Mesa 7i96 mixed voltage field input wiring
1 year 7 months ago #323283 by PCW
Here is the 7I96/7I96S input circuit
Notes:
1. The quad optos are AC input type
2. The solid GND symbol is input common
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
The following user(s) said Thank You: tommylight, Pipik
1 year 3 months ago - 1 year 3 months ago #332398 by alexandrap
1.)Hello,Is this connection of the 7i96 inputs identical / similar for the 7i95T?
2.)What is the connection diagram for MPG ENCODER INPUTS (7i95T)?
I have a problem - in the manual for the 7i95T (page 17) it says:
" MPG ENCODER INPUTS
Standard 7I95 firmware provides 4 quadrature MPG encoder inputs on isolated
inputs 0 through 7. Since the input threshold on isolated inputs is about 3V, its best to use
sinking inputs (with the input common terminal tied to +5V) with TTL output level MPGs."
Isn't that sourcing input?
Thanx
Last edit: 1 year 3 months ago by alexandrap.
1 year 3 months ago - 1 year 3 months ago #332406 by PCW
Yes, if the input common is a + voltage, those are sourcing inputs.
( it's easy to get confused as sourcing inputs connect to a sinking drivers and vice versa )
Last edit: 1 year 3 months ago by PCW.
Moderators: PCW, jmelson
Time to create page: 0.333 seconds
