Mesa 7i97 setup problem
6 years 4 months ago #171855 by Robster
Hello,
I have a Mesa 7i97 connected to my Linux PC with Debian 9.12 running LinuxCNC 2.7.15.
I was already able establish a connection and read out the card with:
mesaflash --device 7i97 --readhmid
The board is set to 192.168.1.121 and as I just mentioned, no problems connecting to the card.
I created a new machine configuration using the following HAL and INI files.
File Name: test.hal
File Size:8.69 KB
File Name: test.ini
File Size:3.47 KB
When I try to start LinuxCNC with this configuration nothing happens. The boot window appears for a couple of seconds but nothing happens afterwards.
Does somebody know how I can solve this problem?
6 years 4 months ago #171859 by PCW
Replied by PCW on topic Mesa 7i97 setup problem
The best way to diagnose start-up issues with uspace LinuxCNC versions is to
launch LinuxCNC from the command line as any errors will be logged there..
6 years 4 months ago #171968 by Todd Zuercher
I believe that the 7i97 board requires either Linuxcnc 2.8 or Master. That card requires newer versions of the Mesa drivers, and your test config is also made for those versions (they will not work on 2.7.) You will need to upgrade your version of Linuxcnc. The easiest way is usually to change or add repositories pointing to the newer version on Buildbot.
6 years 4 months ago #172277 by Robster
Replied by Robster on topic Mesa 7i97 setup problem
Thank you so far! I updated to Linuxcnc 2.8 and it seems to recognize the 7i97.
Unfortunately I still can't get it to run, the debug file intofrmation states the following:
Note: Using POSIX realtime
hm2: Firmware contains unknown function (gtag-30)
Could not open command file 'shutdown.hal'
3879
Stopping realtime threads
Unloading hal components
I guess it has something to do with the unknown function?
6 years 4 months ago #172286 by tommylight
Replied by tommylight on topic Mesa 7i97 setup problem
The ini file is pointing to a "shutdown.hal" file, but it is not in you config folder.
Most probably can be safely removed from the ini or crate an empty file with that name and extension in the config folder you are trying to launch.
ASUS ROG Crosshair VIII Impact - AMD X570
The following user(s) said Thank You: Robster
6 years 4 months ago - 6 years 4 months ago #172291 by PCW
The "hm2: Firmware contains unknown function (gtag-30)" is a warning and will
not stop linuxCNC from starting. tommylight is correct that the actual startup error is
the missing hal file, but for full functionality a 7I97 needs LinuxCNC 2.9
Last edit: 6 years 4 months ago by PCW.
The following user(s) said Thank You: tommylight, Pro_El, Robster
Moderators: PCW, jmelson
Time to create page: 0.440 seconds
