7i76e Stepgen problem
4 years 7 months ago #238996 by PCW
Replied by PCW on topic 7i76e Stepgen problem
If you connected say 24V to the step/dir pins, you may have
blown up the 27 ohm resistor networks between U19 and the
terminal blocks.
4 years 7 months ago #239001 by stes
Replied by stes on topic 7i76e Stepgen problem
Thanks. Those resistor networks are RN3, 7, 24 and 32? What packages are those? I will try to measure the voltages from the U19 directly and if it's ok then I will change those resistors.
4 years 7 months ago #239007 by PCW
Yes RN3,7,24,32 27 Ohm MNR14 (1206)
Moderators: PCW, jmelson
Time to create page: 0.176 seconds
