7i52s replaced ic pin continuity question
5 years 11 months ago #189050 by 3D-Master
okay i looked at the pinout configuration using mesaflash and then used my oscilloscope to measure the header pins on the 7i80hd (upright position, P1 Header, right row is Ground and left row is bottom to top pin 0-23) but the only thing i measure is 4.6v all the time. I have a repeating program running in linuxcnc while i was measuring. Shouldnt i measure at least low and high on the direction pin?
5 years 11 months ago #189122 by 3D-Master
do the step and dir signals get send 1:1 over the 50 pin cable or do the cards communicate in a different way?
also today the y axis (com1) does work. Maybe i got it wrong when testing or something made it working.
5 years 11 months ago #189139 by PCW
3.3V level step and dir signals are sent by the FPGA card.
The 7I52S simply buffers these signals and splits them
into differential pairs
5 years 11 months ago #189142 by 3D-Master
then i wonder why i only see high signal with my oscilloscope.
5 years 11 months ago #189335 by 3D-Master
i measured again with the 50 pin cable on the 7i80 with my multimeter and i measure constant 4.800V (its a True RMS Multimeter). I also noticed that the connector has 25 rows but the configuration pinout for P1 is from pin 1-47 (io 0-23). Could it be that some pins should be connected somewhere so the 7i80 knows there is a board connected and then sends the signals?
5 years 11 months ago #189336 by PCW
All the even pins are ground
Pin 49 can be used to power the 7I52
There are no logical pins other than on odd pins 1..47
Moderators: PCW, jmelson
Time to create page: 0.320 seconds
