How to change ECP mode to EPP mode
6 years 11 months ago #150945 by viski
this is from lspci -v command :
01:00.0 Parallel controller: Oxford Semiconductor Ltd Device c110 (prog-if 02 [ECP])
Subsystem: Oxford Semiconductor Ltd Device c110
Flags: bus master, fast devsel, latency 0, IRQ 16
I/O ports at 2008
I/O ports at 2000
Capabilities: <access denied>
Kernel driver in use: parport_pc
I need to configure it into EPP mode to use it with mesaflash.
mesaflash --device 7i90 --epp --addr 0x2008 --readhmid
The following user(s) said Thank You: Leon82
6 years 11 months ago #150949 by Leon82
On my motherboard in the bios there is a setting for it. Mine was defaulted to epp, but it is an onboard legacy connection
6 years 11 months ago #150951 by viski
This is parport on PCI slot , i can not configure in BIOS.
6 years 11 months ago #150953 by PCW
Did you try both addresses?
What was the result?
If the port has a IEEE1284 compatible register set, both
LinuxCNC amd Mesaflash should set it into EPP mode
How is the 7I90 connected to the card?
Is the 7I90 configured properly? (only yellow power light on after power up)
Moderators: PCW, jmelson
Time to create page: 0.064 seconds
