7i84 + MPG
  • terkaa
  • Topic Author
  • Elite Member
  • Elite Member
10 years 2 months ago #79324 by terkaa
7i84 + MPG was created by terkaa
I have set mode 2 for 7i84 to connect MPG on inputs 16&17. And after that I got analog input pins and encoder pins. I would like to know if it is still possible to use input pins 18 & 19 as "regular" 5V inputs?
Tero
10 years 2 months ago #79328 by PCW
Replied by PCW on topic 7i84 + MPG
Yes, you can use (7I84) pins that are not used as MPG or Analog inputs as standard digital inputs
They will have the default thresholds of 60% and 40% of VField (so the MPG inputs used as digital inputs
are not 5V inputs unless you have 5V field power)
  • terkaa
  • Topic Author
  • Elite Member
  • Elite Member
10 years 2 months ago #79337 by terkaa
Replied by terkaa on topic 7i84 + MPG
i do have 5V field power so in this case they are 5V inputs. Thank you for clearing this.
Tero
Moderators: PCW, jmelson
