7i43 200k firmware for serials and encoders
- nilpferd_noedel
08 Sep 2013 20:57 #38540
by nilpferd_noedel
7i43 200k firmware for serials and encoders was created by nilpferd_noedel
Hi, I´m new to this forum and come from germany
I´ve retrofitted a Klopp CNC Mill with LinuxCNC. The basic I/O and servo configuration
runs with a 5i20, 2x 7i37 and 7i33.
Now I want to embed a control panel with poti for feed-override, electronic handwheel and some buttons.
Two encoders for spindle control are also required.
For this I´ve bought a 7i43 200k (runs already on parallelport). My plan is to use this with a 7i52 and the pendant control board 7i73.
So I need a firmware with configures the 7i43 for 6 encoder channels + 6 serials.
I haven´t found any suitable firmware in this forum.
Knows someone a suitable firmware for this?
A konfiguration with an 7i44 (8 channel serial rs 422) would also help me.
Thanks,
Henrik
Thanks,
Henrik
- Thank you received: 5255
09 Sep 2013 00:14 #38543
Replied by PCW on topic 7i43 200k firmware for serials and encoders
I can do this Monday
10 Sep 2013 04:12 - 10 Sep 2013 20:30 #38577
freeby.mesanet.com/7i43ss.zip has 2 bitfiles for 7I43-200:
7i43_svss4_4s.bit for 7I33 and 7I44
and
7i43_svss6_4s.bit for 7I52
Note 4 sserial ports is all that would fit in a 200K FPGA
and
Last edit: 10 Sep 2013 20:30 by PCW.
- nilpferd_noedel
10 Sep 2013 12:33 - 10 Sep 2013 12:39 #38591
by nilpferd_noedel
Replied by nilpferd_noedel on topic 7i43 200k firmware for serials and encoders
Thank you
I hope that I can try it today.
Edit:
I think the link doesn`t work.
The requested URL /7i43ss.bit was not found on this server.
Edit:
Last edit: 10 Sep 2013 12:39 by nilpferd_noedel.
10 Sep 2013 20:30 #38616
sorry, thats 7i43ss.zip
- nilpferd_noedel
11 Sep 2013 01:56 #38641
by nilpferd_noedel
Hello,
I just tried it but linuxcnc break off with following error message:
hm2: loading Mesa HostMot2 driver version 0.15 [ 870.311929]
hm2_7i43: loading HostMot2 Mesa 7i43 driver version 0.3 [ 870.314000]
hm2_7i43.0: firmware: requesting hm2/7i43-2/7i43_svss6_4s.bit [ 870.621805]
hm2/hm2_7i43.0: IDROM IOPorts is 2 but MD IOPort NumInstances is 3, inconsistent firmware, aborting driver load [ 870.621816]
hm2/hm2_7i43.0: failed to parse Module Descriptor 1 [ 870.621829]
hm2_7i43.0: board at (ioaddr=0x0378, ioaddr_hi=0x0778, epp_wide ON) not found! [ 871.244973]
hm2: unloading [ 871.311534]
RTAI[math]: unloaded. [ 871.336612]
SCHED releases registered named ALIEN RTGLBH [ 871.372459]
RTAI[malloc]: unloaded. [ 871.468027]
RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 871.472563]
The firmware is loaded by following path in .hal:
loadrt hm2_7i43 config="firmware=hm2/7i43-2/7i43_svss6_4s.bit num_encoders=6 sserial_port_0=00000004 "
11 Sep 2013 03:11 #38647
it should be fixed it you re-fetch the zipfile
- nilpferd_noedel
20 Sep 2013 08:01 #39055
by nilpferd_noedel
Thank you very much.
The firmware works (even the analog feed override with poti), but I have still two problems:
- input 5, 7 and 9 of the 7i73 switch simultaneously (not single switchable)
- the component "matrix_kb" doesn't work, so I must buy another input card (via smart serial bus) to realize my buttons
20 Sep 2013 09:41 #39056
You should check your input levels, inputs 0 through 7 (since they can be used as analog inputs) have neither pullups or pulldowns so can float and follow nearby pin states do to capacitance and leakage. If you wish to use these pins as digital inputs you must either connect to SPDT switches or provide pullup/pulldown resistors.
Whats wrong with the matrix KB component?
- Thank you received: 4988
21 Sep 2013 07:41 #39070
It should work. The 7i73 is just about the only thing I tested it on.
What is the problem?
Replied by andypugh on topic 7i43 200k firmware for serials and encoders
Time to create page: 0.078 seconds
