Mesa 7i92 firmware for 7i76 ?
7 years 2 months ago #141734 by JC10
Hello,
just got a 7i92 for the first time. I used only 6i25 so far with a 7i77 and it was a bundle pre-programmed.
Do I need a special 7i92 firmware to operate with the 7i76 ? If yes, where do i get it ?
Thanks for help.
7 years 2 months ago #141736 by tommylight
You should check with mesaflash for what is already in it,
mesaflash --device 7I92 --addr 10.10.10.10 --readhmid
That will show the pins for the existing firmware.
Go to mesanet.com, choose "anything io" or similar on the left side menu, find the 7i92 and there is a link to a zip file with all the firmwares for it.
7 years 2 months ago - 7 years 2 months ago #141799 by JC10
Replied by JC10 on topic Mesa 7i92 firmware for 7i76 ?
Hello TommyLight,
thanks for your answer.
The result of your line of commands gave :
Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I92 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 2 Width of one I/O port: 17 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: DPLL There are 1 of DPLL in configuration Version: 0 Registers: 7 BaseAddress: 7000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 2 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 1 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5A00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: StepGen There are 5 of StepGen in configuration Version: 2 Registers: 10 BaseAddress: 2000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort StepGen 0 Dir/Table2 (Out) 14 1 IOPort StepGen 0 Step/Table1 (Out) 2 2 IOPort StepGen 1 Dir/Table2 (Out) 15 3 IOPort StepGen 1 Step/Table1 (Out) 3 4 IOPort StepGen 2 Dir/Table2 (Out) 16 5 IOPort StepGen 2 Step/Table1 (Out) 4 6 IOPort StepGen 3 Dir/Table2 (Out) 17 7 IOPort StepGen 3 Step/Table1 (Out) 5 8 IOPort StepGen 4 Dir/Table2 (Out) 6 9 IOPort StepGen 4 Step/Table1 (Out) 7 10 IOPort SSerial 0 TXData1 (Out) 8 11 IOPort SSerial 0 RXData1 (In) 9 12 IOPort SSerial 0 TXData2 (Out) 10 13 IOPort SSerial 0 RXData2 (In) 11 14 IOPort QCount 0 Quad-IDX (In) 12 15 IOPort QCount 0 Quad-B (In) 13 16 IOPort QCount 0 Quad-A (In) IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 17 IOPort None 14 18 IOPort None 2 19 IOPort None 15 20 IOPort None 3 21 IOPort None 16 22 IOPort None 4 23 IOPort None 17 24 IOPort None 5 25 IOPort None 6 26 IOPort None 7 27 IOPort None 8 28 IOPort None 9 29 IOPort None 10 30 IOPort None 11 31 IOPort None 12 32 IOPort None 13 33 IOPort None
My 7i92 is a M version with a DB25 connectore on P2.
Here above, when I see that there is no IO connections on P1 and many IO connections for steppers on P2 , I would say that the firmware on this 7i92M is set for Steppers so for a 7i76.
But I don't read anything crystal clear that this 7i92 firmware is for 7i76. Am I correct/wrong ?
Thanks for your insight.
Last edit: 7 years 2 months ago by JC10.
7 years 2 months ago #141802 by tommylight
Yes that looks like it is for 7i76 on P2 so just plug it in and power it up.
Be sure to check the jumpers and read the manuals for the cards Before powering up.
7 years 2 months ago #141804 by pl7i92
t is always a best advice to flash the newest avalable
7i76x2 bit file
mesaflash --device 7i92 --addr 10.10.10.10 --write yourbitfile
mesaflash --device 7i92 --addr 10.10.10.10 --reload
repower
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid > test.pin
7 years 2 months ago #141805 by PCW
Replied by PCW on topic Mesa 7i92 firmware for 7i76 ?
Note that you do not need to power cycle the 7I92 if you use the reload command, the reload command does the same thing
(reload FPGA from Flash memory)
Moderators: PCW, jmelson
Time to create page: 0.435 seconds
