getting 5i25 work for 5 axis Machine - help need -
  • G0G53Z148
  • G0G53Z148's Avatar Topic Author
  • Senior Member
  • Senior Member
18 Sep 2016 15:10 #80569 by G0G53Z148
Hello everybody.
I'm sitting here in front of a problem. I want to extend the machine by my colleague from the current 4 axes X-Y-Z-A to 5-axis X-Y-Z-A-C.
In the spring of Sarah wrote to me on the forum a custom firmware for the existing hardware previously also really great was. For two weeks we are now sitting on it and do not find the error.
I have now again a Hal and INI of the two configurations. To test if the P2 header we have to work at the A axis once configured on P3 and once on the P2 where the 5th axis so C should be later.
Could you please check times as I the files must now together copy I get an X-Y-Z-A-C machine.
In the ini I have already extended to 6 axes and the C axis inserted in the ad was then already visible. In the hal I then in 4 Achs the section A machine copied to the Hal and everything for A axis was renamed C. Unfortunately, it does not really
Thanks for your help
And beautiful greetings
The topic has been locked.
18 Sep 2016 20:29 #80581 by andypugh
The screen photo is a bit hard to read.
Can you copy and paste the text from dmesg?
It looks like the 4th stepgen is on the second connector. But I think I see hints of a stepgen,5 on the first connector.
18 Sep 2016 22:28 #80587 by tommylight
You have only STEP stepgen 5 on that setup, you also need to add stepgen 5 for DIR.
18 Sep 2016 23:17 #80588 by PCW
It looks like stepgen 5 is intended as a chargepump signal source (thats why it has no DIR signal)
That is, there are 6 stepgens (0..5) 0..4 are for 5 motion axis and stepgen 5 is just intended as
a square wave signal generator
19 Sep 2016 00:23 #80590 by tommylight
Forgot to add "not my forte", sorry PCW.
Tom
19 Sep 2016 02:04 #80591 by PCW
No problem, its a rather odd and non-obvious use of a stepgen
  • G0G53Z148
  • Senior Member
  • Senior Member
19 Sep 2016 04:19 #80593 by G0G53Z148
Hello
Yes there are 5 stepgen
0-5
5 is chargepump
I have tryed to cope the config halsection of p2 to config p3 and rename the section to axis c but the there are no motion and erros of that c axis pins no exist
19 Sep 2016 14:14 #80612 by PCW
Can you post the error(s) here
preferably as a text file, not a screenshot
  • G0G53Z148
  • Senior Member
  • Senior Member
19 Sep 2016 15:07 #80618 by G0G53Z148
dear PCW
i am sorry i cant post any files at the moment i am away 200 km from this machine.
i only can post what i have tryed in Ini and HAL. but we dont get some movment for the c axis saomething is wrong there but we dont know what
i have addet only the section c to hal and ini
please make a overviw of there is an error in the file and at the weekend i will test it wehn i come home from work
thank you
  • G0G53Z148
  • Senior Member
  • Senior Member
20 Sep 2016 09:48 - 20 Sep 2016 13:39 #80660 by G0G53Z148
Push up
my collegue has done a video
link to the video
velocity of c axis goes on but no movement and after this joint following erroy you see
Does no one know how to build a 5 axis configuration!
Ihr könnte mir auch gerne in deutsch antworten dies wäre für uns sehr viel einfacher.
Please post a running 5 axisconfiguration to build our own tell me were can i find a 5axis configuration tool
Last edit: 20 Sep 2016 13:39 by G0G53Z148. Reason: what he sais?
Moderators: PCW, jmelson
Time to create page: 0.114 seconds
