7i96 card may have bad Module Descriptor 4
5 years 8 months ago #198542 by PCW
hickory43 wrote: I have tried to change the configuration from 5 steppers to 4 steppers and a PWM but apparently unsuccessfully. In terms of wiring, I believe that I have things wired correctly, but I have a question, the stepper connections only require two wires, one for step and one for direction, is this correct? Is there a way for me to test the integrity of the # 4 module? I appreciate the quick response.
In addition to step and direction you need ground or 5V depending on the drive
The module 4 error means you have a hal file issue where you are asking for more stepgens
than the firmware has available (you probably have a "num_stepgens=5" statement in your
hal file but have firmware loaded tha has only 4 stepgens and a pwmgen)
Moderators: PCW, jmelson
Time to create page: 0.043 seconds
