- Hardware & Machines
- Driver Boards
- Mesa card selection for machine with resolvers - resolver questions
- Henk
- Thank you received: 92
20 Jun 2020 18:55 #172177
by Henk
Mesa card selection for machine with resolvers - resolver questions was created by Henk
HI there
I have started a new retrofit of a Mitsui Seiki HR5 machining centre of 1981 vintage.
The machine is equipped with resolvers (1st time for me). below is a photo of the X axis resolver and a photo of the wiring diagram showing the connections, photo of the Inductosyn scale, fanuc pre-amplifier.
Questions:
The wiring diagram clearly show two excitation signals (sin,cos), but the most resolver interfaces i found online only provide one excitation signal?
The easiest for me would be to use the Mesa 7i49 to get the position feedback into LCNC, but im not sure about the two excitation signals? any advice would be appreciated. I could not find any info on the Fanuc pre-amp, would this be required with the 7i49?
For the full system, im planning to use a 7I80HD + 7i49 + 7i44 +7i70 (x2) + 7i71, i still have a problem with the spindle encoder which will have to be added, but this string of mesa cards done have encoder input interfaces, should i just look for a rotary resolver for the spindle online? Comments on this would be great
Thanks in advance
Questions:
Thanks in advance
- jmelson
- Thank you received: 126
20 Jun 2020 19:37 #172179
by jmelson
Replied by jmelson on topic Mesa card selection for machine with resolvers - resolver questions
Resolvers can be run either way. You can send a single signal to the "rotor" and recieve two signals of varying amplitude on the "stator" windings. Or, you can drive two out-of phase signals to the "stator" windings, and observe the time of the zero crossing on the "rotor".
The resolver rotor is equivalent to the Inductosyn spar. And, the resolver stator windings are equivalent to the two windings on the Inductosyn slider.
Jon
Jon
- Thank you received: 5326
20 Jun 2020 20:23 #172180
Replied by PCW on topic Mesa card selection for machine with resolvers - resolver questions
Unfortunately the 7I49 will not work with inductosyn scales 1. Because of the 2 phase
excitation requirements and 2. Because of the very low impedance, high frequency
excitation and low level output signal.
I think the 2 phase excitation was used on older devices because the interpolation
can be done without analog processing, basically by just measuring the phase
difference of the excitation and the scale signal (a simple digital counter measuring
time between zero crossings)
Maybe you can find an inductosyn/quadrature translator.
The following user(s) said Thank You: Henk
- Henk
21 Jun 2020 01:35 #172213
by Henk
Replied by Henk on topic Mesa card selection for machine with resolvers - resolver questions
That is unfortunate...those converters from Vega cost $1250 per channel.
21 Jun 2020 02:59 #172214
It might not be totally impossible to use s 7I49 if you wired the Inductosyn like a resolver
(excitation on the scale) and you had a gain of 50 to 200 preamp for the sine/cosine signals
Do you have access to an oscilloscope?
- Henk
21 Jun 2020 05:04 #172216
by Henk
Hi PCW. Yes, I do.
Henk
Henk
- HalaszAttila
05 Feb 2021 14:00 #197744
by HalaszAttila
Replied by HalaszAttila on topic Mesa card selection for machine with resolvers - resolver questions
Hello,
we use this type of inductisyn scales on retrofitted machining center with VEGA converters. But it is hard to setup the converters. Easier and better to install new incremental linear scales. This inductosyn is technology from `60.-s.
- HalaszAttila
05 Feb 2021 14:06 #197745
by HalaszAttila
- Henk
05 Feb 2021 14:43 #197750
by Henk
Hi. I also replaced the linear scales but the two rotary axes required very high resolution and it was cheaper to keep the rotary inductosyn encoders.
I purchased Farrand control converters on eBay and manages to set them up using the original pre-amps.
I am very happy with the result.
Henk
Henk
- SHORTCUT
06 Aug 2024 19:41 #307120
by SHORTCUT
Replied by SHORTCUT on topic Mesa card selection for machine with resolvers - resolver questions
Hi Henk, are you from RSA - I am from Port Elizabeth and am trying for many years to find a solution for my home cnc machine which has old resolvers on it - I want to go LinuxCnc type retro but want to use the old stuff - it's a home hobby not a production machine so I am looking to save where I can - you mention Farrand control converters (is this able to convert analogue to digital signal on resolvers etcetc)
I would appreciate any input + I am aware of SA CnC club but it's in JHB and too far for me to attend lectures
- Driver Boards
Time to create page: 0.259 seconds
