7i76e Bit File
6 years 2 weeks ago #186279 by micknucam
7i76e Bit File was created by micknucam
I have been using a 7i92 and a 7i76 card and it works fine i need to use two encoders and used this bit file mesa/7i92_7i76x2D.bit
Have upgraded to a 7i76e card when i load this bit file 7i76e_7i76x1D.bit i get one encoder and I can see this pin in HalMeter hm2_7i76e.0.encoder.timer-number
But as i have highlighted i require two Encoders so i loaded this bit file 7i76e_7i76x3D.bit and when i look on Halmeter this pin hm2_7i76e.0.encoder.timer-number has vanished could some one sort me a Bit file that works and give me the hm2_7i76e.0.encoder.timer-number .
6 years 2 weeks ago #186289 by PCW
Replied by PCW on topic 7i76e Bit File
The bitfile in the archive is old enough that it does not have the DPLL
encoder count sampling option, This should have the encoder timer pins:
File Name: 7i76e_7i76x3D.zip
File Size:167.48 KB
6 years 2 weeks ago #186290 by micknucam
Replied by micknucam on topic 7i76e Bit File
Works Thankyou
Moderators: PCW, jmelson
Time to create page: 0.259 seconds
