Milling machine stepper axis shuts down with following error
5 years 5 months ago #209180 by PCW
The 7I76 could not cause a following error and if the ini and hal file are unchanged
its pretty much got to be a motherboard or 5I25 issue.
Do you get any other errors?
Is the following error always on the same axis?
Can you post your current hal and ini files?
5 years 5 months ago #209249 by Captainjack
Problem solved! The .ini file looked ok compared to backup so I opened the pncconf wizard and checked all the values which looked correct. I then refreshed the file called my_linuxcnc_machine.pncconf and now the y axis works normally. I am pretty sure the power was interrupted the last time it was used and linux cnc and the pc were not shut down properly. Thanks for the help!
Jack
Moderators: PCW, jmelson
Time to create page: 0.136 seconds
