7i80HD-16 and Xilinx ISE, error on synthesize
- B9T
- Topic Author
8 years 6 months ago #109858
by B9T
7i80HD-16 and Xilinx ISE, error on synthesize was created by B9T
Dear all,
I'm not sure if this is the right place, but I downloaded the support zip archive for the 7i80hd-16. I'm now trying to build bitfiles for the card and have downloaded the Xilinx ISE 14.7. When trying to build the PIN_JUSTIO.vhd configuration i get the following error:
Indicating that the function(?) loadmpg is missing in inmuxm.vhd. Is there an updated version of those files, or what would be required to fix this?
thanks in advance,
B9T
ERROR:HDLCompiler:1314 - "/home/linuxcnc/Documents/7i80/configs/hostmot2/source/hostmot2/hostmot2.vhd" Line 3094: Formal port/generic <loadmpg> is not declared in <inmuxm>
ERROR:HDLCompiler:432 - "/home/linuxcnc/Documents/7i80/configs/hostmot2/source/hostmot2/hostmot2.vhd" Line 3078: Formal <muxdata> has no actual or default value.
INFO:HDLCompiler:1408 - "/home/linuxcnc/Documents/7i80/configs/hostmot2/source/hostmot2/inmuxm.vhd" Line 90. muxdata is declared here
ERROR:HDLCompiler:854 - "/home/linuxcnc/Documents/7i80/configs/hostmot2/source/hostmot2/hostmot2.vhd" Line 146: Unit <dataflow> ignored due to previous errors.
VHDL file /home/linuxcnc/Documents/7i80/configs/hostmot2/source/hostmot2/hostmot2.vhd ignored due to errors
thanks in advance,
B9T
- Thank you received: 5334
8 years 6 months ago #109859
Replied by PCW on topic 7i80HD-16 and Xilinx ISE, error on synthesize
Did you download the sources recently? pretty sure this error was fixed around the 13th of April
The following user(s) said Thank You: B9T
- B9T
- Topic Author
8 years 6 months ago #110004
by B9T
Replied by B9T on topic 7i80HD-16 and Xilinx ISE, error on synthesize
I just re-downloaded the archive to be sure, and yes it was fixed, thank you. I was working with a copy that I downloaded when I ordered the board initially.
- vre
- Thank you received: 17
5 years 9 months ago #194207
by vre
Replied by vre on topic 7i80HD-16 and Xilinx ISE, error on synthesize
Hello and happy new year
I have a similar error..
ERROR:HDLCompiler:432 - "/home/mill/Documents/hostmot2/hostmot2sp6.vhd" Line 4035: Formal <hloadregs4> has no actual or default value.
ERROR:HDLCompiler:104 - "/home/mill/Documents/hostmot2/hostmot2sp6.vhd" Line 4188: Cannot find <sserialbwab> in library <work>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
ERROR:HDLCompiler:854 - "/home/mill/Documents/hostmot2/hostmot2sp6.vhd" Line 146: Unit <dataflow> ignored due to previous errors.
Time to create page: 0.199 seconds
