Mesa 7i92 firmware for 7i76 ?
- JC10
09 Aug 2019 09:58 #141734
by JC10
Mesa 7i92 firmware for 7i76 ? was created by JC10
Hello,
just got a 7i92 for the first time. I used only 6i25 so far with a 7i77 and it was a bundle pre-programmed.
Do I need a special 7i92 firmware to operate with the 7i76 ? If yes, where do i get it ?
Thanks for help.
Thanks for help.
- Thank you received: 7497
09 Aug 2019 10:04 #141736
Replied by tommylight on topic Mesa 7i92 firmware for 7i76 ?
You should check with mesaflash for what is already in it,
mesaflash --device 7I92 --addr 10.10.10.10 --readhmid
That will show the pins for the existing firmware.
Go to mesanet.com, choose "anything io" or similar on the left side menu, find the 7i92 and there is a link to a zip file with all the firmwares for it.
- JC10
09 Aug 2019 17:27 - 09 Aug 2019 17:30 #141799
by JC10
Replied by JC10 on topic Mesa 7i92 firmware for 7i76 ?
Hello TommyLight,
thanks for your answer.
The result of your line of commands gave :
My 7i92 is a M version with a DB25 connectore on P2.
Here above, when I see that there is no IO connections on P1 and many IO connections for steppers on P2 , I would say that the firmware on this 7i92M is set for Steppers so for a 7i76.
But I don't read anything crystal clear that this 7i92 firmware is for 7i76. Am I correct/wrong ?
Thanks for your insight.
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort None
3 21 IOPort None
16 22 IOPort None
4 23 IOPort None
17 24 IOPort None
5 25 IOPort None
6 26 IOPort None
7 27 IOPort None
8 28 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort None
13 33 IOPort NoneMy 7i92 is a M version with a DB25 connectore on P2.
Last edit: 09 Aug 2019 17:30 by JC10.
09 Aug 2019 17:35 #141802
Yes that looks like it is for 7i76 on P2 so just plug it in and power it up.
Be sure to check the jumpers and read the manuals for the cards Before powering up.
- pl7i92
- Thank you received: 358
09 Aug 2019 17:56 #141804
by pl7i92
Replied by pl7i92 on topic Mesa 7i92 firmware for 7i76 ?
t is always a best advice to flash the newest avalable
7i76x2 bit file
mesaflash --device 7i92 --addr 10.10.10.10 --write yourbitfile
mesaflash --device 7i92 --addr 10.10.10.10 --reload
repower
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid > test.pin
7i76x2 bit file
repower
- Thank you received: 5335
09 Aug 2019 18:08 #141805
Replied by PCW on topic Mesa 7i92 firmware for 7i76 ?
Note that you do not need to power cycle the 7I92 if you use the reload command, the reload command does the same thing
(reload FPGA from Flash memory)
- CMB
23 Jul 2020 19:30 #175565
by CMB
Replied by CMB on topic Mesa 7i92 firmware for 7i76 ?
Hi, I have a 7i92 with two 7i76 boards and am using the latest 7i92_7i76x2D bitfile.
Can I get a bitfile that swaps the last two stepgens on P1 (StepGens 8&9) for two PWMGens?
Thanks!
Thanks!
24 Jul 2020 00:27 #175589
The following user(s) said Thank You: CMB
- CMB
24 Jul 2020 01:31 #175590
by CMB
Thank you very much!
Time to create page: 0.308 seconds
