Mesa 5i24 mesaflash : No 5I24 board found
- erasmo
- Topic Author
10 years 2 months ago - 10 years 2 months ago #78606
by erasmo
Mesa 5i24 mesaflash : No 5I24 board found was created by erasmo
Hi I have a problem - after programming 5i24 with bitfile using command
sudo ./mesaflash --device 5i24 --write 5i24_25_sv12im_2x7i48.bit
5i24 stopped responding and is not visible using lspci
command
sudo ./mesaflash --device 5i24 --readhmid
gives output:
No 5I24 board found
I did full power cycle and I swaped pci port nothing have changed.
Red Led is ON all the time
What should I do? Can anyone help?
command
gives output:
No 5I24 board found
Last edit: 10 years 2 months ago by erasmo.
- Thank you received: 5334
10 years 2 months ago #78619
Replied by PCW on topic Mesa 5i24 mesaflash : No 5I24 board found
Is the 5I24 you have a -25 model?
What OS and mesaflash version did you use?
I sounds like either the bitfile was not appropriate or somehow the EEPROM got corrupted
I have heard about a problem with 64 bit OSes and mesaflash, possibly you have run into this
You should be able to recover by selecting the other EEPROM
BUT that's the last chance (without JTAG) so the problem needs to be determined
_before_ the backup EEPROM is also corrupted
The first step is to find out what happened
- erasmo
- Topic Author
10 years 2 months ago - 10 years 2 months ago #78622
by erasmo
Replied by erasmo on topic Mesa 5i24 mesaflash : No 5I24 board found
Chip number:
XC6SLX16
FTG256DIV1249
EEProm Memory
25P16VP
My system Ubuntu 10.04 32 bit
XC6SLX16
FTG256DIV1249
EEProm Memory
25P16VP
10 years 2 months ago - 10 years 2 months ago #78623
Ahh, you tried to put a -25 bitfile in a -16 card
The bitfile you want is 5i24_16_sv12im_2x7i48.bit
Here is what I would do to make sure the second EEPROM is kept safe:
1. Arrange your PC so you have easy access to the 5I24 card
2. Move the EEPROM jumper to the secondary position
3. Power on the PC (red lights should go out)
4. Move the EEPROM jumper back to the Primary position
5. Run the correct mesaflash command
Last edit: 10 years 2 months ago by PCW.
The following user(s) said Thank You: erasmo
- erasmo
- Topic Author
10 years 2 months ago #78624
by erasmo
Thank You it worked.
- erasmo
- Topic Author
10 years 2 months ago - 10 years 2 months ago #78644
by erasmo
Hi now I have next problem - 7i65 analog outputs doesnt work.
My pid.output goes to mesa-7i65.0.analog.0.out but it does nothing, no voltage on AOUT0
mesa-7i65.0.enable.0.out is set
Encoders are working fine, watchdog is disabled for testing purposes
What am I doing wrong?
10 years 2 months ago #78645
The config you are using is not suited to a 7I65 (its meant for 1 or 2 7I48s)
For a 5I24-16 with 1 or 2 7I65s you would want 5i24_16_2x7i65.bit
- erasmo
- Topic Author
10 years 2 months ago - 10 years 2 months ago #78646
by erasmo
I also have 7i44 connected to P4 will it run using 5i24_16_2x7i65.bit ?
or do I have to compile my own designated bitfile?
10 years 2 months ago #78647
That needs a new bitfile
I'll see if I can get to it today
10 years 2 months ago #78680
