5i25 + 7i77, 3 servos and one stepper *SOLVED*
04 Nov 2018 21:35 #119943 by biqut2
I've been banging my head against the wall again...
I've had my Hurco Hawk 5M mill running quite smoothly for a while now. It has 3 DC servos that are running off the 7i77. I decided today to hook up my 4th axis to the machine. It has a closed loop stepper that accepts step/direction signals. I have been using this thread as a reference: forum.linuxcnc.org/27-driver-boards/2750...a-7i77-5i25?start=50 . I have the same 5 axis BOB and am wanting to do the same thing as this guy but I'm unclear as to what his actual solution was. I have flashed the 5i25 with the 7i77_7i76 firmware, setup a stepgen for the A axis, but can't seem to get any output on the BOB. I know the BOB is working as I can swap it into one of my other CNCs and it works fine there. I suspect pin mapping is the issue but I don't know how to correct it. Any help would be greatly appreciated.
04 Nov 2018 22:03 - 04 Nov 2018 22:05 #119944 by PCW
Replied by PCW on topic 5i25 + 7i77, 3 servos and one stepper
You should not use 7I77_7I76 firmware for anything but a 7I77+ a 7I76 since it will
be completely incompatible with parallel port BOB pinouts
I think 5i25_7i77_BSTECH firmware should be a lot closer.
You can verify the pinout by loading the firmware and running mesaflash with the readhmid option:
sudo mesaflash --device 5i25 --write 5i25_7i77_bstech.bit
( write new bitfile to flash memory )
sudo mesaflash --device 5i25 --reload
( load FPGA from new bitfile image in flash memory )
sudo mesaflash --device 5i25 --readhmid > pinout.txt
( read the new pinout and put it on the pinout.txt file )
Last edit: 04 Nov 2018 22:05 by PCW.
04 Nov 2018 22:40 - 04 Nov 2018 23:31 #119946 by biqut2
Thank for the fast reply. I loaded the 5i25_7i77_BSTECH firmware, restarted the computer because the reload command wouldn't work, read out the pinout and it looks the same is he 7i77_7i76. the step gens are on 1/14 2/15 3/16 and 4/17. Pncconf doesn't show the bstech firmware either.
Edit: Nevermind, after shutting down killing power and booting back up the pins changed and now it runs all 4 axis properly Thank you again for all the help.
Last edit: 04 Nov 2018 23:31 by biqut2.
05 Nov 2018 19:56 #120030 by PCW
After checking this I noticed that the bitfile date on 5i25_7i77_bstech.bit was 2014,
this predates some sserial noise immunity fixes so its probably best that you use this fresh bitfile:
freeby.mesanet.com/bs.zip
Note that you should be able to use the reload command now ( it needs relatively recent bitfiles )
13 Feb 2020 19:09 - 13 Feb 2020 19:23 #157304 by alex.statie
Replied by alex.statie on topic 5i25 + 7i77, 3 servos and one stepper *SOLVED*
Hello!
Piggybacking on this thread - sorry for resurrecting the dead! :)
I am using a 6i25 (in 5i25 mode) with one 7i77 and an additional stepper that i plan to wire directly to P2 (Z axis controlled by stepper and not servo).
Flashed the 6i25 with the 5i25_7i77_bstech.bit file and checked it with readhmid -> pins look OK.
Problem is in PNCConf.
Initially throws a strange error 'currentboard is not defined'. I've hardcoded the currentboard value in the script and all is good, i can see the list of XML files loaded manually in /lib/firmware/hm2/5i25.
The problem that i have is when i select the 5i25_7i77_bstech.xml file in PNCConf it only populates the P2 and P3 tabs, but does not create the 7i77 tabs (and automatically configures P3 for 7i77).
Being an absolute noob at this, i have no idea how to do that manually. I am guessing i can use a hal file for 7i77_7i76 and copy the 7i77 part in the incomplete hal file generated for bstech...but it's just a guess :)
Any help or advice would be greatly appreciated!
Later edit: or i could simply use the 7i77_7i76 configuration and connect to a set of step/dir pins (without the 7i76 board of course)?
Thanks!
Alex
Last edit: 13 Feb 2020 19:23 by alex.statie.
  • Moderator
  • Moderator
13 Feb 2020 19:29 #157308 by tommylight
Replied by tommylight on topic 5i25 + 7i77, 3 servos and one stepper *SOLVED*
You can make two configs with pncconfig, one for 5i25/7i77 and one for 5i25/bstech, then add the parts from bstech to the 7i77. You need to do that for the hal and ini files only.
15 Feb 2020 15:00 #157442 by alex.statie
Thank you, tommylight!
That did the trick for me!
Merging the two .hal and .ini files was actually much easier than expected. One pncconf config was done for 7i77_7i76 and another for 7i77_bstech.
Managed to connect the stepper driver directly into the P2 port of the 6i25. Please be mindful of the pin number when doing this, the pins do not start at 1 as in the .pin file, so you would need the board’s manual to figure out the exact ones. I’ve left the P2 power jumper to off and it works just fine.
  • Moderator
  • Moderator
15 Feb 2020 15:19 #157447 by tommylight
You are welcomed, always.
Glad you got it working and thank you for reporting back.
Moderators: PCWjmelson
Time to create page: 0.101 seconds
