7i76e Stepgen problem
4 years 8 months ago #236095 by stes
7i76e Stepgen problem was created by stes
I'm having a problem with stepgen3. All other step generators work fine with my ihsv57 servo. I'm quite sure that the problems is not in the servo wiring or settings. I measured the voltages on stepgen4 and got 5v for step and dir+, and 0v for step and dir- when linux cnc is off, and when linux cnc is on, its the other way round.
But for stepgen 0, 1, 2 and 3 i get 0v for step and dir+, and 20-60mv for step dir-, whether linux cnc is on or off it doesn't affect the voltages. and all the stepgens can move the servo except stepgen3. What could cause this?
4 years 8 months ago #236114 by PCW
Replied by PCW on topic 7i76e Stepgen problem
Sounds like the driver for STEP0+ .. STEP3+ (74ACT541 U19)
is damaged.
4 years 8 months ago #236115 by stes
Replied by stes on topic 7i76e Stepgen problem
Thought I was careful installing it. Is this the part? TSSOP-20 package?
4 years 8 months ago #236125 by PCW
Yes TSSOP-20
4 years 7 months ago #238908 by stes
I changed the U19 chip but voltages are still the same.
4 years 7 months ago #238994 by stes
Now when I measured Vcc on U19 is 5v.
For stepgen 0 to 3 dir- and step- is 20 to 60mV, dir+ and step+ 0V.
For stepgen 4 step- and dir- 0V, step+ and dir+ 5V.
I didn't connect anything on the board after changing the chip except power and Ethernet cable. Could there be some other issue than U19?
Moderators: PCW, jmelson
Time to create page: 0.198 seconds
