Hello at all and nice to be here,
I'm working on a RPI4 with a 7c81 and I want to control the Spindle VFD via RS485.
I know there was a similar thread using the pktUART on the FPGA but what I try to achieve seems much easier.
Since the RPI TxD0 / 1 (GPIO Pin
and RxD0 / 1 (GPIO Pin 10) are routed to the FPGA wouldn't it be possible to just connect them both to the SSerial Port 0?
Then I could just use hy_vfd.
I'm able to program python and C++ but VHDL is new too me.
I installed Xilinx ISE 13.4 and successfully already created a working BITFile into the Fallback space without changes.
Can you please simply put me into the direction how to connect TxD from RPI GPIO 8 to 7c81.0.Port017 as Output and RxD RPI GPIO 10 to 7c81.0.Port055 as Input?
Changing the behaviour from RS422 to RS485 will be done in Hardware with Resistors.
Thanks in advance, Harry.
