B9T wrote: The big question mark is currently on needing up to 12 analog inputs for temperature measurements.
andypugh wrote: This might be an option:
linuxcnc.org/docs/devel/html/man/man9/max31855.9.html
rodw wrote: Andy's idea sounds like a good one. Just another thought though. 2 x 7i76 cards would give you your 7 stepgens (and 3 spares). Plus you would end up with 3 analog inputs on each card (6 total) so 8 inputs on the 7i87 would give you all of the analog inputs you need and solve all of your I/O problems for limit switches etc.
I have used LM35 analog sensors with an Arduino. You'd have to see how well they might work with the voltage ranges used by the Mesa cards (and the 7i76 inputs were accurate enough for your needs).
