Mesa 7i76 - can't read inputs on field inputs (TB5, TB6)
  • anli
  • Topic Author
  • Junior Member
  • Junior Member
6 years 4 months ago #170290 by anli
Hello,
I want to read the field inputs on TB5 and TB6 on my brand new Mesa 7i76e card. If I run halcmd and connect via halcmd: loadrt hm2_eth board_ip=192.168.1.121 the following is shown:
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:10:45:c5 hm2_eth: discovered 7I76E-16 hm2/hm2_7i76e.0: Low Level init 0.15 hm2/hm2_7i76e.0: Smart Serial Firmware Version 43 Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv hm2/hm2_7i76e.0: 51 I/O Pins used: hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output) hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output) hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output) hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output) hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output) hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output) hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output) hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output) hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output) hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output) hm2/hm2_7i76e.0: IO Pin 010 (P1-07): Smart Serial Interface #0, pin tx0 (Output) hm2/hm2_7i76e.0: IO Pin 011 (P1-08): Smart Serial Interface #0, pin rx0 (Input) hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input) hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input) hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input) hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort hm2/hm2_7i76e.0: registered
I'm not sure if 7I76E-16 is the right board name. How can I read inputs 0-31 on TB6/TB5 (with halshow)? Thank you for your help in advance!
6 years 4 months ago - 6 years 4 months ago #170291 by PCW
To get a list of all pins, parameters, signals and functions, run
halcmd show all
(with LinuxCNC running)
You cannot read the inputs or set outputs without LinuxCNC running
or seting up a thread with halcmd and addf-ing the low level
read and write functions to that thread
Last edit: 6 years 4 months ago by PCW.
  • anli
  • Topic Author
  • Junior Member
  • Junior Member
6 years 4 months ago #170313 by anli
Thank you for your super-fast answer!
I tried
halcmd show all
with linuxcnc running. This is the answer:
Loaded HAL Components: ID Type Name PID State 52 User halcmd2469 2469 ready 46 User gmoccapy 1933 ready 44 User inihal 1929 ready 33 User hal_manualtoolchange 1920 ready 29 RT pid ready 26 RT hm2_eth ready 23 RT hostmot2 ready 20 RT __servo-thread ready 19 RT motmod ready 16 RT trivkins ready 10 User halui 1878 ready 4 User iocontrol 1876 ready Component Pins: Owner Type Dir Value Name 19 float OUT 0 axis.a.eoffset 19 bit IN FALSE axis.a.eoffset-clear 19 s32 IN 0 axis.a.eoffset-counts 19 bit IN FALSE axis.a.eoffset-enable 19 float OUT 0 axis.a.eoffset-request 19 float IN 0 axis.a.eoffset-scale 19 float IN 1 axis.a.jog-accel-fraction 19 s32 IN 0 axis.a.jog-counts 19 bit IN FALSE axis.a.jog-enable 19 float IN 0 axis.a.jog-scale 19 bit IN FALSE axis.a.jog-vel-mode 19 bit OUT FALSE axis.a.kb-jog-active 19 float OUT 0 axis.a.pos-cmd 19 float OUT 0 axis.a.teleop-pos-cmd 19 bit OUT FALSE axis.a.teleop-tp-enable 19 float OUT 0 axis.a.teleop-vel-cmd 19 float OUT 0 axis.a.teleop-vel-lim 19 bit OUT FALSE axis.a.wheel-jog-active 19 float OUT 0 axis.b.eoffset 19 bit IN FALSE axis.b.eoffset-clear 19 s32 IN 0 axis.b.eoffset-counts 19 bit IN FALSE axis.b.eoffset-enable 19 float OUT 0 axis.b.eoffset-request 19 float IN 0 axis.b.eoffset-scale 19 float IN 1 axis.b.jog-accel-fraction 19 s32 IN 0 axis.b.jog-counts 19 bit IN FALSE axis.b.jog-enable 19 float IN 0 axis.b.jog-scale 19 bit IN FALSE axis.b.jog-vel-mode 19 bit OUT FALSE axis.b.kb-jog-active 19 float OUT 0 axis.b.pos-cmd 19 float OUT 0 axis.b.teleop-pos-cmd 19 bit OUT FALSE axis.b.teleop-tp-enable 19 float OUT 0 axis.b.teleop-vel-cmd 19 float OUT 0 axis.b.teleop-vel-lim 19 bit OUT FALSE axis.b.wheel-jog-active 19 float OUT 0 axis.c.eoffset 19 bit IN FALSE axis.c.eoffset-clear 19 s32 IN 0 axis.c.eoffset-counts 19 bit IN FALSE axis.c.eoffset-enable 19 float OUT 0 axis.c.eoffset-request 19 float IN 0 axis.c.eoffset-scale 19 float IN 1 axis.c.jog-accel-fraction 19 s32 IN 0 axis.c.jog-counts 19 bit IN FALSE axis.c.jog-enable 19 float IN 0 axis.c.jog-scale 19 bit IN FALSE axis.c.jog-vel-mode 19 bit OUT FALSE axis.c.kb-jog-active 19 float OUT 0 axis.c.pos-cmd 19 float OUT 0 axis.c.teleop-pos-cmd 19 bit OUT FALSE axis.c.teleop-tp-enable 19 float OUT 0 axis.c.teleop-vel-cmd 19 float OUT 0 axis.c.teleop-vel-lim 19 bit OUT FALSE axis.c.wheel-jog-active 19 float OUT 0 axis.u.eoffset 19 bit IN FALSE axis.u.eoffset-clear 19 s32 IN 0 axis.u.eoffset-counts 19 bit IN FALSE axis.u.eoffset-enable 19 float OUT 0 axis.u.eoffset-request 19 float IN 0 axis.u.eoffset-scale 19 float IN 1 axis.u.jog-accel-fraction 19 s32 IN 0 axis.u.jog-counts 19 bit IN FALSE axis.u.jog-enable 19 float IN 0 axis.u.jog-scale 19 bit IN FALSE axis.u.jog-vel-mode 19 bit OUT FALSE axis.u.kb-jog-active 19 float OUT 0 axis.u.pos-cmd 19 float OUT 0 axis.u.teleop-pos-cmd 19 bit OUT FALSE axis.u.teleop-tp-enable 19 float OUT 0 axis.u.teleop-vel-cmd 19 float OUT 0 axis.u.teleop-vel-lim 19 bit OUT FALSE axis.u.wheel-jog-active 19 float OUT 0 axis.v.eoffset 19 bit IN FALSE axis.v.eoffset-clear 19 s32 IN 0 axis.v.eoffset-counts 19 bit IN FALSE axis.v.eoffset-enable 19 float OUT 0 axis.v.eoffset-request 19 float IN 0 axis.v.eoffset-scale 19 float IN 1 axis.v.jog-accel-fraction 19 s32 IN 0 axis.v.jog-counts 19 bit IN FALSE axis.v.jog-enable 19 float IN 0 axis.v.jog-scale 19 bit IN FALSE axis.v.jog-vel-mode 19 bit OUT FALSE axis.v.kb-jog-active 19 float OUT 0 axis.v.pos-cmd 19 float OUT 0 axis.v.teleop-pos-cmd 19 bit OUT FALSE axis.v.teleop-tp-enable 19 float OUT 0 axis.v.teleop-vel-cmd 19 float OUT 0 axis.v.teleop-vel-lim 19 bit OUT FALSE axis.v.wheel-jog-active 19 float OUT 0 axis.w.eoffset 19 bit IN FALSE axis.w.eoffset-clear 19 s32 IN 0 axis.w.eoffset-counts 19 bit IN FALSE axis.w.eoffset-enable 19 float OUT 0 axis.w.eoffset-request 19 float IN 0 axis.w.eoffset-scale 19 float IN 1 axis.w.jog-accel-fraction 19 s32 IN 0 axis.w.jog-counts 19 bit IN FALSE axis.w.jog-enable 19 float IN 0 axis.w.jog-scale 19 bit IN FALSE axis.w.jog-vel-mode 19 bit OUT FALSE axis.w.kb-jog-active 19 float OUT 0 axis.w.pos-cmd 19 float OUT 0 axis.w.teleop-pos-cmd 19 bit OUT FALSE axis.w.teleop-tp-enable 19 float OUT 0 axis.w.teleop-vel-cmd 19 float OUT 0 axis.w.teleop-vel-lim 19 bit OUT FALSE axis.w.wheel-jog-active 19 float OUT 0 axis.x.eoffset 19 bit IN FALSE axis.x.eoffset-clear 19 s32 IN 0 axis.x.eoffset-counts 19 bit IN FALSE axis.x.eoffset-enable 19 float OUT 0 axis.x.eoffset-request 19 float IN 0 axis.x.eoffset-scale 19 float IN 1 axis.x.jog-accel-fraction 19 s32 IN 0 axis.x.jog-counts 19 bit IN FALSE axis.x.jog-enable 19 float IN 0 axis.x.jog-scale 19 bit IN FALSE axis.x.jog-vel-mode 19 bit OUT FALSE axis.x.kb-jog-active 19 float OUT 0 axis.x.pos-cmd 19 float OUT 0 axis.x.teleop-pos-cmd 19 bit OUT FALSE axis.x.teleop-tp-enable 19 float OUT 0 axis.x.teleop-vel-cmd 19 float OUT 0 axis.x.teleop-vel-lim 19 bit OUT FALSE axis.x.wheel-jog-active 19 float OUT 0 axis.y.eoffset 19 bit IN FALSE axis.y.eoffset-clear 19 s32 IN 0 axis.y.eoffset-counts 19 bit IN FALSE axis.y.eoffset-enable 19 float OUT 0 axis.y.eoffset-request 19 float IN 0 axis.y.eoffset-scale 19 float IN 1 axis.y.jog-accel-fraction 19 s32 IN 0 axis.y.jog-counts 19 bit IN FALSE axis.y.jog-enable 19 float IN 0 axis.y.jog-scale 19 bit IN FALSE axis.y.jog-vel-mode 19 bit OUT FALSE axis.y.kb-jog-active 19 float OUT 0 axis.y.pos-cmd 19 float OUT 0 axis.y.teleop-pos-cmd 19 bit OUT FALSE axis.y.teleop-tp-enable 19 float OUT 0 axis.y.teleop-vel-cmd 19 float OUT 0 axis.y.teleop-vel-lim 19 bit OUT FALSE axis.y.wheel-jog-active 19 float OUT 0 axis.z.eoffset 19 bit IN FALSE axis.z.eoffset-clear 19 s32 IN 0 axis.z.eoffset-counts 19 bit IN FALSE axis.z.eoffset-enable 19 float OUT 0 axis.z.eoffset-request 19 float IN 0 axis.z.eoffset-scale 19 float IN 1 axis.z.jog-accel-fraction 19 s32 IN 0 axis.z.jog-counts 19 bit IN FALSE axis.z.jog-enable 19 float IN 0 axis.z.jog-scale 19 bit IN FALSE axis.z.jog-vel-mode 19 bit OUT FALSE axis.z.kb-jog-active 19 float OUT 0 axis.z.pos-cmd 19 float OUT 0 axis.z.teleop-pos-cmd 19 bit OUT FALSE axis.z.teleop-tp-enable 19 float OUT 0 axis.z.teleop-vel-cmd 19 float OUT 0 axis.z.teleop-vel-lim 19 bit OUT FALSE axis.z.wheel-jog-active 46 float OUT 0 gmoccapy.blockheight 46 bit IN FALSE gmoccapy.delete-message 46 bit OUT TRUE gmoccapy.error 46 bit IN FALSE gmoccapy.feed.feed-override.analog-enable 46 bit IN FALSE gmoccapy.feed.feed-override.count-enable 46 s32 IN 0 gmoccapy.feed.feed-override.counts 46 float IN 0 gmoccapy.feed.feed-override.direct-value 46 bit IN FALSE gmoccapy.feed.reset-feed-override 46 bit IN FALSE gmoccapy.h-button.button-0 46 bit IN FALSE gmoccapy.h-button.button-1 46 bit IN FALSE gmoccapy.h-button.button-2 46 bit IN FALSE gmoccapy.h-button.button-3 46 bit IN FALSE gmoccapy.h-button.button-4 46 bit IN FALSE gmoccapy.h-button.button-5 46 bit IN FALSE gmoccapy.h-button.button-6 46 bit IN FALSE gmoccapy.h-button.button-7 46 bit IN FALSE gmoccapy.h-button.button-8 46 bit IN FALSE gmoccapy.h-button.button-9 46 bit IN FALSE gmoccapy.ignore-limits 46 bit IN FALSE gmoccapy.jog.axis.jog-x-minus 46 bit IN FALSE gmoccapy.jog.axis.jog-x-plus 46 bit IN FALSE gmoccapy.jog.axis.jog-y-minus 46 bit IN FALSE gmoccapy.jog.axis.jog-y-plus 46 bit IN FALSE gmoccapy.jog.axis.jog-z-minus 46 bit IN FALSE gmoccapy.jog.axis.jog-z-plus 46 bit IN FALSE gmoccapy.jog.jog-inc-0 46 bit IN FALSE gmoccapy.jog.jog-inc-1 46 bit IN FALSE gmoccapy.jog.jog-inc-2 46 bit IN FALSE gmoccapy.jog.jog-inc-3 46 bit IN FALSE gmoccapy.jog.jog-inc-4 46 bit IN FALSE gmoccapy.jog.jog-inc-5 46 bit IN FALSE gmoccapy.jog.jog-inc-6 46 bit IN FALSE gmoccapy.jog.jog-inc-7 46 float OUT 0 gmoccapy.jog.jog-increment 46 bit IN FALSE gmoccapy.jog.jog-velocity.analog-enable 46 bit IN FALSE gmoccapy.jog.jog-velocity.count-enable 46 s32 IN 0 gmoccapy.jog.jog-velocity.counts 46 float IN 0 gmoccapy.jog.jog-velocity.direct-value 46 bit IN FALSE gmoccapy.jog.turtle-jog 46 float OUT 0 gmoccapy.probeheight 46 float OUT 0 gmoccapy.probevel 46 s32 OUT 0 gmoccapy.program.current-line 46 s32 OUT 0 gmoccapy.program.length 46 float OUT 0 gmoccapy.program.progress 46 bit IN FALSE gmoccapy.rapid.rapid-override.analog-enable 46 bit IN FALSE gmoccapy.rapid.rapid-override.count-enable 46 s32 IN 0 gmoccapy.rapid.rapid-override.counts 46 float IN 0 gmoccapy.rapid.rapid-override.direct-value 46 bit IN FALSE gmoccapy.rapid.reset-rapid-override 46 float OUT 0 gmoccapy.searchvel 46 bit IN FALSE gmoccapy.spc_ang_jog_vel.decrease 46 bit IN FALSE gmoccapy.spc_ang_jog_vel.increase 46 float IN 60 gmoccapy.spc_ang_jog_vel.scale 46 float OUT 6 gmoccapy.spc_ang_jog_vel.scaled-value 46 float OUT 360 gmoccapy.spc_ang_jog_vel.value 46 bit IN FALSE gmoccapy.spc_feed.decrease 46 bit IN FALSE gmoccapy.spc_feed.increase 46 float IN 60 gmoccapy.spc_feed.scale 46 float OUT 1.666667 gmoccapy.spc_feed.scaled-value 46 float OUT 100 gmoccapy.spc_feed.value 46 bit IN FALSE gmoccapy.spc_lin_jog_vel.decrease 46 bit IN FALSE gmoccapy.spc_lin_jog_vel.increase 46 float IN 60 gmoccapy.spc_lin_jog_vel.scale 46 float OUT 2.5 gmoccapy.spc_lin_jog_vel.scaled-value 46 float OUT 150 gmoccapy.spc_lin_jog_vel.value 46 bit IN FALSE gmoccapy.spc_rapid.decrease 46 bit IN FALSE gmoccapy.spc_rapid.increase 46 float IN 60 gmoccapy.spc_rapid.scale 46 float OUT 1.666667 gmoccapy.spc_rapid.scaled-value 46 float OUT 100 gmoccapy.spc_rapid.value 46 bit IN FALSE gmoccapy.spc_spindle.decrease 46 bit IN FALSE gmoccapy.spc_spindle.increase 46 float IN 60 gmoccapy.spc_spindle.scale 46 float OUT 1.666667 gmoccapy.spc_spindle.scaled-value 46 float OUT 100 gmoccapy.spc_spindle.value 46 bit IN FALSE gmoccapy.spindle.reset-spindle-override 46 bit IN FALSE gmoccapy.spindle.spindle-override.analog-enable 46 bit IN FALSE gmoccapy.spindle.spindle-override.count-enable 46 s32 IN 0 gmoccapy.spindle.spindle-override.counts 46 float IN 0 gmoccapy.spindle.spindle-override.direct-value 46 bit IN FALSE gmoccapy.spindle_at_speed_led 46 float IN 0 gmoccapy.spindle_feedback_bar 46 float OUT 0 gmoccapy.tool-diameter 46 bit IN FALSE gmoccapy.toolchange-change 46 bit OUT FALSE gmoccapy.toolchange-changed 46 s32 IN 0 gmoccapy.toolchange-number 46 bit OUT FALSE gmoccapy.toolmeasurement 46 float IN 0 gmoccapy.tooloffset-x 46 float IN 0 gmoccapy.tooloffset-z 46 bit IN FALSE gmoccapy.unlock-settings 46 bit IN FALSE gmoccapy.v-button.button-0 46 bit IN FALSE gmoccapy.v-button.button-1 46 bit IN FALSE gmoccapy.v-button.button-2 46 bit IN FALSE gmoccapy.v-button.button-3 46 bit IN FALSE gmoccapy.v-button.button-4 46 bit IN FALSE gmoccapy.v-button.button-5 46 bit IN FALSE gmoccapy.v-button.button-6 33 bit IN FALSE hal_manualtoolchange.change <== tool-change-request 33 bit IN FALSE hal_manualtoolchange.change_button 33 bit OUT FALSE hal_manualtoolchange.changed ==> tool-change-confirmed 33 s32 IN 0 hal_manualtoolchange.number <== tool-number 10 bit IN FALSE halui.abort 10 float IN 0 halui.axis.a.analog 10 float IN 0 halui.axis.a.increment 10 bit IN FALSE halui.axis.a.increment-minus 10 bit IN FALSE halui.axis.a.increment-plus 10 bit IN FALSE halui.axis.a.minus 10 bit IN FALSE halui.axis.a.plus 10 bit IN FALSE halui.axis.a.select 10 float IN 0 halui.axis.b.analog 10 float IN 0 halui.axis.b.increment 10 bit IN FALSE halui.axis.b.increment-minus 10 bit IN FALSE halui.axis.b.increment-plus 10 bit IN FALSE halui.axis.b.minus 10 bit IN FALSE halui.axis.b.plus 10 bit IN FALSE halui.axis.b.select 10 float IN 0 halui.axis.c.analog 10 float IN 0 halui.axis.c.increment 10 bit IN FALSE halui.axis.c.increment-minus 10 bit IN FALSE halui.axis.c.increment-plus 10 bit IN FALSE halui.axis.c.minus 10 bit IN FALSE halui.axis.c.plus 10 bit IN FALSE halui.axis.c.select 10 float IN 0.2 halui.axis.jog-deadband 10 float IN 0 halui.axis.jog-speed <== jog-speed 10 u32 OUT 0x00000000 halui.axis.selected 10 float IN 0 halui.axis.selected.increment 10 bit IN FALSE halui.axis.selected.increment-minus 10 bit IN FALSE halui.axis.selected.increment-plus 10 bit IN FALSE halui.axis.selected.minus <== jog-selected-neg 10 bit IN FALSE halui.axis.selected.plus <== jog-selected-pos 10 float IN 0 halui.axis.u.analog 10 float IN 0 halui.axis.u.increment 10 bit IN FALSE halui.axis.u.increment-minus 10 bit IN FALSE halui.axis.u.increment-plus 10 bit IN FALSE halui.axis.u.minus 10 bit IN FALSE halui.axis.u.plus 10 bit IN FALSE halui.axis.u.select 10 float IN 0 halui.axis.v.analog 10 float IN 0 halui.axis.v.increment 10 bit IN FALSE halui.axis.v.increment-minus 10 bit IN FALSE halui.axis.v.increment-plus 10 bit IN FALSE halui.axis.v.minus 10 bit IN FALSE halui.axis.v.plus 10 bit IN FALSE halui.axis.v.select 10 float IN 0 halui.axis.w.analog 10 float IN 0 halui.axis.w.increment 10 bit IN FALSE halui.axis.w.increment-minus 10 bit IN FALSE halui.axis.w.increment-plus 10 bit IN FALSE halui.axis.w.minus 10 bit IN FALSE halui.axis.w.plus 10 bit IN FALSE halui.axis.w.select 10 float IN 0 halui.axis.x.analog <== jog-x-analog 10 float IN 0 halui.axis.x.increment 10 bit IN FALSE halui.axis.x.increment-minus 10 bit IN FALSE halui.axis.x.increment-plus 10 bit OUT TRUE halui.axis.x.is-selected 10 bit IN FALSE halui.axis.x.minus <== jog-x-neg 10 bit IN FALSE halui.axis.x.plus <== jog-x-pos 10 float OUT 0 halui.axis.x.pos-commanded 10 float OUT 0 halui.axis.x.pos-feedback 10 float OUT 0 halui.axis.x.pos-relative 10 bit IN FALSE halui.axis.x.select <== axis-select-x 10 float IN 0 halui.axis.y.analog <== jog-y-analog 10 float IN 0 halui.axis.y.increment 10 bit IN FALSE halui.axis.y.increment-minus 10 bit IN FALSE halui.axis.y.increment-plus 10 bit OUT FALSE halui.axis.y.is-selected 10 bit IN FALSE halui.axis.y.minus <== jog-y-neg 10 bit IN FALSE halui.axis.y.plus <== jog-y-pos 10 float OUT 0 halui.axis.y.pos-commanded 10 float OUT 0 halui.axis.y.pos-feedback 10 float OUT 0 halui.axis.y.pos-relative 10 bit IN FALSE halui.axis.y.select <== axis-select-y 10 float IN 0 halui.axis.z.analog <== jog-z-analog 10 float IN 0 halui.axis.z.increment 10 bit IN FALSE halui.axis.z.increment-minus 10 bit IN FALSE halui.axis.z.increment-plus 10 bit OUT FALSE halui.axis.z.is-selected 10 bit IN FALSE halui.axis.z.minus <== jog-z-neg 10 bit IN FALSE halui.axis.z.plus <== jog-z-pos 10 float OUT 0 halui.axis.z.pos-commanded 10 float OUT 0 halui.axis.z.pos-feedback 10 float OUT 0 halui.axis.z.pos-relative 10 bit IN FALSE halui.axis.z.select <== axis-select-z 10 bit IN FALSE halui.estop.activate 10 bit OUT TRUE halui.estop.is-activated 10 bit IN FALSE halui.estop.reset 10 bit IN TRUE halui.feed-override.count-enable 10 s32 IN 0 halui.feed-override.counts 10 bit IN FALSE halui.feed-override.decrease 10 bit IN FALSE halui.feed-override.direct-value 10 bit IN FALSE halui.feed-override.increase 10 float IN 0.1 halui.feed-override.scale 10 float OUT 1 halui.feed-override.value 10 bit OUT FALSE halui.flood.is-on 10 bit IN FALSE halui.flood.off 10 bit IN FALSE halui.flood.on 10 float IN 0 halui.joint.0.analog 10 bit OUT FALSE halui.joint.0.has-fault 10 bit IN FALSE halui.joint.0.home 10 float IN 0 halui.joint.0.increment 10 bit IN FALSE halui.joint.0.increment-minus 10 bit IN FALSE halui.joint.0.increment-plus 10 bit OUT FALSE halui.joint.0.is-homed ==> x-is-homed 10 bit OUT TRUE halui.joint.0.is-selected 10 bit IN FALSE halui.joint.0.minus 10 bit OUT FALSE halui.joint.0.on-hard-max-limit 10 bit OUT FALSE halui.joint.0.on-hard-min-limit 10 bit OUT FALSE halui.joint.0.on-soft-max-limit 10 bit OUT FALSE halui.joint.0.on-soft-min-limit 10 bit OUT FALSE halui.joint.0.override-limits 10 bit IN FALSE halui.joint.0.plus 10 bit IN FALSE halui.joint.0.select 10 bit IN FALSE halui.joint.0.unhome 10 float IN 0 halui.joint.1.analog 10 bit OUT FALSE halui.joint.1.has-fault 10 bit IN FALSE halui.joint.1.home 10 float IN 0 halui.joint.1.increment 10 bit IN FALSE halui.joint.1.increment-minus 10 bit IN FALSE halui.joint.1.increment-plus 10 bit OUT FALSE halui.joint.1.is-homed ==> y-is-homed 10 bit OUT FALSE halui.joint.1.is-selected 10 bit IN FALSE halui.joint.1.minus 10 bit OUT FALSE halui.joint.1.on-hard-max-limit 10 bit OUT FALSE halui.joint.1.on-hard-min-limit 10 bit OUT FALSE halui.joint.1.on-soft-max-limit 10 bit OUT FALSE halui.joint.1.on-soft-min-limit 10 bit OUT FALSE halui.joint.1.override-limits 10 bit IN FALSE halui.joint.1.plus 10 bit IN FALSE halui.joint.1.select 10 bit IN FALSE halui.joint.1.unhome 10 float IN 0 halui.joint.2.analog 10 bit OUT FALSE halui.joint.2.has-fault 10 bit IN FALSE halui.joint.2.home 10 float IN 0 halui.joint.2.increment 10 bit IN FALSE halui.joint.2.increment-minus 10 bit IN FALSE halui.joint.2.increment-plus 10 bit OUT FALSE halui.joint.2.is-homed ==> z-is-homed 10 bit OUT FALSE halui.joint.2.is-selected 10 bit IN FALSE halui.joint.2.minus 10 bit OUT FALSE halui.joint.2.on-hard-max-limit 10 bit OUT FALSE halui.joint.2.on-hard-min-limit 10 bit OUT FALSE halui.joint.2.on-soft-max-limit 10 bit OUT FALSE halui.joint.2.on-soft-min-limit 10 bit OUT FALSE halui.joint.2.override-limits 10 bit IN FALSE halui.joint.2.plus 10 bit IN FALSE halui.joint.2.select 10 bit IN FALSE halui.joint.2.unhome 10 float IN 0.2 halui.joint.jog-deadband 10 float IN 0 halui.joint.jog-speed 10 u32 OUT 0x00000000 halui.joint.selected 10 bit OUT FALSE halui.joint.selected.has-fault 10 bit IN FALSE halui.joint.selected.home 10 float IN 0 halui.joint.selected.increment 10 bit IN FALSE halui.joint.selected.increment-minus 10 bit IN FALSE halui.joint.selected.increment-plus 10 bit OUT FALSE halui.joint.selected.is-homed 10 bit IN FALSE halui.joint.selected.minus 10 bit OUT FALSE halui.joint.selected.on-hard-max-limit 10 bit OUT FALSE halui.joint.selected.on-hard-min-limit 10 bit OUT FALSE halui.joint.selected.on-soft-max-limit 10 bit OUT FALSE halui.joint.selected.on-soft-min-limit 10 bit OUT FALSE halui.joint.selected.override-limits 10 bit IN FALSE halui.joint.selected.plus 10 bit IN FALSE halui.joint.selected.unhome 10 bit OUT FALSE halui.lube.is-on 10 bit IN FALSE halui.lube.off 10 bit IN FALSE halui.lube.on 10 bit OUT FALSE halui.machine.is-on ==> machine-is-on 10 bit IN FALSE halui.machine.off 10 bit IN FALSE halui.machine.on 10 float OUT 1 halui.machine.units-per-mm 10 bit IN TRUE halui.max-velocity.count-enable 10 s32 IN 0 halui.max-velocity.counts 10 bit IN FALSE halui.max-velocity.decrease 10 bit IN FALSE halui.max-velocity.direct-value 10 bit IN FALSE halui.max-velocity.increase 10 float IN 0 halui.max-velocity.scale 10 float OUT 25 halui.max-velocity.value 10 bit OUT FALSE halui.mist.is-on 10 bit IN FALSE halui.mist.off 10 bit IN FALSE halui.mist.on 10 bit IN FALSE halui.mode.auto 10 bit OUT FALSE halui.mode.is-auto 10 bit OUT TRUE halui.mode.is-joint 10 bit OUT TRUE halui.mode.is-manual 10 bit OUT FALSE halui.mode.is-mdi ==> MDI-mode 10 bit OUT FALSE halui.mode.is-teleop 10 bit IN FALSE halui.mode.joint 10 bit IN FALSE halui.mode.manual 10 bit IN FALSE halui.mode.mdi 10 bit IN FALSE halui.mode.teleop 10 bit OUT FALSE halui.program.block-delete.is-on 10 bit IN FALSE halui.program.block-delete.off 10 bit IN FALSE halui.program.block-delete.on 10 bit OUT TRUE halui.program.is-idle 10 bit OUT FALSE halui.program.is-paused 10 bit OUT FALSE halui.program.is-running 10 bit OUT TRUE halui.program.optional-stop.is-on 10 bit IN FALSE halui.program.optional-stop.off 10 bit IN FALSE halui.program.optional-stop.on 10 bit IN FALSE halui.program.pause 10 bit IN FALSE halui.program.resume 10 bit IN FALSE halui.program.run 10 bit IN FALSE halui.program.step 10 bit IN FALSE halui.program.stop 10 bit IN TRUE halui.rapid-override.count-enable 10 s32 IN 0 halui.rapid-override.counts 10 bit IN FALSE halui.rapid-override.decrease 10 bit IN FALSE halui.rapid-override.direct-value 10 bit IN FALSE halui.rapid-override.increase 10 float IN 0.1 halui.rapid-override.scale 10 float OUT 1 halui.rapid-override.value 10 bit OUT TRUE halui.spindle.0.brake-is-on 10 bit IN FALSE halui.spindle.0.brake-off 10 bit IN FALSE halui.spindle.0.brake-on 10 bit IN FALSE halui.spindle.0.decrease 10 bit IN FALSE halui.spindle.0.forward <== spindle-manual-cw 10 bit IN FALSE halui.spindle.0.increase 10 bit OUT FALSE halui.spindle.0.is-on 10 bit IN TRUE halui.spindle.0.override.count-enable 10 s32 IN 0 halui.spindle.0.override.counts 10 bit IN FALSE halui.spindle.0.override.decrease 10 bit IN FALSE halui.spindle.0.override.direct-value 10 bit IN FALSE halui.spindle.0.override.increase 10 float IN 0.1 halui.spindle.0.override.scale 10 float OUT 1 halui.spindle.0.override.value 10 bit IN FALSE halui.spindle.0.reverse <== spindle-manual-ccw 10 bit OUT FALSE halui.spindle.0.runs-backward 10 bit OUT FALSE halui.spindle.0.runs-forward 10 bit IN FALSE halui.spindle.0.start 10 bit IN FALSE halui.spindle.0.stop <== spindle-manual-stop 10 float OUT 0 halui.tool.diameter 10 float OUT 0 halui.tool.length_offset.a 10 float OUT 0 halui.tool.length_offset.b 10 float OUT 0 halui.tool.length_offset.c 10 float OUT 0 halui.tool.length_offset.u 10 float OUT 0 halui.tool.length_offset.v 10 float OUT 0 halui.tool.length_offset.w 10 float OUT 0 halui.tool.length_offset.x 10 float OUT 0 halui.tool.length_offset.y 10 float OUT 0 halui.tool.length_offset.z 10 u32 OUT 0x00000000 halui.tool.number 26 s32 OUT 2097000000 hm2_7i76e.0.0.debug 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-00 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-00-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-01 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-01-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-02 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-02-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-03 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-03-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-04 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-04-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-05 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-05-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-06 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-06-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-07 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-07-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-08 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-08-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-09 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-09-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-10 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-10-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-11 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-11-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-12 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-12-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-13 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-13-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-14 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-14-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-15 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-15-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-16 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-16-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-17 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-17-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-18 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-18-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-19 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-19-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-20 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-20-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-21 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-21-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-22 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-22-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-23 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-23-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-24 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-24-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-25 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-25-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-26 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-26-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-27 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-27-not 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-28 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-28-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-29 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-29-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-30 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-30-not 26 bit OUT FALSE hm2_7i76e.0.7i76.0.0.input-31 26 bit OUT TRUE hm2_7i76e.0.7i76.0.0.input-31-not 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-00 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-01 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-02 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-03 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-04 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-05 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-06 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-07 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-08 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-09 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-10 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-11 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-12 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-13 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-14 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.output-15 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.spindir 26 bit IN FALSE hm2_7i76e.0.7i76.0.0.spinena 26 float IN 0 hm2_7i76e.0.7i76.0.0.spinout 26 float IN -50 hm2_7i76e.0.dpll.01.timer-us 26 float IN 100 hm2_7i76e.0.dpll.02.timer-us 26 float IN 100 hm2_7i76e.0.dpll.03.timer-us 26 float IN 100 hm2_7i76e.0.dpll.04.timer-us 26 float IN 1 hm2_7i76e.0.dpll.base-freq-khz 26 u32 OUT 0x0000002A hm2_7i76e.0.dpll.ddsize 26 float OUT 2.361445 hm2_7i76e.0.dpll.phase-error-us 26 u32 IN 0x00400000 hm2_7i76e.0.dpll.plimit 26 u32 OUT 0x00000018 hm2_7i76e.0.dpll.prescale 26 u32 IN 0x000007D0 hm2_7i76e.0.dpll.time-const 26 s32 OUT 0 hm2_7i76e.0.encoder.00.count 26 s32 OUT 0 hm2_7i76e.0.encoder.00.count-latched 26 bit I/O FALSE hm2_7i76e.0.encoder.00.index-enable 26 bit OUT FALSE hm2_7i76e.0.encoder.00.input-a 26 bit OUT FALSE hm2_7i76e.0.encoder.00.input-b 26 bit OUT TRUE hm2_7i76e.0.encoder.00.input-index 26 bit IN FALSE hm2_7i76e.0.encoder.00.latch-enable 26 bit IN FALSE hm2_7i76e.0.encoder.00.latch-polarity 26 float OUT 0 hm2_7i76e.0.encoder.00.position 26 float OUT 0 hm2_7i76e.0.encoder.00.position-latched 26 bit OUT FALSE hm2_7i76e.0.encoder.00.quad-error 26 bit IN FALSE hm2_7i76e.0.encoder.00.quad-error-enable 26 s32 OUT 0 hm2_7i76e.0.encoder.00.rawcounts 26 s32 OUT 0 hm2_7i76e.0.encoder.00.rawlatch 26 bit IN FALSE hm2_7i76e.0.encoder.00.reset 26 float OUT 0 hm2_7i76e.0.encoder.00.velocity 26 float OUT 0 hm2_7i76e.0.encoder.00.velocity-rpm 26 bit IN FALSE hm2_7i76e.0.encoder.hires-timestamp 26 u32 IN 0x017D7840 hm2_7i76e.0.encoder.sample-frequency 26 s32 IN -1 hm2_7i76e.0.encoder.timer-number 26 bit OUT FALSE hm2_7i76e.0.gpio.000.in 26 bit OUT TRUE hm2_7i76e.0.gpio.000.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.001.in 26 bit OUT TRUE hm2_7i76e.0.gpio.001.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.002.in 26 bit OUT TRUE hm2_7i76e.0.gpio.002.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.003.in 26 bit OUT TRUE hm2_7i76e.0.gpio.003.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.004.in 26 bit OUT TRUE hm2_7i76e.0.gpio.004.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.005.in 26 bit OUT TRUE hm2_7i76e.0.gpio.005.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.006.in 26 bit OUT TRUE hm2_7i76e.0.gpio.006.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.007.in 26 bit OUT TRUE hm2_7i76e.0.gpio.007.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.008.in 26 bit OUT TRUE hm2_7i76e.0.gpio.008.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.009.in 26 bit OUT TRUE hm2_7i76e.0.gpio.009.in_not 26 bit OUT TRUE hm2_7i76e.0.gpio.010.in 26 bit OUT FALSE hm2_7i76e.0.gpio.010.in_not 26 bit OUT TRUE hm2_7i76e.0.gpio.011.in 26 bit OUT FALSE hm2_7i76e.0.gpio.011.in_not 26 bit OUT TRUE hm2_7i76e.0.gpio.012.in 26 bit OUT FALSE hm2_7i76e.0.gpio.012.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.012.out 26 bit OUT TRUE hm2_7i76e.0.gpio.013.in 26 bit OUT FALSE hm2_7i76e.0.gpio.013.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.013.out 26 bit OUT FALSE hm2_7i76e.0.gpio.014.in 26 bit OUT TRUE hm2_7i76e.0.gpio.014.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.015.in 26 bit OUT TRUE hm2_7i76e.0.gpio.015.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.016.in 26 bit OUT TRUE hm2_7i76e.0.gpio.016.in_not 26 bit OUT FALSE hm2_7i76e.0.gpio.017.in 26 bit OUT TRUE hm2_7i76e.0.gpio.017.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.017.out 26 bit OUT FALSE hm2_7i76e.0.gpio.018.in 26 bit OUT TRUE hm2_7i76e.0.gpio.018.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.018.out 26 bit OUT FALSE hm2_7i76e.0.gpio.019.in 26 bit OUT TRUE hm2_7i76e.0.gpio.019.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.019.out 26 bit OUT FALSE hm2_7i76e.0.gpio.020.in 26 bit OUT TRUE hm2_7i76e.0.gpio.020.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.020.out 26 bit OUT FALSE hm2_7i76e.0.gpio.021.in 26 bit OUT TRUE hm2_7i76e.0.gpio.021.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.021.out 26 bit OUT FALSE hm2_7i76e.0.gpio.022.in 26 bit OUT TRUE hm2_7i76e.0.gpio.022.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.022.out 26 bit OUT FALSE hm2_7i76e.0.gpio.023.in 26 bit OUT TRUE hm2_7i76e.0.gpio.023.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.023.out 26 bit OUT FALSE hm2_7i76e.0.gpio.024.in 26 bit OUT TRUE hm2_7i76e.0.gpio.024.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.024.out 26 bit OUT FALSE hm2_7i76e.0.gpio.025.in 26 bit OUT TRUE hm2_7i76e.0.gpio.025.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.025.out 26 bit OUT FALSE hm2_7i76e.0.gpio.026.in 26 bit OUT TRUE hm2_7i76e.0.gpio.026.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.026.out 26 bit OUT FALSE hm2_7i76e.0.gpio.027.in 26 bit OUT TRUE hm2_7i76e.0.gpio.027.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.027.out 26 bit OUT FALSE hm2_7i76e.0.gpio.028.in 26 bit OUT TRUE hm2_7i76e.0.gpio.028.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.028.out 26 bit OUT FALSE hm2_7i76e.0.gpio.029.in 26 bit OUT TRUE hm2_7i76e.0.gpio.029.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.029.out 26 bit OUT FALSE hm2_7i76e.0.gpio.030.in 26 bit OUT TRUE hm2_7i76e.0.gpio.030.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.030.out 26 bit OUT FALSE hm2_7i76e.0.gpio.031.in 26 bit OUT TRUE hm2_7i76e.0.gpio.031.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.031.out 26 bit OUT FALSE hm2_7i76e.0.gpio.032.in 26 bit OUT TRUE hm2_7i76e.0.gpio.032.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.032.out 26 bit OUT FALSE hm2_7i76e.0.gpio.033.in 26 bit OUT TRUE hm2_7i76e.0.gpio.033.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.033.out 26 bit OUT FALSE hm2_7i76e.0.gpio.034.in ==> both-x 26 bit OUT TRUE hm2_7i76e.0.gpio.034.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.034.out 26 bit OUT FALSE hm2_7i76e.0.gpio.035.in ==> both-y 26 bit OUT TRUE hm2_7i76e.0.gpio.035.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.035.out 26 bit OUT FALSE hm2_7i76e.0.gpio.036.in ==> both-z 26 bit OUT TRUE hm2_7i76e.0.gpio.036.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.036.out 26 bit OUT FALSE hm2_7i76e.0.gpio.037.in 26 bit OUT TRUE hm2_7i76e.0.gpio.037.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.037.out 26 bit OUT FALSE hm2_7i76e.0.gpio.038.in 26 bit OUT TRUE hm2_7i76e.0.gpio.038.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.038.out 26 bit OUT FALSE hm2_7i76e.0.gpio.039.in 26 bit OUT TRUE hm2_7i76e.0.gpio.039.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.039.out 26 bit OUT FALSE hm2_7i76e.0.gpio.040.in 26 bit OUT TRUE hm2_7i76e.0.gpio.040.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.040.out 26 bit OUT FALSE hm2_7i76e.0.gpio.041.in 26 bit OUT TRUE hm2_7i76e.0.gpio.041.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.041.out 26 bit OUT FALSE hm2_7i76e.0.gpio.042.in 26 bit OUT TRUE hm2_7i76e.0.gpio.042.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.042.out 26 bit OUT FALSE hm2_7i76e.0.gpio.043.in 26 bit OUT TRUE hm2_7i76e.0.gpio.043.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.043.out 26 bit OUT FALSE hm2_7i76e.0.gpio.044.in 26 bit OUT TRUE hm2_7i76e.0.gpio.044.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.044.out 26 bit OUT FALSE hm2_7i76e.0.gpio.045.in 26 bit OUT TRUE hm2_7i76e.0.gpio.045.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.045.out 26 bit OUT FALSE hm2_7i76e.0.gpio.046.in 26 bit OUT TRUE hm2_7i76e.0.gpio.046.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.046.out 26 bit OUT FALSE hm2_7i76e.0.gpio.047.in 26 bit OUT TRUE hm2_7i76e.0.gpio.047.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.047.out 26 bit OUT FALSE hm2_7i76e.0.gpio.048.in 26 bit OUT TRUE hm2_7i76e.0.gpio.048.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.048.out 26 bit OUT FALSE hm2_7i76e.0.gpio.049.in 26 bit OUT TRUE hm2_7i76e.0.gpio.049.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.049.out 26 bit OUT FALSE hm2_7i76e.0.gpio.050.in 26 bit OUT TRUE hm2_7i76e.0.gpio.050.in_not 26 bit IN FALSE hm2_7i76e.0.gpio.050.out 26 bit IN FALSE hm2_7i76e.0.led.CR01 26 bit IN FALSE hm2_7i76e.0.led.CR02 26 bit IN FALSE hm2_7i76e.0.led.CR03 26 bit IN FALSE hm2_7i76e.0.led.CR04 26 bit OUT FALSE hm2_7i76e.0.packet-error 26 bit OUT FALSE hm2_7i76e.0.packet-error-exceeded 26 s32 OUT 0 hm2_7i76e.0.packet-error-level 26 s32 OUT 0 hm2_7i76e.0.read-request.time 26 s32 OUT 498478 hm2_7i76e.0.read.time 26 u32 OUT 0x00000000 hm2_7i76e.0.sserial.port-0.fault-count 26 u32 OUT 0x00000003 hm2_7i76e.0.sserial.port-0.port_state 26 u32 OUT 0x00000000 hm2_7i76e.0.sserial.port-0.port_state2 26 u32 OUT 0x00000000 hm2_7i76e.0.sserial.port-0.port_state3 26 bit IN TRUE hm2_7i76e.0.sserial.port-0.run 26 bit IN TRUE hm2_7i76e.0.stepgen.00.control-type 26 s32 OUT 0 hm2_7i76e.0.stepgen.00.counts 26 float OUT 0 hm2_7i76e.0.stepgen.00.dbg_err_at_match 26 float OUT 0 hm2_7i76e.0.stepgen.00.dbg_ff_vel 26 float OUT 0 hm2_7i76e.0.stepgen.00.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i76e.0.stepgen.00.dbg_s_to_match 26 s32 OUT 0 hm2_7i76e.0.stepgen.00.dbg_step_rate 26 float OUT 0 hm2_7i76e.0.stepgen.00.dbg_vel_error 26 bit IN FALSE hm2_7i76e.0.stepgen.00.enable <== x-enable 26 float IN 0 hm2_7i76e.0.stepgen.00.position-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.00.position-fb ==> x-pos-fb 26 float IN 0 hm2_7i76e.0.stepgen.00.velocity-cmd <== x-output 26 float OUT 0 hm2_7i76e.0.stepgen.00.velocity-fb 26 bit IN TRUE hm2_7i76e.0.stepgen.01.control-type 26 s32 OUT 0 hm2_7i76e.0.stepgen.01.counts 26 float OUT 0 hm2_7i76e.0.stepgen.01.dbg_err_at_match 26 float OUT 0 hm2_7i76e.0.stepgen.01.dbg_ff_vel 26 float OUT 0 hm2_7i76e.0.stepgen.01.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i76e.0.stepgen.01.dbg_s_to_match 26 s32 OUT 0 hm2_7i76e.0.stepgen.01.dbg_step_rate 26 float OUT 0 hm2_7i76e.0.stepgen.01.dbg_vel_error 26 bit IN FALSE hm2_7i76e.0.stepgen.01.enable <== y-enable 26 float IN 0 hm2_7i76e.0.stepgen.01.position-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.01.position-fb ==> y-pos-fb 26 float IN 0 hm2_7i76e.0.stepgen.01.velocity-cmd <== y-output 26 float OUT 0 hm2_7i76e.0.stepgen.01.velocity-fb 26 bit IN TRUE hm2_7i76e.0.stepgen.02.control-type 26 s32 OUT 0 hm2_7i76e.0.stepgen.02.counts 26 float OUT 0 hm2_7i76e.0.stepgen.02.dbg_err_at_match 26 float OUT 0 hm2_7i76e.0.stepgen.02.dbg_ff_vel 26 float OUT 0 hm2_7i76e.0.stepgen.02.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i76e.0.stepgen.02.dbg_s_to_match 26 s32 OUT 0 hm2_7i76e.0.stepgen.02.dbg_step_rate 26 float OUT 0 hm2_7i76e.0.stepgen.02.dbg_vel_error 26 bit IN FALSE hm2_7i76e.0.stepgen.02.enable <== z-enable 26 float IN 0 hm2_7i76e.0.stepgen.02.position-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.02.position-fb ==> z-pos-fb 26 float IN 0 hm2_7i76e.0.stepgen.02.velocity-cmd <== z-output 26 float OUT 0 hm2_7i76e.0.stepgen.02.velocity-fb 26 bit IN FALSE hm2_7i76e.0.stepgen.03.control-type 26 s32 OUT 0 hm2_7i76e.0.stepgen.03.counts 26 float OUT 0 hm2_7i76e.0.stepgen.03.dbg_err_at_match 26 float OUT 0 hm2_7i76e.0.stepgen.03.dbg_ff_vel 26 float OUT 0 hm2_7i76e.0.stepgen.03.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i76e.0.stepgen.03.dbg_s_to_match 26 s32 OUT 0 hm2_7i76e.0.stepgen.03.dbg_step_rate 26 float OUT 0 hm2_7i76e.0.stepgen.03.dbg_vel_error 26 bit IN FALSE hm2_7i76e.0.stepgen.03.enable 26 float IN 0 hm2_7i76e.0.stepgen.03.position-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.03.position-fb 26 float IN 0 hm2_7i76e.0.stepgen.03.velocity-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.03.velocity-fb 26 bit IN FALSE hm2_7i76e.0.stepgen.04.control-type 26 s32 OUT 0 hm2_7i76e.0.stepgen.04.counts 26 float OUT 0 hm2_7i76e.0.stepgen.04.dbg_err_at_match 26 float OUT 0 hm2_7i76e.0.stepgen.04.dbg_ff_vel 26 float OUT 0 hm2_7i76e.0.stepgen.04.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i76e.0.stepgen.04.dbg_s_to_match 26 s32 OUT 0 hm2_7i76e.0.stepgen.04.dbg_step_rate 26 float OUT 0 hm2_7i76e.0.stepgen.04.dbg_vel_error 26 bit IN FALSE hm2_7i76e.0.stepgen.04.enable 26 float IN 0 hm2_7i76e.0.stepgen.04.position-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.04.position-fb 26 float IN 0 hm2_7i76e.0.stepgen.04.velocity-cmd 26 float OUT 0 hm2_7i76e.0.stepgen.04.velocity-fb 26 s32 IN 1 hm2_7i76e.0.stepgen.timer-number 26 bit I/O FALSE hm2_7i76e.0.watchdog.has_bit 26 s32 OUT 5628 hm2_7i76e.0.write.time 44 float IN 0 ini.0.backlash 44 float IN 10 ini.0.ferror 44 float IN 0 ini.0.home 44 float IN 0 ini.0.home_offset 44 s32 IN 999 ini.0.home_sequence 44 float IN 750 ini.0.max_acceleration 44 float IN 200 ini.0.max_limit 44 float IN 25 ini.0.max_velocity 44 float IN 1 ini.0.min_ferror 44 float IN -0.01 ini.0.min_limit 44 float IN 0 ini.1.backlash 44 float IN 10 ini.1.ferror 44 float IN 0 ini.1.home 44 float IN 0 ini.1.home_offset 44 s32 IN 999 ini.1.home_sequence 44 float IN 750 ini.1.max_acceleration 44 float IN 200 ini.1.max_limit 44 float IN 25 ini.1.max_velocity 44 float IN 1 ini.1.min_ferror 44 float IN -0.01 ini.1.min_limit 44 float IN 0 ini.2.backlash 44 float IN 10 ini.2.ferror 44 float IN 0 ini.2.home 44 float IN 0 ini.2.home_offset 44 s32 IN 999 ini.2.home_sequence 44 float IN 750 ini.2.max_acceleration 44 float IN 0.01 ini.2.max_limit 44 float IN 25 ini.2.max_velocity 44 float IN 1 ini.2.min_ferror 44 float IN -100 ini.2.min_limit 44 float IN 0 ini.a.max_acceleration 44 float IN 0 ini.a.max_limit 44 float IN 0 ini.a.max_velocity 44 float IN 0 ini.a.min_limit 44 float IN 0 ini.b.max_acceleration 44 float IN 0 ini.b.max_limit 44 float IN 0 ini.b.max_velocity 44 float IN 0 ini.b.min_limit 44 float IN 0 ini.c.max_acceleration 44 float IN 0 ini.c.max_limit 44 float IN 0 ini.c.max_velocity 44 float IN 0 ini.c.min_limit 44 bit IN TRUE ini.traj_arc_blend_enable 44 bit IN FALSE ini.traj_arc_blend_fallback_enable 44 float IN 4 ini.traj_arc_blend_gap_cycles 44 s32 IN 50 ini.traj_arc_blend_optimization_depth 44 float IN 100 ini.traj_arc_blend_ramp_freq 44 float IN 0.1 ini.traj_arc_blend_tangent_kink_ratio 44 float IN 1e+99 ini.traj_default_acceleration 44 float IN 2.5 ini.traj_default_velocity 44 float IN 1e+99 ini.traj_max_acceleration 44 float IN 25 ini.traj_max_velocity 44 float IN 0 ini.u.max_acceleration 44 float IN 0 ini.u.max_limit 44 float IN 0 ini.u.max_velocity 44 float IN 0 ini.u.min_limit 44 float IN 0 ini.v.max_acceleration 44 float IN 0 ini.v.max_limit 44 float IN 0 ini.v.max_velocity 44 float IN 0 ini.v.min_limit 44 float IN 0 ini.w.max_acceleration 44 float IN 0 ini.w.max_limit 44 float IN 0 ini.w.max_velocity 44 float IN 0 ini.w.min_limit 44 float IN 750 ini.x.max_acceleration 44 float IN 200 ini.x.max_limit 44 float IN 25 ini.x.max_velocity 44 float IN -0.01 ini.x.min_limit 44 float IN 750 ini.y.max_acceleration 44 float IN 200 ini.y.max_limit 44 float IN 25 ini.y.max_velocity 44 float IN -0.01 ini.y.min_limit 44 float IN 750 ini.z.max_acceleration 44 float IN 0.01 ini.z.max_limit 44 float IN 25 ini.z.max_velocity 44 float IN -100 ini.z.min_limit 4 bit OUT FALSE iocontrol.0.coolant-flood ==> coolant-flood 4 bit OUT FALSE iocontrol.0.coolant-mist ==> coolant-mist 4 bit IN FALSE iocontrol.0.emc-enable-in <== estop-out 4 bit OUT FALSE iocontrol.0.lube 4 bit IN FALSE iocontrol.0.lube_level 4 bit OUT FALSE iocontrol.0.tool-change ==> tool-change-request 4 bit IN FALSE iocontrol.0.tool-changed <== tool-change-confirmed 4 s32 OUT 0 iocontrol.0.tool-number 4 s32 OUT 0 iocontrol.0.tool-prep-number ==> tool-number 4 s32 OUT 0 iocontrol.0.tool-prep-pocket 4 bit OUT FALSE iocontrol.0.tool-prepare ==> tool-prepare-loopback 4 bit IN FALSE iocontrol.0.tool-prepared <== tool-prepare-loopback 4 bit OUT FALSE iocontrol.0.user-enable-out ==> estop-out 4 bit OUT FALSE iocontrol.0.user-request-enable 19 float OUT 0 joint.0.acc-cmd 19 bit OUT TRUE joint.0.active 19 bit OUT FALSE joint.0.amp-enable-out ==> x-enable 19 bit IN FALSE joint.0.amp-fault-in 19 float OUT 0 joint.0.backlash-corr 19 float OUT 0 joint.0.backlash-filt 19 float OUT 0 joint.0.backlash-vel 19 float OUT 0 joint.0.coarse-pos-cmd 19 bit OUT FALSE joint.0.error 19 float OUT 0 joint.0.f-error 19 float OUT 1 joint.0.f-error-lim 19 bit OUT FALSE joint.0.f-errored 19 bit OUT FALSE joint.0.faulted 19 float OUT 0 joint.0.free-pos-cmd 19 bit OUT FALSE joint.0.free-tp-enable 19 float OUT 0 joint.0.free-vel-lim 19 s32 OUT 0 joint.0.home-state 19 bit IN FALSE joint.0.home-sw-in <== x-home-sw 19 bit OUT FALSE joint.0.homed 19 bit OUT FALSE joint.0.homing 19 bit OUT TRUE joint.0.in-position 19 bit I/O FALSE joint.0.index-enable 19 float IN 1 joint.0.jog-accel-fraction 19 s32 IN 0 joint.0.jog-counts 19 bit IN FALSE joint.0.jog-enable 19 float IN 0 joint.0.jog-scale 19 bit IN FALSE joint.0.jog-vel-mode 19 bit OUT FALSE joint.0.kb-jog-active 19 float OUT 0 joint.0.motor-offset 19 float OUT 0 joint.0.motor-pos-cmd ==> x-pos-cmd 19 float IN 0 joint.0.motor-pos-fb <== x-pos-fb 19 bit OUT FALSE joint.0.neg-hard-limit 19 bit IN FALSE joint.0.neg-lim-sw-in <== both-x 19 float OUT 0 joint.0.pos-cmd 19 float OUT 0 joint.0.pos-fb 19 bit OUT FALSE joint.0.pos-hard-limit 19 bit IN FALSE joint.0.pos-lim-sw-in <== both-x 19 float OUT 0 joint.0.vel-cmd ==> x-vel-cmd 19 bit OUT FALSE joint.0.wheel-jog-active 19 float OUT 0 joint.1.acc-cmd 19 bit OUT TRUE joint.1.active 19 bit OUT FALSE joint.1.amp-enable-out ==> y-enable 19 bit IN FALSE joint.1.amp-fault-in 19 float OUT 0 joint.1.backlash-corr 19 float OUT 0 joint.1.backlash-filt 19 float OUT 0 joint.1.backlash-vel 19 float OUT 0 joint.1.coarse-pos-cmd 19 bit OUT FALSE joint.1.error 19 float OUT 0 joint.1.f-error 19 float OUT 1 joint.1.f-error-lim 19 bit OUT FALSE joint.1.f-errored 19 bit OUT FALSE joint.1.faulted 19 float OUT 0 joint.1.free-pos-cmd 19 bit OUT FALSE joint.1.free-tp-enable 19 float OUT 0 joint.1.free-vel-lim 19 s32 OUT 0 joint.1.home-state 19 bit IN FALSE joint.1.home-sw-in <== y-home-sw 19 bit OUT FALSE joint.1.homed 19 bit OUT FALSE joint.1.homing 19 bit OUT TRUE joint.1.in-position 19 bit I/O FALSE joint.1.index-enable 19 float IN 1 joint.1.jog-accel-fraction 19 s32 IN 0 joint.1.jog-counts 19 bit IN FALSE joint.1.jog-enable 19 float IN 0 joint.1.jog-scale 19 bit IN FALSE joint.1.jog-vel-mode 19 bit OUT FALSE joint.1.kb-jog-active 19 float OUT 0 joint.1.motor-offset 19 float OUT 0 joint.1.motor-pos-cmd ==> y-pos-cmd 19 float IN 0 joint.1.motor-pos-fb <== y-pos-fb 19 bit OUT FALSE joint.1.neg-hard-limit 19 bit IN FALSE joint.1.neg-lim-sw-in <== both-y 19 float OUT 0 joint.1.pos-cmd 19 float OUT 0 joint.1.pos-fb 19 bit OUT FALSE joint.1.pos-hard-limit 19 bit IN FALSE joint.1.pos-lim-sw-in <== both-y 19 float OUT 0 joint.1.vel-cmd ==> y-vel-cmd 19 bit OUT FALSE joint.1.wheel-jog-active 19 float OUT 0 joint.2.acc-cmd 19 bit OUT TRUE joint.2.active 19 bit OUT FALSE joint.2.amp-enable-out ==> z-enable 19 bit IN FALSE joint.2.amp-fault-in 19 float OUT 0 joint.2.backlash-corr 19 float OUT 0 joint.2.backlash-filt 19 float OUT 0 joint.2.backlash-vel 19 float OUT 0 joint.2.coarse-pos-cmd 19 bit OUT FALSE joint.2.error 19 float OUT 0 joint.2.f-error 19 float OUT 1 joint.2.f-error-lim 19 bit OUT FALSE joint.2.f-errored 19 bit OUT FALSE joint.2.faulted 19 float OUT 0 joint.2.free-pos-cmd 19 bit OUT FALSE joint.2.free-tp-enable 19 float OUT 0 joint.2.free-vel-lim 19 s32 OUT 0 joint.2.home-state 19 bit IN FALSE joint.2.home-sw-in <== z-home-sw 19 bit OUT FALSE joint.2.homed 19 bit OUT FALSE joint.2.homing 19 bit OUT TRUE joint.2.in-position 19 bit I/O FALSE joint.2.index-enable 19 float IN 1 joint.2.jog-accel-fraction 19 s32 IN 0 joint.2.jog-counts 19 bit IN FALSE joint.2.jog-enable 19 float IN 0 joint.2.jog-scale 19 bit IN FALSE joint.2.jog-vel-mode 19 bit OUT FALSE joint.2.kb-jog-active 19 float OUT 0 joint.2.motor-offset 19 float OUT 0 joint.2.motor-pos-cmd ==> z-pos-cmd 19 float IN 0 joint.2.motor-pos-fb <== z-pos-fb 19 bit OUT FALSE joint.2.neg-hard-limit 19 bit IN FALSE joint.2.neg-lim-sw-in <== both-z 19 float OUT 0 joint.2.pos-cmd 19 float OUT 0 joint.2.pos-fb 19 bit OUT FALSE joint.2.pos-hard-limit 19 bit IN FALSE joint.2.pos-lim-sw-in <== both-z 19 float OUT 0 joint.2.vel-cmd ==> z-vel-cmd 19 bit OUT FALSE joint.2.wheel-jog-active 19 s32 OUT 10 motion-command-handler.time 19 s32 OUT 2079 motion-controller.time 19 float IN 1 motion.adaptive-feed 19 float IN 0 motion.analog-in-00 19 float IN 0 motion.analog-in-01 19 float IN 0 motion.analog-in-02 19 float IN 0 motion.analog-in-03 19 float OUT 0 motion.analog-out-00 19 float OUT 0 motion.analog-out-01 19 float OUT 0 motion.analog-out-02 19 float OUT 0 motion.analog-out-03 19 bit OUT FALSE motion.coord-error 19 bit OUT FALSE motion.coord-mode 19 float OUT 0 motion.current-vel 19 bit IN FALSE motion.digital-in-00 19 bit IN FALSE motion.digital-in-01 19 bit IN FALSE motion.digital-in-02 19 bit IN FALSE motion.digital-in-03 19 bit OUT FALSE motion.digital-out-00 19 bit OUT FALSE motion.digital-out-01 19 bit OUT FALSE motion.digital-out-02 19 bit OUT FALSE motion.digital-out-03 19 float OUT 0 motion.distance-to-go 19 bit IN TRUE motion.enable 19 bit OUT FALSE motion.eoffset-active 19 bit OUT FALSE motion.eoffset-limited 19 bit IN FALSE motion.feed-hold 19 bit IN FALSE motion.feed-inhibit 19 bit IN FALSE motion.homing-inhibit 19 bit OUT TRUE motion.in-position ==> in-position 19 bit OUT FALSE motion.motion-enabled ==> machine-is-enabled 19 s32 OUT 0 motion.motion-type 19 bit OUT FALSE motion.on-soft-limit 19 bit IN FALSE motion.probe-input <== probe-in 19 s32 OUT 0 motion.program-line 19 float OUT 0 motion.requested-vel 19 u32 OUT 0x0018FB8F motion.servo.last-period 19 bit OUT FALSE motion.teleop-mode 19 float OUT 0 motion.tooloffset.a 19 float OUT 0 motion.tooloffset.b 19 float OUT 0 motion.tooloffset.c 19 float OUT 0 motion.tooloffset.u 19 float OUT 0 motion.tooloffset.v 19 float OUT 0 motion.tooloffset.w 19 float OUT 0 motion.tooloffset.x 19 float OUT 0 motion.tooloffset.y 19 float OUT 0 motion.tooloffset.z 19 bit OUT FALSE motion.tp-reverse 29 float IN 0 pid.s.Dgain 29 float IN 1 pid.s.FF0 29 float IN 0 pid.s.FF1 29 float IN 0 pid.s.FF2 29 float IN 0 pid.s.FF3 29 float IN 0 pid.s.Igain 29 float IN 0 pid.s.Pgain 29 float IN 0 pid.s.bias 29 float IN 0 pid.s.command <== spindle-vel-cmd-rpm 29 float IN 0 pid.s.command-deriv 29 float IN 0 pid.s.deadband 29 s32 OUT 83 pid.s.do-pid-calcs.time 29 bit IN FALSE pid.s.enable <== spindle-enable 29 float OUT 0 pid.s.error 29 bit IN TRUE pid.s.error-previous-target 29 float IN 0 pid.s.feedback <== spindle-vel-fb-rpm 29 float IN 0 pid.s.feedback-deriv 29 bit IN FALSE pid.s.index-enable <== spindle-index-enable 29 float IN 0 pid.s.maxcmdD 29 float IN 0 pid.s.maxcmdDD 29 float IN 0 pid.s.maxcmdDDD 29 float IN 0 pid.s.maxerror 29 float IN 0 pid.s.maxerrorD 29 float IN 0 pid.s.maxerrorI 29 float IN 2000 pid.s.maxoutput 29 float OUT 0 pid.s.output ==> spindle-output 29 bit OUT FALSE pid.s.saturated 29 s32 OUT 0 pid.s.saturated-count 29 float OUT 0 pid.s.saturated-s 29 float IN 0 pid.x.Dgain 29 float IN 0 pid.x.FF0 29 float IN 1 pid.x.FF1 29 float IN 0 pid.x.FF2 29 float IN 0 pid.x.FF3 29 float IN 0 pid.x.Igain 29 float IN 1000 pid.x.Pgain 29 float IN 0 pid.x.bias 29 float IN 0 pid.x.command <== x-pos-cmd 29 float IN 0 pid.x.command-deriv 29 float IN 0 pid.x.deadband 29 s32 OUT 57 pid.x.do-pid-calcs.time 29 bit IN FALSE pid.x.enable <== x-enable 29 float OUT 0 pid.x.error 29 bit IN TRUE pid.x.error-previous-target 29 float IN 0 pid.x.feedback <== x-pos-fb 29 float IN 0 pid.x.feedback-deriv 29 bit IN FALSE pid.x.index-enable <== x-index-enable 29 float IN 0 pid.x.maxcmdD 29 float IN 0 pid.x.maxcmdDD 29 float IN 0 pid.x.maxcmdDDD 29 float IN 0.0005 pid.x.maxerror 29 float IN 0 pid.x.maxerrorD 29 float IN 0 pid.x.maxerrorI 29 float IN 0 pid.x.maxoutput 29 float OUT 0 pid.x.output ==> x-output 29 bit OUT FALSE pid.x.saturated 29 s32 OUT 0 pid.x.saturated-count 29 float OUT 0 pid.x.saturated-s 29 float IN 0 pid.y.Dgain 29 float IN 0 pid.y.FF0 29 float IN 1 pid.y.FF1 29 float IN 0 pid.y.FF2 29 float IN 0 pid.y.FF3 29 float IN 0 pid.y.Igain 29 float IN 1000 pid.y.Pgain 29 float IN 0 pid.y.bias 29 float IN 0 pid.y.command <== y-pos-cmd 29 float IN 0 pid.y.command-deriv 29 float IN 0 pid.y.deadband 29 s32 OUT 43 pid.y.do-pid-calcs.time 29 bit IN FALSE pid.y.enable <== y-enable 29 float OUT 0 pid.y.error 29 bit IN TRUE pid.y.error-previous-target 29 float IN 0 pid.y.feedback <== y-pos-fb 29 float IN 0 pid.y.feedback-deriv 29 bit IN FALSE pid.y.index-enable <== y-index-enable 29 float IN 0 pid.y.maxcmdD 29 float IN 0 pid.y.maxcmdDD 29 float IN 0 pid.y.maxcmdDDD 29 float IN 0.0005 pid.y.maxerror 29 float IN 0 pid.y.maxerrorD 29 float IN 0 pid.y.maxerrorI 29 float IN 0 pid.y.maxoutput 29 float OUT 0 pid.y.output ==> y-output 29 bit OUT FALSE pid.y.saturated 29 s32 OUT 0 pid.y.saturated-count 29 float OUT 0 pid.y.saturated-s 29 float IN 0 pid.z.Dgain 29 float IN 0 pid.z.FF0 29 float IN 1 pid.z.FF1 29 float IN 0 pid.z.FF2 29 float IN 0 pid.z.FF3 29 float IN 0 pid.z.Igain 29 float IN 1000 pid.z.Pgain 29 float IN 0 pid.z.bias 29 float IN 0 pid.z.command <== z-pos-cmd 29 float IN 0 pid.z.command-deriv 29 float IN 0 pid.z.deadband 29 s32 OUT 49 pid.z.do-pid-calcs.time 29 bit IN FALSE pid.z.enable <== z-enable 29 float OUT 0 pid.z.error 29 bit IN TRUE pid.z.error-previous-target 29 float IN 0 pid.z.feedback <== z-pos-fb 29 float IN 0 pid.z.feedback-deriv 29 bit IN FALSE pid.z.index-enable <== z-index-enable 29 float IN 0 pid.z.maxcmdD 29 float IN 0 pid.z.maxcmdDD 29 float IN 0 pid.z.maxcmdDDD 29 float IN 0.0005 pid.z.maxerror 29 float IN 0 pid.z.maxerrorD 29 float IN 0 pid.z.maxerrorI 29 float IN 0 pid.z.maxoutput 29 float OUT 0 pid.z.output ==> z-output 29 bit OUT FALSE pid.z.saturated 29 s32 OUT 0 pid.z.saturated-count 29 float OUT 0 pid.z.saturated-s 20 s32 OUT 506427 servo-thread.time 19 bit IN FALSE spindle.0.amp-fault-in 19 bit IN TRUE spindle.0.at-speed <== spindle-at-speed 19 bit OUT TRUE spindle.0.brake ==> spindle-brake 19 bit OUT FALSE spindle.0.forward ==> spindle-cw 19 bit I/O FALSE spindle.0.index-enable <=> spindle-index-enable 19 bit IN FALSE spindle.0.inhibit 19 bit IN FALSE spindle.0.is-oriented 19 bit OUT FALSE spindle.0.locked 19 bit OUT FALSE spindle.0.on ==> spindle-enable 19 bit OUT FALSE spindle.0.orient 19 float OUT 0 spindle.0.orient-angle 19 s32 IN 0 spindle.0.orient-fault 19 s32 OUT 0 spindle.0.orient-mode 19 bit OUT FALSE spindle.0.reverse ==> spindle-ccw 19 float IN 0 spindle.0.revs <== spindle-revs 19 float OUT 0 spindle.0.speed-cmd-rps 19 float IN 0 spindle.0.speed-in <== spindle-vel-fb-rps 19 float OUT 0 spindle.0.speed-out ==> spindle-vel-cmd-rpm 19 float OUT 0 spindle.0.speed-out-abs ==> spindle-vel-cmd-rpm-abs 19 float OUT 0 spindle.0.speed-out-rps ==> spindle-vel-cmd-rps 19 float OUT 0 spindle.0.speed-out-rps-abs ==> spindle-vel-cmd-rps-abs Pin Aliases: Alias Original Name Signals: Type Value Name (linked to) bit FALSE MDI-mode <== halui.mode.is-mdi bit FALSE axis-select-x ==> halui.axis.x.select bit FALSE axis-select-y ==> halui.axis.y.select bit FALSE axis-select-z ==> halui.axis.z.select bit FALSE both-x <== hm2_7i76e.0.gpio.034.in ==> joint.0.neg-lim-sw-in ==> joint.0.pos-lim-sw-in bit FALSE both-y <== hm2_7i76e.0.gpio.035.in ==> joint.1.neg-lim-sw-in ==> joint.1.pos-lim-sw-in bit FALSE both-z <== hm2_7i76e.0.gpio.036.in ==> joint.2.neg-lim-sw-in ==> joint.2.pos-lim-sw-in bit FALSE coolant-flood <== iocontrol.0.coolant-flood bit FALSE coolant-mist <== iocontrol.0.coolant-mist bit FALSE estop-out ==> iocontrol.0.emc-enable-in <== iocontrol.0.user-enable-out bit TRUE in-position <== motion.in-position bit FALSE jog-selected-neg ==> halui.axis.selected.minus bit FALSE jog-selected-pos ==> halui.axis.selected.plus float 0 jog-speed ==> halui.axis.jog-speed float 0 jog-x-analog ==> halui.axis.x.analog bit FALSE jog-x-neg ==> halui.axis.x.minus bit FALSE jog-x-pos ==> halui.axis.x.plus float 0 jog-y-analog ==> halui.axis.y.analog bit FALSE jog-y-neg ==> halui.axis.y.minus bit FALSE jog-y-pos ==> halui.axis.y.plus float 0 jog-z-analog ==> halui.axis.z.analog bit FALSE jog-z-neg ==> halui.axis.z.minus bit FALSE jog-z-pos ==> halui.axis.z.plus bit FALSE machine-is-enabled <== motion.motion-enabled bit FALSE machine-is-on <== halui.machine.is-on bit FALSE probe-in ==> motion.probe-input bit TRUE spindle-at-speed ==> spindle.0.at-speed bit TRUE spindle-brake <== spindle.0.brake bit FALSE spindle-ccw <== spindle.0.reverse bit FALSE spindle-cw <== spindle.0.forward bit FALSE spindle-enable ==> pid.s.enable <== spindle.0.on bit FALSE spindle-index-enable ==> pid.s.index-enable <=> spindle.0.index-enable bit FALSE spindle-manual-ccw ==> halui.spindle.0.reverse bit FALSE spindle-manual-cw ==> halui.spindle.0.forward bit FALSE spindle-manual-stop ==> halui.spindle.0.stop float 0 spindle-output <== pid.s.output float 0 spindle-revs ==> spindle.0.revs float 0 spindle-vel-cmd-rpm ==> pid.s.command <== spindle.0.speed-out float 0 spindle-vel-cmd-rpm-abs <== spindle.0.speed-out-abs float 0 spindle-vel-cmd-rps <== spindle.0.speed-out-rps float 0 spindle-vel-cmd-rps-abs <== spindle.0.speed-out-rps-abs float 0 spindle-vel-fb-rpm ==> pid.s.feedback float 0 spindle-vel-fb-rps ==> spindle.0.speed-in bit FALSE tool-change-confirmed <== hal_manualtoolchange.changed ==> iocontrol.0.tool-changed bit FALSE tool-change-request ==> hal_manualtoolchange.change <== iocontrol.0.tool-change s32 0 tool-number ==> hal_manualtoolchange.number <== iocontrol.0.tool-prep-number bit FALSE tool-prepare-loopback <== iocontrol.0.tool-prepare ==> iocontrol.0.tool-prepared bit FALSE x-enable ==> hm2_7i76e.0.stepgen.00.enable <== joint.0.amp-enable-out ==> pid.x.enable bit FALSE x-home-sw ==> joint.0.home-sw-in bit FALSE x-index-enable ==> pid.x.index-enable bit FALSE x-is-homed <== halui.joint.0.is-homed float 0 x-output ==> hm2_7i76e.0.stepgen.00.velocity-cmd <== pid.x.output float 0 x-pos-cmd <== joint.0.motor-pos-cmd ==> pid.x.command float 0 x-pos-fb <== hm2_7i76e.0.stepgen.00.position-fb ==> joint.0.motor-pos-fb ==> pid.x.feedback float 0 x-vel-cmd <== joint.0.vel-cmd bit FALSE y-enable ==> hm2_7i76e.0.stepgen.01.enable <== joint.1.amp-enable-out ==> pid.y.enable bit FALSE y-home-sw ==> joint.1.home-sw-in bit FALSE y-index-enable ==> pid.y.index-enable bit FALSE y-is-homed <== halui.joint.1.is-homed float 0 y-output ==> hm2_7i76e.0.stepgen.01.velocity-cmd <== pid.y.output float 0 y-pos-cmd <== joint.1.motor-pos-cmd ==> pid.y.command float 0 y-pos-fb <== hm2_7i76e.0.stepgen.01.position-fb ==> joint.1.motor-pos-fb ==> pid.y.feedback float 0 y-vel-cmd <== joint.1.vel-cmd bit FALSE z-enable ==> hm2_7i76e.0.stepgen.02.enable <== joint.2.amp-enable-out ==> pid.z.enable bit FALSE z-home-sw ==> joint.2.home-sw-in bit FALSE z-index-enable ==> pid.z.index-enable bit FALSE z-is-homed <== halui.joint.2.is-homed float 0 z-output ==> hm2_7i76e.0.stepgen.02.velocity-cmd <== pid.z.output float 0 z-pos-cmd <== joint.2.motor-pos-cmd ==> pid.z.command float 0 z-pos-fb <== hm2_7i76e.0.stepgen.02.position-fb ==> joint.2.motor-pos-fb ==> pid.z.feedback float 0 z-vel-cmd <== joint.2.vel-cmd Parameters: Owner Type Dir Value Name 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.analogin0 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.analogin1 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.analogin2 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.analogin3 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.encmode0 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.encmode1 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.fieldvoltage 26 u32 RW 0x00000001 hm2_7i76e.0.7i76.0.0.hwrevision 26 u32 RW 0x00000009 hm2_7i76e.0.7i76.0.0.nvbaudrate 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.nvencmode0 26 u32 RO 0x00000000 hm2_7i76e.0.7i76.0.0.nvencmode1 26 u32 RO 0x1A0005C5 hm2_7i76e.0.7i76.0.0.nvunitnumber 26 u32 RO 0x00000032 hm2_7i76e.0.7i76.0.0.nvwatchdogtimeout 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-00-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-01-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-02-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-03-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-04-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-05-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-06-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-07-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-08-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-09-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-10-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-11-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-12-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-13-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-14-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.output-15-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.spindir-invert 26 bit RW FALSE hm2_7i76e.0.7i76.0.0.spinena-invert 26 float RW 100 hm2_7i76e.0.7i76.0.0.spinout-maxlim 26 float RW 0 hm2_7i76e.0.7i76.0.0.spinout-minlim 26 float RW 100 hm2_7i76e.0.7i76.0.0.spinout-scalemax 26 u32 RW 0x0000000E hm2_7i76e.0.7i76.0.0.swrevision 26 bit RW FALSE hm2_7i76e.0.encoder.00.counter-mode 26 bit RW TRUE hm2_7i76e.0.encoder.00.filter 26 bit RW FALSE hm2_7i76e.0.encoder.00.index-invert 26 bit RW FALSE hm2_7i76e.0.encoder.00.index-mask 26 bit RW FALSE hm2_7i76e.0.encoder.00.index-mask-invert 26 float RW 1 hm2_7i76e.0.encoder.00.scale 26 float RW 0.5 hm2_7i76e.0.encoder.00.vel-timeout 26 bit RW FALSE hm2_7i76e.0.gpio.012.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.012.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.012.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.013.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.013.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.013.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.017.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.017.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.017.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.018.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.018.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.018.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.019.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.019.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.019.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.020.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.020.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.020.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.021.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.021.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.021.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.022.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.022.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.022.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.023.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.023.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.023.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.024.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.024.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.024.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.025.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.025.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.025.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.026.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.026.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.026.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.027.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.027.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.027.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.028.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.028.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.028.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.029.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.029.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.029.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.030.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.030.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.030.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.031.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.031.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.031.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.032.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.032.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.032.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.033.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.033.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.033.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.034.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.034.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.034.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.035.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.035.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.035.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.036.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.036.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.036.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.037.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.037.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.037.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.038.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.038.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.038.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.039.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.039.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.039.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.040.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.040.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.040.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.041.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.041.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.041.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.042.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.042.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.042.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.043.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.043.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.043.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.044.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.044.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.044.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.045.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.045.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.045.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.046.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.046.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.046.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.047.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.047.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.047.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.048.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.048.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.048.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.049.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.049.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.049.is_output 26 bit RW FALSE hm2_7i76e.0.gpio.050.invert_output 26 bit RW FALSE hm2_7i76e.0.gpio.050.is_opendrain 26 bit RW FALSE hm2_7i76e.0.gpio.050.is_output 26 bit RW FALSE hm2_7i76e.0.io_error 26 s32 RO 1 hm2_7i76e.0.packet-error-decrement 26 s32 RW 2 hm2_7i76e.0.packet-error-increment 26 s32 RW 10 hm2_7i76e.0.packet-error-limit 26 s32 RW 80 hm2_7i76e.0.packet-read-timeout 26 s32 RW 0 hm2_7i76e.0.read-request.tmax 26 bit RO FALSE hm2_7i76e.0.read-request.tmax-increased 26 s32 RW 1010386 hm2_7i76e.0.read.tmax 26 bit RO FALSE hm2_7i76e.0.read.tmax-increased 26 bit RW FALSE hm2_7i76e.0.sserial.00.tx0.invert_output 26 bit RW FALSE hm2_7i76e.0.sserial.00.tx0.is_opendrain 26 u32 RW 0x00000001 hm2_7i76e.0.sserial.port-0.fault-dec 26 u32 RW 0x0000000A hm2_7i76e.0.sserial.port-0.fault-inc 26 u32 RW 0x000000C8 hm2_7i76e.0.sserial.port-0.fault-lim 26 bit RW FALSE hm2_7i76e.0.stepgen.00.direction.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.00.direction.is_opendrain 26 u32 RW 0x00002710 hm2_7i76e.0.stepgen.00.dirhold 26 u32 RW 0x00002710 hm2_7i76e.0.stepgen.00.dirsetup 26 float RW 937.5 hm2_7i76e.0.stepgen.00.maxaccel 26 float RW 31.25 hm2_7i76e.0.stepgen.00.maxvel 26 float RW 40 hm2_7i76e.0.stepgen.00.position-scale 26 bit RW FALSE hm2_7i76e.0.stepgen.00.step.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.00.step.is_opendrain 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.00.step_type 26 u32 RW 0x00001388 hm2_7i76e.0.stepgen.00.steplen 26 u32 RW 0x00001388 hm2_7i76e.0.stepgen.00.stepspace 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.00.table-data-0 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.00.table-data-1 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.00.table-data-2 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.00.table-data-3 26 bit RW FALSE hm2_7i76e.0.stepgen.01.direction.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.01.direction.is_opendrain 26 u32 RW 0x00002710 hm2_7i76e.0.stepgen.01.dirhold 26 u32 RW 0x00002710 hm2_7i76e.0.stepgen.01.dirsetup 26 float RW 937.5 hm2_7i76e.0.stepgen.01.maxaccel 26 float RW 31.25 hm2_7i76e.0.stepgen.01.maxvel 26 float RW 40 hm2_7i76e.0.stepgen.01.position-scale 26 bit RW FALSE hm2_7i76e.0.stepgen.01.step.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.01.step.is_opendrain 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.01.step_type 26 u32 RW 0x00001388 hm2_7i76e.0.stepgen.01.steplen 26 u32 RW 0x00001388 hm2_7i76e.0.stepgen.01.stepspace 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.01.table-data-0 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.01.table-data-1 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.01.table-data-2 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.01.table-data-3 26 bit RW FALSE hm2_7i76e.0.stepgen.02.direction.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.02.direction.is_opendrain 26 u32 RW 0x00002710 hm2_7i76e.0.stepgen.02.dirhold 26 u32 RW 0x00002710 hm2_7i76e.0.stepgen.02.dirsetup 26 float RW 937.5 hm2_7i76e.0.stepgen.02.maxaccel 26 float RW 31.25 hm2_7i76e.0.stepgen.02.maxvel 26 float RW 40 hm2_7i76e.0.stepgen.02.position-scale 26 bit RW FALSE hm2_7i76e.0.stepgen.02.step.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.02.step.is_opendrain 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.02.step_type 26 u32 RW 0x00001388 hm2_7i76e.0.stepgen.02.steplen 26 u32 RW 0x00001388 hm2_7i76e.0.stepgen.02.stepspace 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.02.table-data-0 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.02.table-data-1 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.02.table-data-2 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.02.table-data-3 26 bit RW FALSE hm2_7i76e.0.stepgen.03.direction.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.03.direction.is_opendrain 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.03.dirhold 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.03.dirsetup 26 float RW 1 hm2_7i76e.0.stepgen.03.maxaccel 26 float RW 0 hm2_7i76e.0.stepgen.03.maxvel 26 float RW 1 hm2_7i76e.0.stepgen.03.position-scale 26 bit RW FALSE hm2_7i76e.0.stepgen.03.step.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.03.step.is_opendrain 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.03.step_type 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.03.steplen 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.03.stepspace 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.03.table-data-0 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.03.table-data-1 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.03.table-data-2 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.03.table-data-3 26 bit RW FALSE hm2_7i76e.0.stepgen.04.direction.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.04.direction.is_opendrain 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.04.dirhold 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.04.dirsetup 26 float RW 1 hm2_7i76e.0.stepgen.04.maxaccel 26 float RW 0 hm2_7i76e.0.stepgen.04.maxvel 26 float RW 1 hm2_7i76e.0.stepgen.04.position-scale 26 bit RW FALSE hm2_7i76e.0.stepgen.04.step.invert_output 26 bit RW FALSE hm2_7i76e.0.stepgen.04.step.is_opendrain 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.04.step_type 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.04.steplen 26 u32 RW 0x00027FF6 hm2_7i76e.0.stepgen.04.stepspace 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.04.table-data-0 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.04.table-data-1 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.04.table-data-2 26 u32 RW 0x00000000 hm2_7i76e.0.stepgen.04.table-data-3 26 u32 RW 0x004C4B40 hm2_7i76e.0.watchdog.timeout_ns 26 s32 RW 96517 hm2_7i76e.0.write.tmax 26 bit RO FALSE hm2_7i76e.0.write.tmax-increased 4 s32 RO 0 iocontrol.0.tool-prep-index 19 s32 RW 52591 motion-command-handler.tmax 19 bit RO FALSE motion-command-handler.tmax-increased 19 s32 RW 83969 motion-controller.tmax 19 bit RO FALSE motion-controller.tmax-increased 19 bit RO FALSE motion.debug-bit-0 19 bit RO FALSE motion.debug-bit-1 19 float RO 0 motion.debug-float-0 19 float RO 0 motion.debug-float-1 19 float RO 0 motion.debug-float-2 19 float RO 1 motion.debug-float-3 19 s32 RO 0 motion.debug-s32-0 19 s32 RO 0 motion.debug-s32-1 29 s32 RW 53646 pid.s.do-pid-calcs.tmax 29 bit RO FALSE pid.s.do-pid-calcs.tmax-increased 29 s32 RW 34587 pid.x.do-pid-calcs.tmax 29 bit RO FALSE pid.x.do-pid-calcs.tmax-increased 29 s32 RW 33098 pid.y.do-pid-calcs.tmax 29 bit RO FALSE pid.y.do-pid-calcs.tmax-increased 29 s32 RW 51292 pid.z.do-pid-calcs.tmax 29 bit RO FALSE pid.z.do-pid-calcs.tmax-increased 20 s32 RW 1017906 servo-thread.tmax 19 float RO 0 tc.0.acc 19 float RO 0 tc.0.pos 19 float RO 0 tc.0.vel 19 float RO 0 tc.1.acc 19 float RO 0 tc.1.pos 19 float RO 0 tc.1.vel 19 float RO 0 tc.2.acc 19 float RO 0 tc.2.pos 19 float RO 0 tc.2.vel 19 float RO 0 tc.3.acc 19 float RO 0 tc.3.pos 19 float RO 0 tc.3.vel 19 u32 RO 0x00000000 traj.active_tc 19 float RO 0 traj.pos_out 19 float RO 0 traj.vel_out Parameter Aliases: Alias Original Name hm2_7i76e.0.sserial.00.tx0.invert_output hm2_7i76e.0.gpio.010.invert_output hm2_7i76e.0.sserial.00.tx0.is_opendrain hm2_7i76e.0.gpio.010.is_opendrain hm2_7i76e.0.stepgen.00.direction.invert_output hm2_7i76e.0.gpio.000.invert_output hm2_7i76e.0.stepgen.00.direction.is_opendrain hm2_7i76e.0.gpio.000.is_opendrain hm2_7i76e.0.stepgen.00.step.invert_output hm2_7i76e.0.gpio.001.invert_output hm2_7i76e.0.stepgen.00.step.is_opendrain hm2_7i76e.0.gpio.001.is_opendrain hm2_7i76e.0.stepgen.01.direction.invert_output hm2_7i76e.0.gpio.002.invert_output hm2_7i76e.0.stepgen.01.direction.is_opendrain hm2_7i76e.0.gpio.002.is_opendrain hm2_7i76e.0.stepgen.01.step.invert_output hm2_7i76e.0.gpio.003.invert_output hm2_7i76e.0.stepgen.01.step.is_opendrain hm2_7i76e.0.gpio.003.is_opendrain hm2_7i76e.0.stepgen.02.direction.invert_output hm2_7i76e.0.gpio.004.invert_output hm2_7i76e.0.stepgen.02.direction.is_opendrain hm2_7i76e.0.gpio.004.is_opendrain hm2_7i76e.0.stepgen.02.step.invert_output hm2_7i76e.0.gpio.005.invert_output hm2_7i76e.0.stepgen.02.step.is_opendrain hm2_7i76e.0.gpio.005.is_opendrain hm2_7i76e.0.stepgen.03.direction.invert_output hm2_7i76e.0.gpio.006.invert_output hm2_7i76e.0.stepgen.03.direction.is_opendrain hm2_7i76e.0.gpio.006.is_opendrain hm2_7i76e.0.stepgen.03.step.invert_output hm2_7i76e.0.gpio.007.invert_output hm2_7i76e.0.stepgen.03.step.is_opendrain hm2_7i76e.0.gpio.007.is_opendrain hm2_7i76e.0.stepgen.04.direction.invert_output hm2_7i76e.0.gpio.008.invert_output hm2_7i76e.0.stepgen.04.direction.is_opendrain hm2_7i76e.0.gpio.008.is_opendrain hm2_7i76e.0.stepgen.04.step.invert_output hm2_7i76e.0.gpio.009.invert_output hm2_7i76e.0.stepgen.04.step.is_opendrain hm2_7i76e.0.gpio.009.is_opendrain Exported Functions: Owner CodeAddr Arg FP Users Name 00026 7fee239df7b5 55bd05587b60 YES 1 hm2_7i76e.0.read 00026 7fee239df741 55bd05587b60 YES 0 hm2_7i76e.0.read-request 00026 7fee239df626 55bd05587b60 YES 1 hm2_7i76e.0.write 00019 7fee23ea7aaa 00000000 YES 1 motion-command-handler 00019 7fee23eab43a 00000000 YES 1 motion-controller 00029 7fee235ccd6a 7fee263f7a98 YES 1 pid.s.do-pid-calcs 00029 7fee235ccd6a 7fee263f76d8 YES 1 pid.x.do-pid-calcs 00029 7fee235ccd6a 7fee263f7818 YES 1 pid.y.do-pid-calcs 00029 7fee235ccd6a 7fee263f7958 YES 1 pid.z.do-pid-calcs Realtime Threads: Period FP Name ( Time, Max-Time ) 1000000 YES servo-thread ( 506427, 1017906 ) 1 hm2_7i76e.0.read 2 motion-command-handler 3 motion-controller 4 pid.x.do-pid-calcs 5 pid.y.do-pid-calcs 6 pid.z.do-pid-calcs 7 pid.s.do-pid-calcs 8 hm2_7i76e.0.write
I attached my hal and ini. I tried the pins like hm2_7i76e.0.7i76.0.0.input-xx where xx is the number, e. g. 00 and hm2_7i76e.0.gpio.xxx.in where xxx is the number, e. g. 000. Do I need to connect field power to all input pins while powering up the mesa board?
A second problem I have with this configuration is the message <2hm2/hm2_7i76e.0: Smart serial card hm2_7i76e.0.7i76.0.0.remote nerror = (29) Under voltage when I start linuxcnc. How can I solve this? Disable the smart serial port in linuxcnc config?
  • anli
  • Topic Author
  • Junior Member
  • Junior Member
6 years 4 months ago #170316 by anli
OK, I found the solution: W1 was set in the wrong position. I use the field power connector TB1 and W1 was set to 2-3. If I set W1 to 1-2 (VIN CON) everything works well. Thanks a lot for your help!
6 years 4 months ago #170319 by bbsr_5a
the default setting is for safty reason and gives lots of people headbangs to find this
as so many do not read the Manual ,woudt be fine to get a quick one Page Info Jumpers,power,ip
  • anli
  • Topic Author
  • Junior Member
  • Junior Member
6 years 4 months ago #170374 by anli
Hm, I read the manual, but maybe didn't understand it. I connected TB1.5 to +24VDC and TB1.8 to GND and thought then setting W1 to 2-3 (VIN SEP) would be right.
6 years 4 months ago #170379 by PCW
I think you have things backwards
Field power for I/O should go to TB1 pin 1 (2,3,4) and pin 5 (VIN)
should be left open if W1 is in the left hand position.
Otherwise you are powering the outputs (which might draw 2 A or more)
via the jumper W1
  • anli
  • Topic Author
  • Junior Member
  • Junior Member
6 years 4 months ago #170464 by anli
Hi Peter, OK, thank you, got it!
Moderators: PCW, jmelson
Time to create page: 0.103 seconds
