7i96E Differental Step/Dir - SOLVED
- Project_Hopeless
- Topic Author
- Thank you received: 9
10 Jul 2019 01:30 - 20 Jul 2019 14:44 #138986
by Project_Hopeless
7i96E Differental Step/Dir - SOLVED was created by Project_Hopeless
Do you need to set any jumpers to run a 7i96E Mesa card in differential mode on the Step and Dir outputs? I wouldn't think so, and there is nothing indicated in the manual.
LinuxCNC is talking with the card, axis positions in joint are changing, the drives are powered, and the stepper rotors are locked/holding.
I know it is something simple, it has me stumped .
Last edit: 20 Jul 2019 14:44 by Project_Hopeless.
10 Jul 2019 04:10 #138987
Replied by PCW on topic 7i96E Differental Step/Dir
Whether the step/dir outputs are differential or single ended is entirely determined by
how they are wired
Note that by far the most common reasons that you don't get movement in step/dir
systems are wiring errors, step/dir swapped or too short step pulses
(start with 5000 ns)
how they are wired
The following user(s) said Thank You: oddwick, Project_Hopeless
- Project_Hopeless
- Topic Author
10 Jul 2019 15:31 #139006
by Project_Hopeless
I don't need extreme performance out of my hobby machine so I should be able to de-tune.
Is there a rule of thumb like 2x or 4x min pulse duration ? Should step and direction timings be set equal?
Replied by Project_Hopeless on topic 7i96E Differental Step/Dir
The manual for my drives state a minimum 2500ns for step, and 5000ns for dir changes. That is what I configured for.Note that by far the most common reasons that you don't get movement in step/dir
- Mike_Eitel
- Thank you received: 185
10 Jul 2019 16:27 #139008
by Mike_Eitel
Replied by Mike_Eitel on topic 7i96E Differental Step/Dir
I see no enable cabling on your drivers...
Mike
Mike
10 Jul 2019 16:33 #139009
In general you should _never_ use minimum timing numbers
I would always double the minimums to start and only reduce the timings
if they limit your maximum step rate.
The following user(s) said Thank You: Project_Hopeless
10 Jul 2019 16:43 #139010
Pretty sure those drives (like most low end step motor drives) have "DISABLES"
so will work when unconnected.
Mike
- Mike_Eitel
10 Jul 2019 17:00 #139011
by Mike_Eitel
Was aware, but dislike unconnected (activated) inputs by principle
- Project_Hopeless
- Topic Author
10 Jul 2019 19:16 #139017
by Project_Hopeless
That is correct, enables not required on these drives.
Mike
- Project_Hopeless
- Topic Author
10 Jul 2019 22:51 #139032
by Project_Hopeless
Yup!! doubled the step/dir times, motors are purring like kittens. I knew it had to be something simple.In general you should _never_ use minimum timing numbers
10 Jul 2019 23:05 - 10 Jul 2019 23:06 #139035
Pretty sure generic Chinese step/dir drives are not tested at their minimum step length spec...
Last edit: 10 Jul 2019 23:06 by PCW.
Time to create page: 0.093 seconds
