Wiring a Chinese servo to a 7i77. Setup for yet another newbie
7 years 2 weeks ago #147915 by SPH
I said 'powers off' but I don't actually know what it's doing. Before I plugged the TB5 connector in I had the top left orange led and the middle two orange led's lit. They go out when the plug is connected.
7 years 2 weeks ago - 7 years 2 weeks ago #147917 by SPH
With little else to try switched the +-10 wires and replugged them. The board doesn't shut down now.
When the drive plug is connected I read 4.8v between pins 3 and 4 on the TB5 connector and if I enable the drive it runs at something like 750rpm. As you'd expect, i guess, for an output of 4.8v. If I disconnect the TB5 plug the pins go back to 0v.
Anyone have any insight on those drive pins? I don't know if I've actually found the issue or just a way to make it not crash. As it is now I've got pin 25 from the drive going to TB5 pin 3 and 13 to TB5 pin 4.
Last edit: 7 years 2 weeks ago by SPH.
7 years 2 weeks ago - 7 years 2 weeks ago #147918 by SPH
God, I'm an idiot and am lucky I didn't cook something. I'd read so many posts about people wiring things backwards and had even said to myself "I wont be that guy", well, I'm that guy too. I had the encoder plug wired back to front. 1 as 8 etc. So I was getting small signs of life in the HAL config page but my DRO wasn't counting. What I thought was pin 3 on the 7i77 TB5 was actually pin 6 and therefor was sending 5v to the ground on the servo drive and then getting back fed to the +-10 circuit.
Lucky the board seems to have been able to handle it.
Now that the wiring is around the right way with no wayward voltages everything is working nicely!
I have a motor that's actually tuned half ok! I've only had to change one parameter in the drive and that was to put it into speed control which is quite a surprise, don't know if it's a fluke or what but all I've had to do is connect it and tune via the calibration screen. Just a bare motor mind you, it might be a different story once everythings connected up.
One thing that's struck me with the HAL scope and watching the DRO now the first servo is connected is just how damn instant everything is. I'd always hated how mach3 felt like you were driving it with a pole, always seeing things after they happened.
It's awesome being able to put my hand on the motor shaft and see the few tiny vibrations I've still got reflected in the DRO.
Still a long way to go, I'll likely have a lot of things to change once I get the motors in place and can actually tell which way they should be turning and put some load on them but all in all a far better end to the day than it was looking like a few hours ago.
Oh! I'm still not confident I know how to hook up the drive enable. If someone could spell it out for me I'd really appreciate it. For someone who considders CNC a favourite hobby, basic electronics still catch me out often enough.
Pretty sure I need to send +24v to pin 9 on the drive and - to pin 6? The answer will seem really obvious in the morning no doubt.
Thanks again all.
7 years 2 weeks ago #147922 by tommylight
You do not need to send anything, one of hose pins is the output signal power supply, the other is the input that enables the drives.
Take a multimeter set it to OHM ( usually 200 ) or to test for shorts with a buzzer if it is an auto DVM, connect the probes to those two pins and check if it enables the drive. Check the polarity of the probes when it enables and wire them to Mesa accordingly.
7 years 2 weeks ago #147943 by bevins
tommylight wrote:
SPH wrote: TB3 PIN FUNCTION DIR
1 QA0 TO 7I77 PA+ pin 20
2 /QA0 TO 7I77 PA- pin19
3 GND FROM 7I77 GND pin 1
4 QB0 TO 7I77 PB+ pin 18
5 /QB0 TO 7I77 PB- pin 17
6 +5V FROM 7I77 do not connect
7 IDX0 TO 7I77 do not connect
8 /IDX0 TO 7I77 do not connect
Also +-10V from Mesa to pin 25 and 13 respectively .
Drive enable from Mesa to pin 29 and 9.
Why are you not connecting the index of the encoders?
7 years 2 weeks ago #147946 by SPH
Let me know how the index connects and I’ll wire it in. Perhaps tommylight’s directions were just the basics?
The drive enable is so obvious now, thanks. Don’t know what was thinking.
Moderators: PCW, jmelson
Time to create page: 0.254 seconds
