1Vpp Encoder to Mesa 7i33
There is just one open question for me regarding BLDC hal component and 8i20 driver card linked to need of absolute position.
8i20 should know rotor position by hall effect current sensing? If yes, how I get this information to BLDC to be synchronized where the rotor actualy is? Maybe I am lost in understanding of the principle, I am sorry for that.
I think you may be confusing two uses if "Hall effect"pavel7890 wrote: 8i20 should know rotor position by hall effect current sensing? If yes, how I get this information to BLDC to be synchronized where the rotor actualy is? Maybe I am lost in understanding of the principle, I am sorry for that.
A typical brushless motor has Hall sensors in the motor to feed-back the absolute rotor position.
The bldc component watches these signals changing and uses the first transition that it sees as an absolute reference, and then switches to using the encoder value to give a more fine-grained position.
If your motors have a Hiperface encoder it is possible that they don't have Hall sensors, which may make getting an absolute position reference rather more difficult (Hiperface might be the _only_ way if the encoders have no index pulse.)
The blcd can do "bump" alignment, but that isn't very reliable under load.
I am just curious about one interesting feature of the encoder. I tested absolute positioning by shaft turning after power off. I would expect that after power on, the encoder can provide shaft position within 360 deg, but he was even able to provide number of revolutions too!!
How this can be done? There might be a battery or some kind of different mechanism I do not know about.
Anyhow, this feature gives me perfect feedback not only for commutation but for machine positioning after power on.
Paul
Can you give more details? Is this something that could be a released HAL component?pavel7890 wrote: I just proceed with Hiperface encoder RS485 interface with positive results. Its in principal easy to understand and implement into HAL..
