Mesa 5i22 + 7i29 + 7i52 custom firmware
- kostas
- Thank you received: 6
07 Jan 2014 05:41 #42405
by kostas
Mesa 5i22 + 7i29 + 7i52 custom firmware was created by kostas
I tried to compile a new firmware for the 5i22 because I have to combine two 7i29 + one 7i52, so I made a new .vhd file with a guess for what I have to include after reading other files. Unfortunately the generated .bit file does not load and dmsg reports "hm2/hm2_5i22.0: IDROM IOPorts is 4 but MD IOPort NumInstances is 3, inconsistent firmware, aborting driver load" . I compiled with ISE 9.2.
I guess I'm doing something wrong
Maybe Peter could have a look at the vhdl source and tell me what is the problem?
I have attached the .vhd file
Thanks,
Kostas
Thanks,
Kostas
- kostas
07 Jan 2014 07:16 #42413
by kostas
Replied by kostas on topic Mesa 5i22 + 7i29 + 7i52 custom firmware
Oops, I see now that the file was not attached, maybe because of the extension? Same as .txt ..
- Thank you received: 5217
07 Jan 2014 10:30 #42422
Replied by PCW on topic Mesa 5i22 + 7i29 + 7i52 custom firmware
at least this line is in error:
(IOPortTag,x"00",ClockLowTag,x"03",PortAddr&PadT,IOPortNumRegs,x"00",IOPortMPBitMask)
the 0x03 (number or I/O ports) should be 0x04 for a 5I22
- kostas
08 Jan 2014 06:22 #42465
by kostas
Thanks Peter. Would it be easy for you to make a new configuration for this? I thought I might give it a try and build one myself, but now it fails with different errors ..
08 Jan 2014 08:38 #42471
I will try and get to this some time this week
- kostas
08 Jan 2014 18:30 #42488
by kostas
That would be very helpful, thanks!
11 Jan 2014 05:41 #42592
Here is the edited pinout file and bitfiles for 1.5M and 1M 5I22s
Note that I used multiplexed encoder for all encoders since I'm not sure
if the driver version you have supports mixed encoder types.
This results in somewhat odd encoder numbering:
PHYSICAL HAL
7I29 ENC0 ENC0
7I29 ENC1 ENC2
7I29 ENC2 ENC4
7I29 ENC3 ENC6
7I52 ENC0 ENC8
7I52 ENC1 ENC9
7I52 ENC2 ENC10
7I52 ENC3 ENC11
7I52 ENC4 ENC12
7I52 ENC5 ENC13
PHYSICAL HAL
7I29 ENC0 ENC0
7I29 ENC1 ENC2
7I29 ENC2 ENC4
7I29 ENC3 ENC6
7I52 ENC0 ENC8
7I52 ENC1 ENC9
7I52 ENC2 ENC10
7I52 ENC3 ENC11
7I52 ENC4 ENC12
7I52 ENC5 ENC13
The following user(s) said Thank You: kostas
- kostas
12 Jan 2014 07:16 #42631
by kostas
It's working! Many thanks Peter!
- kostas
19 Jan 2014 06:58 - 19 Jan 2014 07:07 #43003
by kostas
Peter, I tried to compile a modified version of the vhdl file you gave me because as it turns out I need a firmware with two more pwms and encoders for one more 7i29 I'm about to order soon. I used the tree from git://git.linuxcnc.org/git/hostmot2-firmware.git and your modified vhdl file and compiled with ISE 10.1, but I can't get results.
Firmware compiled succesfully but I get an error: "hm2/hm2_5i22.0: The bitfile contains Smart Serial modules for a firmware revision < rev22. This Driver now requires rev22 or newer firmwares"
Can you tell me what I should do? I don't want to bother you all the time with firmware customizations if I can build them myself.
Thanks in advance.
Thanks in advance.
Last edit: 19 Jan 2014 07:07 by kostas.
19 Jan 2014 07:51 - 19 Jan 2014 07:52 #43005
I would download the source from mesa, (in 5i20.zip)
use the fivei20 project file and go from there
Last edit: 19 Jan 2014 07:52 by PCW.
Time to create page: 0.075 seconds
