7c80 and ODROID-C4
6 years 5 months ago #167528 by escott
7c80 and ODROID-C4 was created by escott
I am planning on using a 7c80 for a mill controller upgrade project. I was wondering if the choice of an ODROID-C4 rather than a Pi 4B would a workable option? I would prefer the eMMC memory over an SD card.
Thanks,
Edward
6 years 5 months ago #167531 by PCW
Replied by PCW on topic 7c80 and ODROID-C4
You _might_ be able to run a 7C80 from the ODROIDs SPI port using the hm2_spi driver
but its not a given... A Ethernet connected card might be safer bet with the ODROID
The following user(s) said Thank You: escott
6 years 5 months ago #167533 by escott
Replied by escott on topic 7c80 and ODROID-C4
So something like a 7I76E, a din rail mounted ethernet switch and power supply for the odroid?
6 years 5 months ago #167534 by tommylight
Replied by tommylight on topic 7c80 and ODROID-C4
escott wrote: So something like a 7I76E, a din rail mounted ethernet switch and power supply for the odroid?
No ethernet switch!!!
Direct connection between Mesa and PC or Odroid.
And this is from a guy that knows that will work with some switches, but it is not for controlling the machine.
6 years 5 months ago #167535 by escott
I suppose USB ethernet for file transfer would be OK?
6 years 5 months ago #167537 by tommylight
escott wrote: I suppose USB ethernet for file transfer would be OK?
Yes it will, USB WiFi also.
Moderators: PCW, jmelson
Time to create page: 0.213 seconds
