- Hardware & Machines
- Driver Boards
- [SOLVED] Mesa 7i76E - Joint Following Error - Error Finishing Read
15 Apr 2021 00:11 #205955
Replied by PCW on topic Mesa 7i76E - Joint Following Error - Error Finishing Read
What errors do you get?
15 Apr 2021 00:21 #205956
by radicus
Replied by radicus on topic Mesa 7i76E - Joint Following Error - Error Finishing Read
hm2/hm2_7i76e.0: error finishing read! iter=6
joint 0 following error
15 Apr 2021 00:35 #205958
Not sure, do you still get:
"ioctl SIOCDARP: Network is unreachable" ?
Sounds less like latency and more some kind of network setup issue
15 Apr 2021 00:49 #205959
by radicus
No that one is not showing up "ioctl SIOCDARP: Network is unreachable" ?
Here it is in full.
LINUXCNC - 2.8.0
Machine configuration directory is '/home/rad/Desktop/shopsabre'
Machine configuration file is 'shopsabre.ini'
Starting LinuxCNC...
Found file(REL): ./shopsabre.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:48:37
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): IOPort
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): IOPort
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
Found file(REL): ./custom.hal
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
emc/task/taskintf.cc 942: Error on joint 0, command number 95
task: main loop took 0.129135 seconds
task: main loop took 0.150449 seconds
joint 1 following error
emc/task/taskintf.cc 942: Error on joint 1, command number 162
command (EMC_JOG_STOP) cannot be executed until the machine is out of E-stop and turned on
task: main loop took 0.230054 seconds
Running HAL shutdown script
task: 2968 cycles, min=0.000023, max=0.230054, avg=0.010347, 3 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Here it is in full.
LINUXCNC - 2.8.0
hm2: unloading
15 Apr 2021 00:56 #205960
Not sure whats going on, looks like the host drops the connection
as soon as it starts sending periodic packets (it gets through setup OK)
20 Apr 2021 02:50 #206496
by radicus
I set up a new system on a Raspberry Pi4, installed a new CAT6 cable and I'm getting the same errors as I received with my previous machine I was testing on.
Here is the startup/shutdown log and the results of halcmd show param *.tmax
pi@cncpi:~/linuxcnc/configs/shopsab $ linuxcnc
LINUXCNC - 2.8.1
Machine configuration directory is '/home/pi/linuxcnc/configs/shopsab'
Machine configuration file is 'shopsab.ini'
Found file(REL): ./shopsab.hal
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:48:37
hm2/hm2_7i76e.0: Low Level init 0.15
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
hm2/hm2_7i76e.0: error finishing read! iter=8
emc/task/taskintf.cc 942: Error on joint 0, command number 96
task: 3654 cycles, min=0.000173, max=0.065475, avg=0.010062, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: in hm2_eth_reset
hm2: unloading
pi@cncpi:~/linuxcnc/configs/shopsab $ halcmd show param *.tmax
Parameters:
Owner Type Dir Value Name
26 s32 RW 0 hm2_7i76e.0.read-request.tmax
26 s32 RW 861435 hm2_7i76e.0.read.tmax
26 s32 RW 83536 hm2_7i76e.0.write.tmax
19 s32 RW 7704 motion-command-handler.tmax
19 s32 RW 75147 motion-controller.tmax
29 s32 RW 4185 pid.s.do-pid-calcs.tmax
29 s32 RW 8389 pid.x.do-pid-calcs.tmax
29 s32 RW 3518 pid.y.do-pid-calcs.tmax
29 s32 RW 4908 pid.z.do-pid-calcs.tmax
20 s32 RW 981637 servo-thread.tmax
LINUXCNC - 2.8.1
hm2: unloading
Parameters:
20 Apr 2021 03:05 #206497
I don't think a RPI4 can manage a 1 KHz servo thread over Ethernet
I would try 500 Hz = 2 ms =2000000 ns
20 Apr 2021 03:23 #206498
by radicus
I tried
SERVO_PERIOD = 2000000
with P=500 for all 3 axis
Same errors.
LINUXCNC - 2.8.1
check_config: (trivkins kinematics) WARNING:
Unspecified [JOINT_0]MAX_ACCELERATION, default used: 1.0
hm2/hm2_7i76e.0: error finishing read! iter=7
emc/task/taskintf.cc 942: Error on joint 0, command number 108
emc/task/taskintf.cc 942: Error on joint 1, command number 140
task: 2774 cycles, min=0.000137, max=0.056010, avg=0.010066, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2: unloading
Same errors.
LINUXCNC - 2.8.1
hm2: unloading
20 Apr 2021 03:52 #206500
by radicus
Just noticed that while LinuxCnc is running CR4 and CR6 are green. When I exit out CR5 and CR1 turn on. Not sure if that means anything
20 Apr 2021 14:33 - 20 Apr 2021 14:49 #206533
CR1 will be lit if you get a watchdog bite on the 7I76E
so is expected if you lose communications after the card
is setup by LinuxCNC
If you ping the 7I76E, do CR3,CR4,CR5,CR6 count up?
What are your ping times?
Also since you have very similar symptoms
(communications dropped in the first few servo thread cycles)
on different hosts, it does suggest a 7I76E issue,
so returning the card for evaluation is probably a good idea
Last edit: 20 Apr 2021 14:49 by PCW.
The following user(s) said Thank You: radicus
- Driver Boards
Time to create page: 0.269 seconds
