- Thank you received: 126
Another option is the Pico Systems (disclosure - my company) PWM controller for servos and the Universal Stepper Controller for anything that needs step and direction. It can run those in either open-loop or closed-loop mode. These are controlled by the parallel port as a communications channel to the device. Drivers are included in the LinuxCNC distribution.irakandjii wrote: Thanks Andy. It is nice to hear the stuff is supported BUT...
Are there any specifics documented anywhere?
BTW .. I would not use a raspi as a front end so it never occurred to me, I use a lot of them, but never for mission critical stuff.
I think my problem is that I am not sure what you want help designing.irakandjii wrote: The first part was a request for a link to where I can find design information.
Both Pico and Mesa make very capable interface boards that use the parallel port as a communications bus. I assumed you were meaning one of these. (Pico USC and PPMC and the Mesa 7i43 and 7i90 I assumed you were talking about these, from the context.On PCI we might be talking about the same thing. When I reference DB25 I was talking about a MESA PCIe card with a DB25 connecting to a daughter card.
The buildbot builds all the current versions, both 2.7 and master. master and "2.8" are the same thing.Ah ok on the 2.8 build, I am using the GIT master for source. Is this buildbot master build the same or different?
I used the instructions on the site to get the release from GIT, so now I am confused regarding the official release site.
Yes, you are reading it wrong.These buildbot files seem to only support precise. Am I reading that wrong?
