- Thank you received: 95
Bumped into this, to old but for the sake of having correct information.greeder88 wrote: I an getting some weirdness with the scale factor.
I put three different encoders on my machine and scaled so I have .100 inch of travel per motor revolution which is what I require.
Encoder 1 has 250ppr and needs a scale factor of 10,000
Encoder 2 has 1000ppr and needs 40,000
Encoder 3 has 1024ppr and needs 20,480
Encoder 3 is only getting half the counts it should.
They are all the same BEI ABZC indexed encoders.
I can live with the lower count but does anyone know what happened?
Also a spare encoder is open collector not line driver. Is there a way to use it with a converter chip of some sort or should I get rid of it?
