7i96 card may have bad Module Descriptor 4
5 years 8 months ago #198459 by hickory43
My plasmac machine has been operational for several months. Upon startup recently I found that my Z drive motor would not run but the DRO showed movement. I assumed that this might be caused by loose wires in the cabinet so began checking the wiring, continuity, joint tightness, etc, During this process I sparked a few wires. I attempted to bypass the 4th stepper module and use the fifth module without success. I had also changed some of the programing. without dribbling along I am at a point that the attached error message was received
File Name: errortext.txt
File Size:1.52 KB
File Name: RsplasmaC.hal.hal
File Size:7.32 KB
File Name: RsplasmaC.ini.ini
File Size:11.07 KB
File Name: RsplasmaC_....hal.hal
File Size:2.68 KB
. Basic question can the card possibly be repaired or do I need a new card? Best case I'm all wet and it is something else.
Thanks for your help in advance. I have a great time pulling my hair out over this conversion from router to plasma and greatly appreciate all that the many of the forum members do!
5 years 8 months ago #198460 by PCW
The error is likely because you are using firmware with only
4 stepgens (probably has PWM on the 5th stepgen) and you asked
to enable 5 stepgens.
If the system works as far as showing motion on the screen
and the Z axis is wired properly, its likely an issue with the
drive, drive wiring or 7I96 step/dir output
If its just a bad step/dir output on the 7I96, this is reparable
5 years 8 months ago #198487 by hickory43
I have tried to change the configuration from 5 steppers to 4 steppers and a PWM but apparently unsuccessfully. In terms of wiring, I believe that I have things wired correctly, but I have a question, the stepper connections only require two wires, one for step and one for direction, is this correct? Is there a way for me to test the integrity of the # 4 module? I appreciate the quick response.
5 years 8 months ago #198488 by hickory43
I had the wire from the breakaway switch hanging loose while testing continuity of the motor wires. the two sets made contact making some sparks. Thanks for the quick response.
5 years 8 months ago #198489 by hickory43
In terms of the motor driver, yes I did detect some smoke damage across a resister(?) in the motor driver. I replaced the driver but have not been able to test the motor system since I haven't cleared all of the errors.
Moderators: PCW, jmelson
Time to create page: 0.187 seconds
