Mesa 7i96 5v power input
6 years 5 months ago #168060 by EddieM
I have received my Mesa 7i96. I am rebuilding my first cnc router from scratch. Migrating from Arduino Uno GRBL and mostly the rewiring is obvious.
The manual indicates a 5v and gnd input on T3 and also two 5v and gnd inputs on TB3 pin 20-23. Do I need to supply multiple 5v inputs? Do they supply different functionalities on the board or are they actually the same connection? If I supply T3 then can I use the TB3 connections for outputs like for power to limit switches circuits?
Eddie
6 years 5 months ago #168063 by PCW
Replied by PCW on topic Mesa 7i96 5v power input
The 5V connections are all common so yes, you can use the TB3 pins as
5V outputs if its convenient
The following user(s) said Thank You: EddieM
6 years 5 months ago #168789 by persei8
Replied by persei8 on topic Mesa 7i96 5v power input
Is the 7i96 schematic drawing available or is that proprietary?
6 years 5 months ago #168797 by PCW
I don't have a pdf-ized schematic for the 7I96 but I can make one
There's nothing proprietary,
If you have a specific question I can answer it.
6 years 5 months ago #168815 by persei8
Nothing specific at the current time. If it's not too much trouble, I would be interested in having a schematic in PDF or even Eagle. Thanks.
Moderators: PCW, jmelson
Time to create page: 0.279 seconds
