Help understanding and selecting cards, 7i76E/7I96/7i95?
12 Oct 2019 09:51 #147732 by Doxs_Roxs
Hello
I have been reading a bit on the different cards and I frankly need help understanding the differences between them.
I currently have an old Skyfire CNC mill that I plan to change over to mesa card control and Linuxcnc.
I have some sort of USB interfaced controller with mach 3 running on a PC at the moment.
This is controlled by Leadshine HBS57 hybrid servo drive controllers, they are clearly labelled with signal inputs etc. so I assume I can get them to work. I also have a VFD running a 24k rpm spindle, I assume that is no problem with either of these cards.
I do think I will need to change limit switches etc. so I am prepared for that.
I plan to exchange the PC to an old server pc with some proper ECC ram etc. for maximum stability and hopefully a small touch screeen to go with that.
For example, the 7i76E seem to be pretty common 5 axis capable card with lots of input/output, but it seems to be older then the others, are there any obvious disadvantages with it when compared to the other cards?
7i96 seem to be quite similar with 5 axis control and half the price with reduced IO options? If so, I would expect this card to be the most common card in use, but from what I can tell, its not. Am I missing something here?
7i95 seem to be quite similar to the 7i76 but 6 axis capable. If I understand this correctly 6 axis is useful if I would like to upgrade to 5 axis + toolchanger?
Im currently leaning towards getting the 7i95 for its 6 axis capability, but I want to make sure I did not miss anything.
12 Oct 2019 10:39 #147733 by tommylight
For your setup a 7i76E would be more than enough. It can also be expanded a lot by adding other cards for steppers, servo, I.O. etc
But if you can afford it, get the 7i95 as it has also encoder feedback built in, so if you want to add glass scales later, you have that covered. Linuxcnc does support dual feedback devices per axis.
The following user(s) said Thank You: Doxs_Roxs
12 Oct 2019 13:04 #147735 by Hakan
My highly personal understanding is that the 7i76e has been around for some time and is very well suited for a stepper motor machine, it has analog spindle control and lots of inputs so is suitable for a small panel. But things have changed, the spindle is often controlled by some usb dongle, a touch screen and handheld usb-based mpg are often used, reducing the i/o need. The 7i96 is a response to that and cost less and is more attractive. It is relatively new so not so many out there yet. The 7i95 is a suited for the many servo-drives that use step/dir as control-method and has the corresponding encoder inputs. So if you know that you will need encoders for the axiss go for the 7i95. If your spindle controi is via usb go for the 7i96. You can always add encoder interface afterwards shoud you need it, I myself use 7i76e with a 7i85s and like that a lot. Today I might have bought the 7i96 fot my lathe with stepper motors and the 7i95 for the milling machine with stepper motors and linear scale feedback.
12 Oct 2019 14:40 #147737 by pl7i92
hi as you already got the parport settings
even a 7i92 at less then 100USD is good to go eth and hardware stepping
but a 7i96 is a best guess if you only want to upgrade
the 7i76e will boost you to a match higher level
07 Aug 2021 12:47 #217116 by ianlowe
I am interested in the 7i95, for the 6 axis and encoder interface this board supports. Its a shame they didn't add the spindle support like the 7i76e, What is the best way to wire spindle control to the 7i95 as the manual does not reference this at all. I would like an ATC spindle driven with VFD and encoder for ridged tapping etc.
Regards
Ian
07 Aug 2021 12:50 #217117 by ianlowe
Which board did you settle on for your Skyfire upgrade
01 Sep 2021 03:25 #219303 by Ingo
I'm also very interested in the 7i95 as Ian said. Could someone explain to me how I can use an analog spindle on this board? For example, is it possible to communicate with a Delta inverter?
Ingo
01 Sep 2021 14:14 #219339 by PCW
The 7I95 has no analog spindle output, but you can and an external
PWM --> analog converter
01 Sep 2021 16:38 #219352 by Ingo
Can you tell if it is a Mesa, which is the external PWM model -> analog converter?
02 Sep 2021 23:17 #219468 by andypugh
Spinx1
Moderators: PCW, jmelson
Time to create page: 0.406 seconds
