Mesa 7i96 Output Wiring
6 years 2 months ago #178102 by tommylight
Replied by tommylight on topic Mesa 7i96 Output Wiring
tommylight wrote: Connect gnd and IN to the mesa board, they just need the input to gnd to switch over.
In case it does not work, reverse the gnd and in pins.
Just in case it got lost in there.
6 years 2 months ago #178121 by AgentWD40
Replied by AgentWD40 on topic Mesa 7i96 Output Wiring
Your answer is what I was confused about. Is my drawing incorrect?
forum.linuxcnc.org/27-driver-boards/3845...iring?start=0#178037
6 years 2 months ago #178124 by Mud
Replied by Mud on topic Mesa 7i96 Output Wiring
PCW wrote: No, the diode should be across the relay coil
for example
Sourcing drive:
+24V --> OUT+ --> OUT- --> COIL+ --> COIL- --> GND
or
Sinking drive:
+24V --> COIL+ --> COIL- --> OUT+ --> OUT- --> GND
Diode always goes from COIL+ to COIL- (cathode=band to COIL +)
If you are unsure, test the relay+diode with a mechanical switch
replacing the 7I96 OUT+- pins
As attached?
I'm a bit gun shy about hooking up my torch switch - I plan to use a multimeter to check voltage and current, but the polarity of the 7i96 output switches keeps breaking my brain. I read in another thread that an additional relay isn't necessary (at least for a hypertherm which uses a low switch voltage/current), but I'm tempted to use one nonetheless. I assume the alternative is to just loop through an output pair since the plasma is supplying the signal voltage for the switch (assuming it's a reasonable voltage/current and I send signal+ to OUT+ and signal- to OUT-).
The manual could be more friendly, i.e.
"Inductive loads must have a flyback diode. The output polarity must be observed (reversed outputs will be stuck-on)."
I can see what you mean now, but I interpreted that as flyback diode across the 7i96 outputs (which seemed to make sense since you could force current to only flow in one direction). I was also interpreting the statement about reversed outputs with respect to a diode across the outputs, which seemed to make sense since you would short the switch if you attached the diode in one direction. Big dumb.
It also doesn't say if the polarity sign convention is current flow, or just hook neg-neg, pos-pos. Hence the confusion. I empathise with AgentWD40, I need drawings to understand :blush:
6 years 2 months ago #178125 by PCW
Replied by PCW on topic Mesa 7i96 Output Wiring
AgentWD40 wrote: Your answer is what I was confused about. Is my drawing incorrect?
Yes, that looks correct if I understand those relay modules
The following user(s) said Thank You: AgentWD40
6 years 2 months ago #178126 by PCW
Yes, those drawings are correct
OUT+ must be more positive than OUT-, otherwise the inherent diode
in the output MOSFET will conduct (so the switch will appear to be on if reversed)
This is not related to the flyback diode which is most often wired directly
across the relay coil.
The following user(s) said Thank You: Mud
6 years 2 months ago #178127 by tommylight
I have those relay modules, the 5V version and they have a jumper for setting the input.
Go with PCW's version and check that the jumper is set for positive triggering.
Moderators: PCW, jmelson
Time to create page: 0.439 seconds
