0: IO Pin 052 (P4-09): Smart Serial Interface #0, pin TxData0 (Output)
[ 24.423876] hm2/hm2_5i23.0: IO Pin 053 (P4-11): Smart Serial Interface #0, pin TxEn0 (Output)
[ 24.423884] hm2/hm2_5i23.0: IO Pin 054 (P4-13): Smart Serial Interface #0, pin TxData1 (Output)
[ 24.423892] hm2/hm2_5i23.0: IO Pin 055 (P4-15): Smart Serial Interface #0, pin TxEn1 (Output)
[ 24.423900] hm2/hm2_5i23.0: IO Pin 056 (P4-17): Smart Serial Interface #0, pin TxData2 (Output)
[ 24.423907] hm2/hm2_5i23.0: IO Pin 057 (P4-19): Smart Serial Interface #0, pin TxEn2 (Output)
[ 24.423914] hm2/hm2_5i23.0: IO Pin 058 (P4-21): IOPort
[ 24.423920] hm2/hm2_5i23.0: IO Pin 059 (P4-23): IOPort
[ 24.423925] hm2/hm2_5i23.0: IO Pin 060 (P4-25): IOPort
[ 24.423931] hm2/hm2_5i23.0: IO Pin 061 (P4-27): IOPort
[ 24.423937] hm2/hm2_5i23.0: IO Pin 062 (P4-29): IOPort
[ 24.423942] hm2/hm2_5i23.0: IO Pin 063 (P4-31): IOPort
[ 24.423948] hm2/hm2_5i23.0: IO Pin 064 (P4-33): IOPort
[ 24.423954] hm2/hm2_5i23.0: IO Pin 065 (P4-35): IOPort
[ 24.423959] hm2/hm2_5i23.0: IO Pin 066 (P4-37): IOPort
[ 24.423965] hm2/hm2_5i23.0: IO Pin 067 (P4-39): IOPort
[ 24.423971] hm2/hm2_5i23.0: IO Pin 068 (P4-41): IOPort
[ 24.423976] hm2/hm2_5i23.0: IO Pin 069 (P4-43): IOPort
[ 24.423984] hm2/hm2_5i23.0: IO Pin 070 (P4-45): IOPort
[ 24.423989] hm2/hm2_5i23.0: IO Pin 071 (P4-47): IOPort
[ 24.424245] hm2/hm2_5i23.0: registered
[ 24.424250] hm2_5i23.0: initialized AnyIO board at 0000:05:00.0
[ 24.457002] classicladder_rt: module license 'LGPL' taints kernel.
[ 24.457010] Disabling lock debugging due to kernel taint
[ 24.460470] creating ladder-state
[ 87.776656] hm2_5i23.0: dropping AnyIO board at 0000:05:00.0
[ 87.776668] hm2/hm2_5i23.0: unregistered
[ 87.776705] hm2_pci 0000:05:00.0: PCI INT A disabled
[ 87.776846] hm2_pci: driver unloaded
[ 87.781878] hm2: unloading
[ 87.854381] RTAI[math]: unloaded.
[ 87.916591] SCHED releases registered named ALIEN RTGLBH
[ 87.948552] RTAI[malloc]: unloaded.
[ 88.048530] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 88.053432] I-pipe: Domain RTAI unregistered.
[ 88.053525] RTAI[hal]: unmounted.
[ 90.949135] I-pipe: Domain RTAI registered.
[ 90.949149] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 90.949154] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 90.949234] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 90.949239] PIPELINE layers:
[ 90.949244] f9126e20 9ac15d93 RTAI 200
[ 90.949249] c085cb20 0 Linux 100
[ 90.993237] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 90.993640] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 90.993653] RTAI[sched]: hard timer type/freq = APIC/12500368(Hz); default timing: periodic; linear timed lists.
[ 90.993661] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800016000 hz.
[ 90.993666] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 90.993793] RTAI[usi]: enabled.
[ 91.084645] RTAI[math]: loaded.
[ 119.834484] hm2: loading Mesa HostMot2 driver version 0.15
[ 190.333080] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 190.333090] HAL: initializing component 'hm2_pci'
[ 190.333096] RTAPI: initing module HAL_hm2_pci
[ 190.333102] RTAPI: module 'HAL_hm2_pci' loaded, ID: 5
[ 190.333110] HAL: component 'hm2_pci' initialized, ID = 05
[ 190.333167] hm2_pci 0000:05:00.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 190.333174] hm2_pci: discovered 5i23 at 0000:05:00.0
[ 190.333248] hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
[ 190.333506] HAL: creating parameter 'hm2_5i23.0.io_error'
[ 190.333704] hm2/hm2_5i23.0: MD 1: 3x IOPort v0: accepted, using 3
[ 190.333713] HAL: creating pin 'hm2_5i23.0.watchdog.has_bit'
[ 190.333720] HAL: creating parameter 'hm2_5i23.0.watchdog.timeout_ns'
[ 190.333727] HAL: exporting function 'hm2_5i23.0.pet_watchdog'
[ 190.333734] HAL: creating parameter 'hm2_5i23.0.pet_watchdog.time'
[ 190.333740] HAL: creating parameter 'hm2_5i23.0.pet_watchdog.tmax'
[ 190.333748] hm2/hm2_5i23.0: MD 0: 1x Watchdog v0: accepted, using 1
[ 190.333754] hm2/hm2_5i23.0: MD 1: 3x IOPort v0: ignored
[ 190.333762] HAL: creating pin 'hm2_5i23.0.encoder.00.rawcounts'
[ 190.333768] HAL: creating pin 'hm2_5i23.0.encoder.00.rawlatch'
[ 190.333775] HAL: creating pin 'hm2_5i23.0.encoder.00.count'
[ 190.333782] HAL: creating pin 'hm2_5i23.0.encoder.00.count-latched'
[ 190.333789] HAL: creating pin 'hm2_5i23.0.encoder.00.position'
[ 190.333796] HAL: creating pin 'hm2_5i23.0.encoder.00.position-latched'
[ 190.333804] HAL: creating pin 'hm2_5i23.0.encoder.00.velocity'
[ 190.333812] HAL: creating pin 'hm2_5i23.0.encoder.00.reset'
[ 190.333820] HAL: creating pin 'hm2_5i23.0.encoder.00.index-enable'
[ 190.333827] HAL: creating pin 'hm2_5i23.0.encoder.00.latch-enable'
[ 190.333835] HAL: creating pin 'hm2_5i23.0.encoder.00.latch-polarity'
[ 190.333843] HAL: creating parameter 'hm2_5i23.0.encoder.00.scale'
[ 190.333849] HAL: creating parameter 'hm2_5i23.0.encoder.00.index-invert'
[ 190.333856] HAL: creating parameter 'hm2_5i23.0.encoder.00.index-mask'
[ 190.333864] HAL: creating parameter 'hm2_5i23.0.encoder.00.index-mask-invert'
[ 190.333872] HAL: creating parameter 'hm2_5i23.0.encoder.00.counter-mode'
[ 190.333879] HAL: creating parameter 'hm2_5i23.0.encoder.00.filter'
[ 190.333886] HAL: creating parameter 'hm2_5i23.0.encoder.00.vel-timeout'
[ 190.333894] HAL: creating pin 'hm2_5i23.0.encoder.01.rawcounts'
[ 190.333903] HAL: creating pin 'hm2_5i23.0.encoder.01.rawlatch'
[ 190.333912] HAL: creating pin 'hm2_5i23.0.encoder.01.count'
[ 190.333920] HAL: creating pin 'hm2_5i23.0.encoder.01.count-latched'
[ 190.333930] HAL: creating pin 'hm2_5i23.0.encoder.01.position'
[ 190.333939] HAL: creating pin 'hm2_5i23.0.encoder.01.position-latched'
[ 190.333949] HAL: creating pin 'hm2_5i23.0.encoder.01.velocity'
[ 190.333959] HAL: creating pin 'hm2_5i23.0.encoder.01.reset'
[ 190.333969] HAL: creating pin 'hm2_5i23.0.encoder.01.index-enable'
[ 190.333978] HAL: creating pin 'hm2_5i23.0.encoder.01.latch-enable'
[ 190.333988] HAL: creating pin 'hm2_5i23.0.encoder.01.latch-polarity'
[ 190.333998] HAL: creating parameter 'hm2_5i23.0.encoder.01.scale'
[ 190.334006] HAL: creating parameter 'hm2_5i23.0.encoder.01.index-invert'
[ 190.334014] HAL: creating parameter 'hm2_5i23.0.encoder.01.index-mask'
[ 190.334023] HAL: creating parameter 'hm2_5i23.0.encoder.01.index-mask-invert'
[ 190.334032] HAL: creating parameter 'hm2_5i23.0.encoder.01.counter-mode'
[ 190.334041] HAL: creating parameter 'hm2_5i23.0.encoder.01.filter'
[ 190.334049] HAL: creating parameter 'hm2_5i23.0.encoder.01.vel-timeout'
[ 190.334059] HAL: creating pin 'hm2_5i23.0.encoder.02.rawcounts'
[ 190.334069] HAL: creating pin 'hm2_5i23.0.encoder.02.rawlatch'
[ 190.334080] HAL: creating pin 'hm2_5i23.0.encoder.02.count'
[ 190.334091] HAL: creating pin 'hm2_5i23.0.encoder.02.count-latched'
[ 190.334103] HAL: creating pin 'hm2_5i23.0.encoder.02.position'
[ 190.334114] HAL: creating pin 'hm2_5i23.0.encoder.02.position-latched'
[ 190.334126] HAL: creating pin 'hm2_5i23.0.encoder.02.velocity'
[ 190.334138] HAL: creating pin 'hm2_5i23.0.encoder.02.reset'
[ 190.334150] HAL: creating pin 'hm2_5i23.0.encoder.02.index-enable'
[ 190.334162] HAL: creating pin 'hm2_5i23.0.encoder.02.latch-enable'
[ 190.334174] HAL: creating pin 'hm2_5i23.0.encoder.02.latch-polarity'
[ 190.334186] HAL: creating parameter 'hm2_5i23.0.encoder.02.scale'
[ 190.334195] HAL: creating parameter 'hm2_5i23.0.encoder.02.index-invert'
[ 190.334205] HAL: creating parameter 'hm2_5i23.0.encoder.02.index-mask'
[ 190.334215] HAL: creating parameter 'hm2_5i23.0.encoder.02.index-mask-invert'
[ 190.334225] HAL: creating parameter 'hm2_5i23.0.encoder.02.counter-mode'
[ 190.334235] HAL: creating parameter 'hm2_5i23.0.encoder.02.filter'
[ 190.334245] HAL: creating parameter 'hm2_5i23.0.encoder.02.vel-timeout'
[ 190.334256] HAL: creating pin 'hm2_5i23.0.encoder.03.rawcounts'
[ 190.334269] HAL: creating pin 'hm2_5i23.0.encoder.03.rawlatch'
[ 190.334282] HAL: creating pin 'hm2_5i23.0.encoder.03.count'
[ 190.334295] HAL: creating pin 'hm2_5i23.0.encoder.03.count-latched'
[ 190.334308] HAL: creating pin 'hm2_5i23.0.encoder.03.position'
[ 190.334322] HAL: creating pin 'hm2_5i23.0.encoder.03.position-latched'
[ 190.334335] HAL: creating pin 'hm2_5i23.0.encoder.03.velocity'
[ 190.334349] HAL: creating pin 'hm2_5i23.0.encoder.03.reset'
[ 190.334364] HAL: creating pin 'hm2_5i23.0.encoder.03.index-enable'
[ 190.334377] HAL: creating pin 'hm2_5i23.0.encoder.03.latch-enable'
[ 190.334391] HAL: creating pin 'hm2_5i23.0.encoder.03.latch-polarity'
[ 190.334405] HAL: creating parameter 'hm2_5i23.0.encoder.03.scale'
[ 190.334416] HAL: creating parameter 'hm2_5i23.0.encoder.03.index-invert'
[ 190.334427] HAL: creating parameter 'hm2_5i23.0.encoder.03.index-mask'
[ 190.334438] HAL: creating parameter 'hm2_5i23.0.encoder.03.index-mask-invert'
[ 190.334450] HAL: creating parameter 'hm2_5i23.0.encoder.03.counter-mode'
[ 190.334461] HAL: creating parameter 'hm2_5i23.0.encoder.03.filter'
[ 190.334472] HAL: creating parameter 'hm2_5i23.0.encoder.03.vel-timeout'
[ 190.334484] HAL: creating pin 'hm2_5i23.0.encoder.04.rawcounts'
[ 190.334499] HAL: creating pin 'hm2_5i23.0.encoder.04.rawlatch'
[ 190.334515] HAL: creating pin 'hm2_5i23.0.encoder.04.count'
[ 190.334530] HAL: creating pin 'hm2_5i23.0.encoder.04.count-latched'
[ 190.334545] HAL: creating pin 'hm2_5i23.0.encoder.04.position'
[ 190.334561] HAL: creating pin 'hm2_5i23.0.encoder.04.position-latched'
[ 190.334577] HAL: creating pin 'hm2_5i23.0.encoder.04.velocity'
[ 190.334593] HAL: creating pin 'hm2_5i23.0.encoder.04.reset'
[ 190.334609] HAL: creating pin 'hm2_5i23.0.encoder.04.index-enable'
[ 190.334625] HAL: creating pin 'hm2_5i23.0.encoder.04.latch-enable'
[ 190.334641] HAL: creating pin 'hm2_5i23.0.encoder.04.latch-polarity'
[ 190.334657] HAL: creating parameter 'hm2_5i23.0.encoder.04.scale'
[ 190.334669] HAL: creating parameter 'hm2_5i23.0.encoder.04.index-invert'
[ 190.334682] HAL: creating parameter 'hm2_5i23.0.encoder.04.index-mask'
[ 190.334695] HAL: creating parameter 'hm2_5i23.0.encoder.04.index-mask-invert'
[ 190.334708] HAL: creating parameter 'hm2_5i23.0.encoder.04.counter-mode'
[ 190.334720] HAL: creating parameter 'hm2_5i23.0.encoder.04.filter'
[ 190.334732] HAL: creating parameter 'hm2_5i23.0.encoder.04.vel-timeout'
[ 190.334746] HAL: creating pin 'hm2_5i23.0.encoder.05.rawcounts'
[ 190.334763] HAL: creating pin 'hm2_5i23.0.encoder.05.rawlatch'
[ 190.334780] HAL: creating pin 'hm2_5i23.0.encoder.05.count'
[ 190.334798] HAL: creating pin 'hm2_5i23.0.encoder.05.count-latched'
[ 190.334815] HAL: creating pin 'hm2_5i23.0.encoder.05.position'
[ 190.334833] HAL: creating pin 'hm2_5i23.0.encoder.05.position-latched'
[ 190.334851] HAL: creating pin 'hm2_5i23.0.encoder.05.velocity'
[ 190.334870] HAL: creating pin 'hm2_5i23.0.encoder.05.reset'
[ 190.334888] HAL: creating pin 'hm2_5i23.0.encoder.05.index-enable'
[ 190.334906] HAL: creating pin 'hm2_5i23.0.encoder.05.latch-enable'
[ 190.334924] HAL: creating pin 'hm2_5i23.0.encoder.05.latch-polarity'
[ 190.334942] HAL: creating parameter 'hm2_5i23.0.encoder.05.scale'
[ 190.334956] HAL: creating parameter 'hm2_5i23.0.encoder.05.index-invert'
[ 190.334970] HAL: creating parameter 'hm2_5i23.0.encoder.05.index-mask'
[ 190.334984] HAL: creating parameter 'hm2_5i23.0.encoder.05.index-mask-invert'
[ 190.334998] HAL: creating parameter 'hm2_5i23.0.encoder.05.counter-mode'
[ 190.335012] HAL: creating parameter 'hm2_5i23.0.encoder.05.filter'
[ 190.335026] HAL: creating parameter 'hm2_5i23.0.encoder.05.vel-timeout'
[ 190.335041] HAL: creating pin 'hm2_5i23.0.encoder.06.rawcounts'
[ 190.335060] HAL: creating pin 'hm2_5i23.0.encoder.06.rawlatch'
[ 190.335079] HAL: creating pin 'hm2_5i23.0.encoder.06.count'
[ 190.335099] HAL: creating pin 'hm2_5i23.0.encoder.06.count-latched'
[ 190.335118] HAL: creating pin 'hm2_5i23.0.encoder.06.position'
[ 190.335138] HAL: creating pin 'hm2_5i23.0.encoder.06.position-latched'
[ 190.335159] HAL: creating pin 'hm2_5i23.0.encoder.06.velocity'
[ 190.335179] HAL: creating pin 'hm2_5i23.0.encoder.06.reset'
[ 190.335200] HAL: creating pin 'hm2_5i23.0.encoder.06.index-enable'
[ 190.335220] HAL: creating pin 'hm2_5i23.0.encoder.06.latch-enable'
[ 190.335240] HAL: creating pin 'hm2_5i23.0.encoder.06.latch-polarity'
[ 190.335260] HAL: creating parameter 'hm2_5i23.0.encoder.06.scale'
[ 190.335275] HAL: creating parameter 'hm2_5i23.0.encoder.06.index-invert'
[ 190.335290] HAL: creating parameter 'hm2_5i23.0.encoder.06.index-mask'
[ 190.335306] HAL: creating parameter 'hm2_5i23.0.encoder.06.index-mask-invert'
[ 190.335322] HAL: creating parameter 'hm2_5i23.0.encoder.06.counter-mode'
[ 190.335337] HAL: creating parameter 'hm2_5i23.0.encoder.06.filter'
[ 190.335352] HAL: creating parameter 'hm2_5i23.0.encoder.06.vel-timeout'
[ 190.335368] HAL: creating pin 'hm2_5i23.0.encoder.07.rawcounts'
[ 190.335389] HAL: creating pin 'hm2_5i23.0.encoder.07.rawlatch'
[ 190.335411] HAL: creating pin 'hm2_5i23.0.encoder.07.count'
[ 190.335432] HAL: creating pin 'hm2_5i23.0.encoder.07.count-latched'
[ 190.335454] HAL: creating pin 'hm2_5i23.0.encoder.07.position'
[ 190.335476] HAL: creating pin 'hm2_5i23.0.encoder.07.position-latched'
[ 190.335499] HAL: creating pin 'hm2_5i23.0.encoder.07.velocity'
[ 190.335521] HAL: creating pin 'hm2_5i23.0.encoder.07.reset'
[ 190.335544] HAL: creating pin 'hm2_5i23.0.encoder.07.index-enable'
[ 190.335566] HAL: creating pin 'hm2_5i23.0.encoder.07.latch-enable'
[ 190.335588] HAL: creating pin 'hm2_5i23.0.encoder.07.latch-polarity'
[ 190.335611] HAL: creating parameter 'hm2_5i23.0.encoder.07.scale'
[ 190.335627] HAL: creating parameter 'hm2_5i23.0.encoder.07.index-invert'
[ 190.335644] HAL: creating parameter 'hm2_5i23.0.encoder.07.index-mask'
[ 190.335660] HAL: creating parameter 'hm2_5i23.0.encoder.07.index-mask-invert'
[ 190.335678] HAL: creating parameter 'hm2_5i23.0.encoder.07.counter-mode'
[ 190.335694] HAL: creating parameter 'hm2_5i23.0.encoder.07.filter'
[ 190.335710] HAL: creating parameter 'hm2_5i23.0.encoder.07.vel-timeout'
[ 190.335728] hm2/hm2_5i23.0: MD 2: 8x Encoder v2: accepted, using 8
[ 190.335736] HAL: creating parameter 'hm2_5i23.0.pwmgen.pwm_frequency'
[ 190.335749] HAL: creating parameter 'hm2_5i23.0.pwmgen.pdm_frequency'
[ 190.335763] HAL: creating pin 'hm2_5i23.0.pwmgen.00.value'
[ 190.335780] HAL: creating pin 'hm2_5i23.0.pwmgen.00.enable'
[ 190.335797] HAL: creating parameter 'hm2_5i23.0.pwmgen.00.scale'
[ 190.335811] HAL: creating parameter 'hm2_5i23.0.pwmgen.00.output-type'
[ 190.335825] HAL: creating pin 'hm2_5i23.0.pwmgen.01.value'
[ 190.335842] HAL: creating pin 'hm2_5i23.0.pwmgen.01.enable'
[ 190.335859] HAL: creating parameter 'hm2_5i23.0.pwmgen.01.scale'
[ 190.335873] HAL: creating parameter 'hm2_5i23.0.pwmgen.01.output-type'
[ 190.335887] HAL: creating pin 'hm2_5i23.0.pwmgen.02.value'
[ 190.335904] HAL: creating pin 'hm2_5i23.0.pwmgen.02.enable'
[ 190.335922] HAL: creating parameter 'hm2_5i23.0.pwmgen.02.scale'
[ 190.335936] HAL: creating parameter 'hm2_5i23.0.pwmgen.02.output-type'
[ 190.335951] HAL: creating pin 'hm2_5i23.0.pwmgen.03.value'
[ 190.335969] HAL: creating pin 'hm2_5i23.0.pwmgen.03.enable'
[ 190.335987] HAL: creating parameter 'hm2_5i23.0.pwmgen.03.scale'
[ 190.336042] HAL: creating parameter 'hm2_5i23.0.pwmgen.03.output-type'
[ 190.336060] HAL: creating pin 'hm2_5i23.0.pwmgen.04.value'
[ 190.336081] HAL: creating pin 'hm2_5i23.0.pwmgen.04.enable'
[ 190.336102] HAL: creating parameter 'hm2_5i23.0.pwmgen.04.scale'
[ 190.336119] HAL: creating parameter 'hm2_5i23.0.pwmgen.04.output-type'
[ 190.336136] HAL: creating pin 'hm2_5i23.0.pwmgen.05.value'
[ 190.336156] HAL: creating pin 'hm2_5i23.0.pwmgen.05.enable'
[ 190.336177] HAL: creating parameter 'hm2_5i23.0.pwmgen.05.scale'
[ 190.336195] HAL: creating parameter 'hm2_5i23.0.pwmgen.05.output-type'
[ 190.336212] HAL: creating pin 'hm2_5i23.0.pwmgen.06.value'
[ 190.336233] HAL: creating pin 'hm2_5i23.0.pwmgen.06.enable'
[ 190.336254] HAL: creating parameter 'hm2_5i23.0.pwmgen.06.s
04 Jul 2012 20:35 - 04 Jul 2012 20:37 #21577 by clkeck1
version is 2.5.0
here is the config line in the hal file
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i23/SVSS8_8.BIT num_encoders=4 num_pwmgens=3 num_3pwmgens=0 num_stepgens=0 sserial_port_0=00000000 "
Last edit: 04 Jul 2012 20:37 by clkeck1.
04 Jul 2012 20:43 #21579 by PCW
Oh thats a pretty ancient bitfile (sserial V23)
Moderators: PCWjmelson
