How to connect Sir88 to mesa board and linuxcnc
- aleksamc
- Thank you received: 67
14 Aug 2019 17:08 #142130
by aleksamc
How to connect Sir88 to mesa board and linuxcnc was created by aleksamc
Dear specialists,
I hope to retrofit old biesse cnc machine using mesa boards.
It has broken PC.
Situation very common:
- 3 servomotors with analog comand inputs
- encoder inputs (not sure what voltage)
- many field mechanisms.
My question is about input/output modules that drives field mechanisms:
-8 modules of CNI Sir88 that conected through RS485 interface.
Two of them are in cabinet (relay output), others are installed in machine automation.
I don't have any documentation to this modules nor I don't know what interface is used to communication (supposedly ModBus). But my task is: to connect this modules to linuxcnc, all other tasks should do mesa boards.
Can any body help my with this?
It has broken PC.
- aleksamc
14 Aug 2019 17:34 #142135
by aleksamc
Replied by aleksamc on topic How to connect Sir88 to mesa board and linuxcnc
Realy found answer for my question. If that modules are using Modbus, that I can connect with help of Ladder Logic.
I will study this in more detail.
But how to connect PC to modbus and to configure Port in phisical dimension (where to connect wires)?
- pl7i92
- Thank you received: 358
14 Aug 2019 17:46 #142136
by pl7i92
Replied by pl7i92 on topic How to connect Sir88 to mesa board and linuxcnc
what servo motors are connected to the driver
can you give us a plate image
modbus drives are som hard to get going
not many posts here on that
we most use cheep analog servos that fit the standard boards for 200USD
- aleksamc
14 Aug 2019 18:20 - 14 Aug 2019 18:22 #142144
by aleksamc
>>CACR-SR05BE
Currently I don't have question to Servodrives.
They are old ones that have +/- (2V to 10V) speed reference input.
and encoder outputs to CNC-board.
I have no experiance with ModBus. And it's realy crussial issue.
Last edit: 14 Aug 2019 18:22 by aleksamc.
- Thank you received: 1470
14 Aug 2019 19:00 #142150
Replied by Todd Zuercher on topic How to connect Sir88 to mesa board and linuxcnc
The biggest problem I foresee is, as far as I know Modbus connections In Linuxcnc are in userspace and are not realtime. This works ok for some things such as controlling a spindle's VFD, or a tool changer, but maybe not so well for something else, like a home or limit switches or controlling a servo.
- Thank you received: 4648
14 Aug 2019 20:40 #142160
I think that Classic Ladder Modbus is Realtime (I have never used it) but probably only if connected via a serial port rather than USB-to-Modbus.
Replied by andypugh on topic How to connect Sir88 to mesa board and linuxcnc
- aleksamc
15 Aug 2019 07:54 - 15 Aug 2019 07:55 #142203
by aleksamc
Thank you Todd and Andypugh,
As Mesa board has it's own Inputs/Outputs, RealTime switches I'll connect directly to it.
But using that modbus modules that are installed is realy makes job easier, moreover, a lot of signals are at machine side, not in Cabinet.
As I said, I have no experiance with modbus, I was wrong a little.
I made automation on PLC S7-1200 (Siemens) and Modbus connections to spindles. I know what it is, and what problems I could have.
But linuxcnc has it's own development (that I don't know complitly) and how to work with that modbus I don't know currently.
But now, I make such main desicion:
Linuxcnc supports Modbus, and I can rely on it in my retrofit complitly.
Last edit: 15 Aug 2019 07:55 by aleksamc.
- aleksamc
23 Aug 2019 16:14 #142976
by aleksamc
I've get unswer about this I/O boards.
All their boards use FieldBus.
Does linuxcnc supports filedbus?
23 Aug 2019 16:43 #142977
Don't know what "FieldBus" is.
According to Wikipedia it is a general term and could refer to one of many different protocols, one of which is Modbus.
23 Aug 2019 16:48 #142978
The more I think about it, I don't think it is realtime. That is why, in order to use Modbus with ClassicLadder you have to have to have the user-space part of it (the GUI) active for Modbus to work.
linuxcnc.org/docs/html/ladder/classic-ladder.html#_modbus
Time to create page: 0.154 seconds
