2.2kw VFD Spindle wiring to Mesa 7i76e
8 years 2 weeks ago #118851 by jackdavies
Does anyone know the best way to wire a standard Huanyang VFD to the Mesa 7i76e board?
I can kind of guess most of the connections but would be good to have a solid idea of how they should be connected!
Cheers, Jack
The following user(s) said Thank You: deanforbes
8 years 2 weeks ago #118855 by Hakan
No eBay APP ID and/or Cert ID defined in Kunena configurationI have not connected the Huan Yang vfd to the 7i76e. Instead I used USB-RS485 converter like this one
together with the hy_vfd module
8 years 2 weeks ago #119013 by andypugh
+10 to Pin 3
VI to pin 2
ACM to Pin 1
FOR to Pin 6
REV to Pin 8
DCM to Pins 7 and 5
Then Configure the VFD
PD001 = 1
PD002 = 1
PD044 = 1
PD045 = 5
The following user(s) said Thank You: TheChosenOne, deanforbes, Sadmeatball, benqick
5 years 8 months ago #200418 by Marki123
Hi, i have a HY02D223B Ver.2 i think. Did anyone have an idea how to connect them right to the 7i76e? Or would it be better to only work with the RS485 Modbus
5 years 8 months ago - 5 years 8 months ago #200460 by kkuehn
Modbus is preferable in my opinion because it allows you to have information from the VFD available in LinuxCNC. I currently have a pyvcp panel set up to display the current draw from the VFD and the approximate spindle speed based on the frequency the VFD is outputting.
Edit: I have a different VFD than you have, and I don't see the Rs- and Rs+ headers on yours.
Last edit: 5 years 8 months ago by kkuehn.
5 years 8 months ago #200461 by Hakan
I agree on Modbus. But it seems from a quick search that the "ver 2" is a clone that lacks Modbus www.kronosrobotics.com/hy02d223b-vfd-type-2
Follow Andy's wiring a few posts back,
where Andy has ACM and DCM you have only GND,
and you have +12V instead of +10
Moderators: PCW, jmelson
Time to create page: 0.375 seconds
