Gecko G320X - Closed Loop - Mesa 7i76E + 7i85
- hoffb77
- Thank you received: 21
28 May 2020 20:26 #169265
by hoffb77
Gecko G320X - Closed Loop - Mesa 7i76E + 7i85 was created by hoffb77
I am currently running a Porter/Powermatic 3 axis bed mill on Gecko 320X's with a Pico USC+Gecko Drive Interface.
My question is about my new project. I have a Millennium 4200 that I have installed 320X's but this time I'm stepping away from the parport and went with a Mesa 7i76E. Like the Pico setup I want to close the loop at the controller. I am running differential encoders to a 7i85. Do I simply jump the +A and +B for each axis from the 7i85 to the Gecko 320X? is there a "proper" way to appease the requirements of the drive without degrading the signal at the controller?
Thank You
Thank You
- bbsr_5a
- Thank you received: 106
29 May 2020 01:48 #169271
by bbsr_5a
Replied by bbsr_5a on topic Gecko G320X - Closed Loop - Mesa 7i76E + 7i85
Hi
why dident you go for 7i92 and a 7i77 in first place to get a real servo system the gecko suport this setup
dont forget the GND to be bridged to the controller THIS woudtent be nessesary at the 7i77 and EMI is off the system
DID you ask here about the items to use or simply get some infos around
- Thank you received: 7506
29 May 2020 01:55 #169274
Replied by tommylight on topic Gecko G320X - Closed Loop - Mesa 7i76E + 7i85
Gecko 320x are step/dir drives, so will not work with 7i77.why dident you go for 7i92 and a 7i77 in first place to get a real servo system the gecko suport this setup
29 May 2020 01:59 #169276
Jumping the same encoder output to two inputs usually works, but might be to much for some encoders, so the risk of missing the counts is present.
The best solution would be to wire A+ and B+ to the 7i85, A- and B- to the Gecko, set the 7i85 for single ended encoders.I am running differential encoders to a 7i85. Do I simply jump the +A and +B for each axis from the 7i85 to the Gecko 320X? is there a "proper" way to appease the requirements of the drive without degrading the signal at the controller?
- bbsr_5a
29 May 2020 02:00 #169277
by bbsr_5a
the amptzru port accept +-10V if you setup the drives to VEL mode
- hoffb77
29 May 2020 08:11 #169312
by hoffb77
Replied by hoffb77 on topic Gecko G320X - Closed Loop - Mesa 7i76E + 7i85
I will split them off like that and report my findings.
I have the encoders already ran to the 7i85. I will set the jumpers to ttl. Would there be an issue using the - terminal to jump the signal to the gecko from there?
29 May 2020 08:29 #169314
Leave it as is, jump the wires to the gecko, do NOT jump the +5V, just gnd and AB.
Check if gecko AND Linuxcnc can count properly, if they do, leave it at that, if they do not, then some splitting is in order.
In the latter case, the answer to your question would be: YES.
- Thank you received: 5337
29 May 2020 08:51 #169317
Replied by PCW on topic Gecko G320X - Closed Loop - Mesa 7i76E + 7i85
In general I would have reservations about doing this, that is, connecting to a drives
encoder that was intended for local feedback only. One reason is that I think its likely
that the Gecko encoder ground is the same as the motor power ground, so will have
a lot of common mode noise. This coupled with the fact that the encoder signals
are single ended (TTL levels) is like to compromise the controller and drive signal
integrity
integrity
- hoffb77
29 May 2020 09:16 #169319
by hoffb77
You are correct. On my other setup I can pull +5 on a DVM using the drive power ground and probing the enc+ and the common +5 on the Pico.
- hoffb77
07 Jun 2020 17:34 - 07 Jun 2020 17:36 #170540
by hoffb77
Do you have any insight on encoder signal conditioners? Automation Direct sells an affordable one. There are several top end manufacturers making them at top end prices. Allen Bradley makes one at $100 per output, unfortunately it has 8 outputs.
BB-845
I'd go with different drives and I may down the road but the G320X and the Machdrives seem to be the only ready available and affordable drives with 20 amp capacity. They both require feedback to the drive. My current setup runs well. The Gecko's push big iron around without overheating for hours on end. I am upgrading to the Mesa setup to add more functionality and reliability. My major concern is the encoder signal integrity to the 7i85.
Automation Direct modules
I plan to purchase 3 of the FC-ISO-D modules. Would there be any benefit using the -C mod(open collector)?
Last edit: 07 Jun 2020 17:36 by hoffb77. Reason: bad grammer
Time to create page: 0.168 seconds
