5i25, 6i25, 7i92, firmware request.
6 years 6 months ago #163670 by tommylight
Hold on just a sec, i have that set in hal as mode 2, but found some other error in the hal file, namely the same pwmgen being set to mode 2 and then to mode 1 lower in the hal.
I found it making sure i did set it.....
Sorry for all the trouble, back in a jiffy with more results and a new video.
Thank you.
6 years 6 months ago #163671 by tommylight
PCW, thank you.
That was it, it was set to 2 and then 1 later on in hal.
Sorry for the mess.
It work perfectly.
5 years 10 months ago - 5 years 10 months ago #191796 by tommylight
On request from youtube user, attached is the config for this setup, both for parallel and Mesa 5i25/6i25. For Mesa 7i92 use the text editor and use the "search and replace" function to substitute the card name.
Last edit: 5 years 10 months ago by tommylight. Reason: attacment forgoten.
5 years 10 months ago #191798 by tommylight
For some reason forgot to add the video of it working properly.
5 years 2 months ago #218435 by BigDo
can i also use this firmware for a 7i98 Anything I/O Ethernet Controller?
5 years 2 months ago - 5 years 2 months ago #218439 by PCW
No, you must use firmware specifically written for the 7I98.
Using firmware for a different card will likely brick the 7I98
Here is sv8d firmware for a 7I98:
File Name: 7i98_sv8d.zip
File Size:80.55 KB
Last edit: 5 years 2 months ago by PCW.
The following user(s) said Thank You: tommylight, BigDo
Moderators: PCW, jmelson
Time to create page: 0.195 seconds
