Mesa 7i76e and toolchanger.comp
9 years 6 months ago #91919 by PCW
Replied by PCW on topic Mesa 7i76e and toolchanger.comp
Can you post you hal and ini files? something very basic is broken here
9 years 6 months ago #91920 by mikeross
Attached,
Thanks,
Mike
9 years 6 months ago #91921 by PCW
OK what i think is happening is this:
The toolchanger does not provide a motion profile, it just steps the position so the
FF1 term is not doing the expected thing
You might try setting the PID maxerrror to 0 and see what happens
The following user(s) said Thank You: mikeross
9 years 6 months ago #92018 by mikeross
As suggested I changed the PID maxerror in the HAL to 0 (spent some time looking for this in the .ini...)
setp pid.ToolChanger.maxerror .000
That worked - Now its alive! Needs to be tuned though as it overshoots quite a bit.
This might be another reason for me to think about rewriting the toolchanger.comp, but if I get it working enough I may just live with it.
Thanks for your help!
Mike
9 years 6 months ago #92019 by PCW
The stepgenerator really dislikes step inputs (this is why you have overshoot) so one solution would to feed the position
command through the limit3 component so an actual trapezoidal velocity profile is generated
9 years 6 months ago #92020 by mikeross
I'll give that a try - as a quick hint - will that need to be in the toolchanger.comp or can I just reroute it in the hal file?
Mike
Moderators: PCW, jmelson
Time to create page: 0.065 seconds
